Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C7 Corvette > C7 ZR1 Discussion
Reload this Page >
ZR1 Carbon ceramic brakes versus Z06 Carbon Ceramic
C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Old 02-03-2019, 12:47 AM
intensifi
CF Senior Member
Default ZR1 Carbon ceramic brakes versus Z06 Carbon Ceramic
Differences?
intensifi is offline
Old 02-03-2019, 01:24 AM
range96
CF Senior Member
Same, except for the different pad material.
range96 is offline
Old 02-03-2019, 01:30 AM
Rinaldo Catria
CF Senior Member
Rinaldo Catria's Avatar
Copied from Brembo sourced article: Although the size of the fixed aluminum calipers hasn't changed from the Z07, the brake rotors and the friction materials have been enhanced to provide additional track capability to match the increased performance of the vehicle.
The front carbon-ceramic rotor is manufactured with a special heat treatment in order to improve its resistance to the higher thermal load and to increase the heat dissipation under the most demanding track conditions.
The front and rear brake pads are made with new formulations developed under the guidelines of the Brembo R&D Center with the purpose of providing higher stopping power and better pad wear under more demanding and challenging braking conditions. ​
https://www.brembo.com/en/company/ne...-brembo-brakes
Complete source material for my previous post.
Rinaldo Catria is offline
The Following User Says Thank You to Rinaldo Catria For This Useful Post:
DebRedZR1 (02-03-2019)
Old 02-03-2019, 01:38 AM
intensifi
CF Senior Member
So for the sake of argument if I wanted to change the color of my ZR1 calipers, I could just install Z07 (from Z06) calipers on the ZR1 using the original ZR1 pads and ZR1 rotors on the ZR1 and all is well?
If so I’m guessing I’ll need new caliper bolts for the swap as the ZR1 caliper bolts are torque to yield (TTY)?
Old 02-04-2019, 09:04 AM
hcvone
CF Senior Member
Support Corvetteforum!
Have a 17' Z06/Z07 and a 19' ZR1, have not bedded my ZR1 brakes yet, but I have not been able to tell any difference yet, need warm weather
hcvone is offline
Old 02-04-2019, 11:27 AM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
If so Iím guessing Iíll need new caliper bolts for the swap as the ZR1 caliper bolts are torque to yield (TTY)?
Yes, the calipers are listed as the same part numbers for all J57 (carbon ceramic brake) equipped cars. As stated above, the rotors and pads carry a different part number from the GS/Z06 with J57 and the ZR1.
RichieRichZ06 is offline
Old 02-04-2019, 11:52 PM
Hib Halverson
CF Senior Member
Yo Richieeeee-
For the different PN....front and rear or just front?
Hib Halverson is offline
Old 02-05-2019, 11:31 AM
RichieRichZ06
Supporting Vendor
St. Jude Donor '08
Originally Posted by Hib Halverson View Post
Yo Richieeeee-
Front and rear have different part numbers
Quick Reply: ZR1 Carbon ceramic brakes versus Z06 Carbon Ceramic
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
