Can the rear wing be removed without trunk damage?
Am curious if removing the rear wing on the ZR1 will leave mounting holes in the trunk. Presume yes? Is is drilled to otherwise also fit a factory Vette logo?
Received 3,793 Likes
"Ask Tadge" Producer
Some of the earliest deliveries of the ZR1 photos here on the forum show pictures of the car before the stanchions are mounted, as that's how it's sent to the dealers. Hunt around; you should be able to find them.
Received 1,816 Likes
You could stick a couple of bobble-heads on the wing mounts to cover them up.
intensifi (10-10-2018)
