USB media in 2019 ZR1
Been trying to get my music library on USB to play in my 19 ZR1. It doesn't seem to recognize that it's attached. Does it take time to read the drive? Are there size limitations? Any other considerations?
Did u format the drive first , mine had no problem with a cheap USB stick . I just plug mine in , then select media ....
Dave
Dave
I have 9 gig on mine and it reads it pretty fast when I have it set to play it on startup , I get the no media found first , then it must sense the stick and it starts to play . My itouch does the same thing on startup and I have 32 gig on it
maybe buy a cheap 4 gig. Format it , when formatting you must switch to fat 32 if I are using windows 7 or 10 and then just put a few songs on it to see if it recognizes the stick
Dave
Dave
I may have found the problem. Windows 10 doesn't allow formatting to FAT32 with a drive larger than 32GB, only exFAT format. Formatting into FAT32 by command line prompt. We'll see if this works.
