C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Differences washing ZR1 and Z06
Old 12-27-2018, 11:55 AM
  #61
Steven Bell
Moderator
Support Corvetteforum!
Steven Bell's Avatar
Liked 3,846 Times in 2,390 Posts
St. Jude Donor'15
Originally Posted by punky View Post
Once a week or so with a good dose of detail spray and it was gorgeous. Anyone who washes regulary and uses Adams Detail Spray after each knows that it is hardly necessary to slave over a finish.
This is somewhat correct....IF.....your paint and finish is pristine already. That's why I wanted to see your paint. If it's pristine with no spider webs, swirls or marring, then you can do the Detail Spray without much problem.
I'm not going to bore anyone here with my technique as I think just about any guy already knows how to wash a car. To the fellows here who seem to take issue with someone who dares to voice an opinion about Corvettes but does not currently have one in his garage I can tell them I am currently in the process of acquiring my 11th Corvette which will be a C7, M7, Z06.
Sir, you are more than welcome to voice your opinion here on CorvetteForum. But do NOT diss others who don't share your views. An adult-like debate helps to share different options WITHOUT trying to tell others they are wrong. That's how we learn....even old dogs like me can learn new tricks.
Steven Bell is offline
The following 3 users liked this post by Steven Bell:
DebRedZR1 (12-27-2018), Glenn Quagmire (12-27-2018), intensifi (12-27-2018)
Old 12-27-2018, 12:10 PM
  #62
MMD
CF Senior Member
MMD's Avatar
Liked 337 Times in 243 Posts
Originally Posted by Mr. Gizmo View Post
I recited the “washing a zr1 versus z06” soliloquy Verbatim as you described above to a hooters waitress and she said she wants to meet you. Her headlights started perking up.
If I only knew this when I was 13.
MMD is offline
The following users liked this post: MMD
Old 12-27-2018, 12:33 PM
  #63
punky
CF Senior Member
punky's Avatar
Liked 407 Times in 255 Posts
Am I correct to assume that this advisement would also be directed at those here who fail to share to share my perspective and ask me if I was "beaten as child" or question my sanity?
punky is offline
The following users liked this post: punky
Satanspawn (01-01-2019)
Old 12-27-2018, 01:07 PM
  #64
intensifi
CF Senior Member
Liked 64 Times in 45 Posts
excellent. Mission accomplished.
intensifi is offline
Old 12-27-2018, 01:12 PM
  #65
MMD
CF Senior Member
MMD's Avatar
uuhhh...were you beaten as a child?
MMD is offline
Old 12-27-2018, 02:48 PM
  #66
punky
CF Senior Member
punky's Avatar
I'm sure anyone else who may disagree with you was.
punky is offline
Old 12-27-2018, 02:59 PM
  #67
MMD
CF Senior Member
MMD's Avatar
you brought up the topic, so I had to ask. Apparently you are the only poster disagreeing with most everyone on the thread. Just maybe your old school way has not held up to more technical and effective methods of detailing 2 stage paint surfaces. What you consider to be a great shine with just applying some detail spray under closer inspection by folks who detail for a living would show up many paint flaws. I am 100% sure of this.
MMD is offline
Old 12-27-2018, 03:34 PM
  #68
punky
CF Senior Member
punky's Avatar
You are beautiful Man, love the continued enlightenment. "2 stage paint surfaces", really, welcome to 30 years ago. Base coat/clear coat is what you are referring to here but keep in mind that tri-coats are quite common now and have been for a very long time. Tell me Mr MD exactly what do your clay bar and various other wiz bang automotive treatments that you are obviously sold on do for these single or dual base coats? Do you also buy expensive automotive leather interior treatments also which are absolutely useless now?
punky is offline
Old 12-27-2018, 03:38 PM
  #69
DebRedZR1
Moderator
DebRedZR1's Avatar
Liked 1,163 Times in 626 Posts
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
How bout debating detailing methods over in the section for that. This thread is way off the topic..........
DebRedZR1 is offline
The following 3 users liked this post by DebRedZR1:
Glenn Quagmire (12-27-2018), intensifi (12-27-2018), Repo Pilot (12-27-2018)
Old 12-27-2018, 04:04 PM
  #70
Glenn Quagmire
CF Senior Member
Glenn Quagmire's Avatar
Liked 297 Times in 165 Posts
Glenn Quagmire is offline
The following users liked this post: Glenn Quagmire
Old 12-27-2018, 05:48 PM
  #71
punky
CF Senior Member
punky's Avatar
^^^I love it. The detailing boys and their purveyors of high tech concoctions have some great stuff for cleaning your windshield also, only problem is they cost 135 times as much per unit volume and clean 1/2 as good as ammonia and water.
punky is offline
Old 12-27-2018, 06:12 PM
  #72
UnhandledException
CF Senior Member
Liked 101 Times in 81 Posts
This is too much work.
Wrap the entire car (or as much of it as you can afford) with xpel.
then add ceramic coating.
From that point on, you just need to wash it and it will look like new for several years.
UnhandledException is offline
The following 3 users liked this post by UnhandledException:
intensifi (12-27-2018), propete (12-28-2018), Satanspawn (01-01-2019)
Old 12-27-2018, 06:31 PM
  #73
MMD
CF Senior Member
MMD's Avatar
Preps the painted surface by cleansing the paint. Very small defects in the paint can be seen in the paint. The whole process of paint correction is to minimize these defects. Your procedure does not resolve issues in the paint. See images below. Detailing now is a lot more technical than what you have learned back in the day. There is a lot more science and there is some art involved. See pics below.
MMD is offline
Old 12-27-2018, 06:41 PM
  #74
UnhandledException
CF Senior Member
Claying unless done regularly takes me at least 4-5 hours. If you clay once a month or two (assuming its driven only weekends), then it can be spot done. But overall its a very difficult thing.
Old 12-27-2018, 06:50 PM
  #75
intensifi
CF Senior Member
What clay and lube are you using?
That seems like a long time. I switched to the clay mitt and use heavily diluted waterless wash as a lube and it's about a 30 min job (I go very slowly).
The following users liked this post: intensifi
MMD (12-27-2018)
  #76
punky
CF Senior Member
punky's Avatar
Wow, most enlightening. I'll think about how terrible my clearcoat is the next time I get sideways and pull second gear.
punky is offline
Old 12-27-2018, 07:10 PM
  #77
intensifi
CF Senior Member
The following 2 users liked this post by intensifi:
MMD (12-27-2018), Rodbuster56 (12-28-2018)
  #78
MMD
CF Senior Member
MMD's Avatar
Get a Nanoskin glove. It will take a fraction of the time and do a better job. Clay bar is old school.
MMD is offline
Mr. Gizmo (12-28-2018)
Old 12-27-2018, 07:59 PM
  #79
F4Gary
CF Senior Member
F4Gary's Avatar
Liked 107 Times in 79 Posts
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
4) No need to clean rust off rotors post wash on ZR1
The first time you drive your ZO6, the rust will be gone with the first brake application. Removing it by hand is a waste of time.
Otherwise, some good tips in here.
F4Gary is offline
The following users liked this post: F4Gary
Old 12-27-2018, 08:23 PM
  #80
Repo Pilot
CF Senior Member
Repo Pilot's Avatar
Liked 135 Times in 89 Posts
Oh come on dude... Were you pulling it in the Corvette you 'just sold' or in were you pulling it in your bathtub?
Was that in your driveway or on a gravel road?
Either Post some pictures or write down the last 4 of the VIN of - what was it?.. your Z06/07?
BTW - the clear coat can't be fixed by A-Damn's magic smell good look good spray or what ever it was, and it really needs to be wet sanded to be corrected...OH -or maybe there is an Adams spray-on wet sander we should all be using Mr Troll. Please go find another forum to nest in.
Thank you.
Repo Pilot is offline
The following 4 users liked this post by Repo Pilot:
DebRedZR1 (12-27-2018), intensifi (12-27-2018), MMD (12-27-2018), Rodbuster56 (12-28-2018)
Quick Reply: Differences washing ZR1 and Z06
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
