Closing Speeds
#41
The new 911 difference seems to be in the GT3 it is an 'Always On' (Active Handling) chassis intervention.
And in the RS's it is just 'Always On!' plus $4000 worth of one lap tires!
#42
Heavy, how about? ;)
Thats more like it......
Because no one outside of GM employees or owners who drank the kool-aid are that sold on PTM. I've mentioned I don't trust any manufacturers claims until really and independently proven in real life. I took me less than half a lap at Road Atlanta to not like PTM. Just the simple fact that it makes drivers worse by teaching them to completely abandon proper driving technique and lean on TC is enough for me not to like it. I don't like DCT, autos or rear wheel steer either. That's just me, I'm old school and believe in driver development over vehicle development. The latter has taken over in recent years, even in pro racing. I hardy watch any of it, because guys in suits decide who wins, no the best drivers.
Back to PTM, there is no arguing that it teaches improper muscle memory. Just turn and floor it and let PTM sort it out is a crash in most any other car (including Porsche whom you inaccurately want to compare drivers aids) . If GM wants to sacrifice all of its owners driving skill for track cred, then I don't support that. Never will. And outside of GM's clearly paid for tests, there is no proof it's actually faster.
#43
These are the things you can't quantify on a stat sheet which most yokels won't understand.
#44
Do I really need to explain to you the difference between PTM and PTV? Not even remotely the same concept. Yes, all nannies, all cars now are ridden with them. But not the same at all.
#45
Okay, you can fill in some things! ;)
The RS Porsche's at a minimum use brakes at corner entry.
The Vette's just tap on the diff. all the way through, and apply T/C (Tire Calibration) exiting in 'Race Mode' to minimize wheel spin.
What am I missing Heavy?
#46
Track Rat
Don't we already have enough threads debating the ZR1 vs GT2RS and PTM vs other nannies?
The following 3 users liked this post by Poor-sha:
#49
Track Rat
Damn good driver you are!
#51
First of all, I think they both have to do with an always on locking differential, which locks on the straights.
The RS Porsche's at a minimum uses brakes at corner entry.
The Vette's just tap on the diff. all the way through, and applies T/C (Tire Calibration) exiting in 'Race Mode' to minimize wheel spin.
You are using marketing fluff to describe PTM, don't beat around the bush.
I'll tell you what. Go floor a PTM enabled Corvette through the corner and let the motor cut throttle all the way through to keep you on track and then go floor a PTV/RWS GT2RS through a corner and you can bet you behind the outcome will be completely different. PTM is more comparable to PSM than PTV anyways. You can't spin it any other way.
That being said, let Sean have his thread back. No that you are typing in English, I'll answer your posts, just take it elsewhere.
CorvettoBrando (11-07-2018)
#52
You are moving along well poorsha...
how much time have you shaved off your best time from, say, 2 months ago?
also, see if you can complain to Tadge that the G Meter needs to read higher on the circle. It is frustrating not being able to see in real time video the real G's the cars are pulling. Chevy should offer a software update to take it to 1.5 g circle/readout for those who can actually drive.
#53
#54
Track Rat
The friction circle doesn't bother me because I just load everything up in Pi Toolbox and look at the data.
I know that's been escalated to Cosworth and I've sent them some data files. No news so far though.
#55
Why steel
u may have addressed this before but i thought that the carbon brakes were a great advantage over steel? I’m using the stoptech st60/40 setup on my c6z w/SRF fluid and feel like the carbon c7z is significantly outbraking me. Did u switch cause of $ savings? Sorry if this is a repeat question for u.
#56
Track Rat
#57
Great driving as usual Sean.
Man the speed you are carrying now into T14 is astounding. I liked on that last lap where you pushed it a bit harder and bobbled the line a bit on the entry because you came in hotter and were right at threshold braking from what I could tell. Not a criticism; it's what happens when we push ourselves and you clearly were.
The best I've managed in that section is 161, and I bobbled that time as well.
Looks like my skid marks are still there in T5b as well as a few new ones...
Poor-sha (11-12-2018)
