Need help regarding CF side skirt replacement
Fellow members,
i need to find out:
- The part number/cost of CF side skirt (this is not the painted rocker panel but the little thin CF piece)
- Installation instructions and any other useful information about installing (i.e I believe there are holes drilled to the body by the dealer and rivets used that are pushed in, can those holes be reused or new holes drilled)?
Trying to figure out if I can do this one myself.
i need to find out:
St. Jude Donor '14
Fellow members,
i need to find out:
i need to find out:
Do you have CF aero already? I have a couple sets here that reuse the OEM holes.
It's very easy, you just need black 3/16" rivets and you can repurpose those holes! I took the SODP aero off of mine and put all of our new aero on it:
My ZR1 is torch red. Yes I have all the aero on it already. This piece was damaged in transit and insurance will pay for replacement/install. Good to know its easy to install. I’ll look into getting a riveting gun, hope its not too expensive.
Ben@WeaponX (01-14-2019)
