C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Tires rubbing when backing up?
Old 02-11-2019, 02:21 AM
Palantirion
CF Senior Member
Palantirion's Avatar
Default Tires rubbing when backing up?
Does anyone else's ZR1 shudder intermittently as if the front tires are catching or rubbing when you back up with the steering not quite at full lock? Or when going forward at full lock? ZTK tires.
Palantirion is offline
Old 02-11-2019, 03:20 AM
Rinaldo Catria
CF Senior Member
Rinaldo Catria's Avatar
. I think you are just experiencing wide tire shudder which occurs because the inside and outside of the tire are so far apart that in a tight turn radius, the outside of the tire has to travel a longer distance than the inside. It causes one of them to have to “skid” which often sounds like a rubbing noise. The tires can even hop a little giving a vibration that can sound like a clunking noise.
Rinaldo Catria is online now
The Following User Says Thank You to Rinaldo Catria For This Useful Post:
Palantirion (02-11-2019)
Old 02-11-2019, 07:54 AM
UnhandledException
CF Senior Member
does this happen even on pss tires or just cups? Does it still happen if tires are warm?
UnhandledException is offline
Old 02-11-2019, 08:38 AM
hcvone
CF Senior Member
Support Corvetteforum!
Happens on my cup tires and my pss, the colder the worse it is, my tts does the same thing, did it with the stock Pirelli's and I have pss on that too now
hcvone is online now
Old 02-11-2019, 08:53 AM
GrapemanZR1
CF Senior Member
GrapemanZR1's Avatar
Mine does the same thing, and as with Carl's, it is decidedly more noticeable the colder the tires. When warm, I hardly notice it.
GrapemanZR1 is offline
Old 02-11-2019, 08:55 AM
UnhandledException
CF Senior Member
Thanks guys
Old 02-11-2019, 11:33 AM
Palantirion
CF Senior Member
Thank you guys VERY much, was worried the delivering dealer might have done something wrong during PDI (besides putting the wrong wings on).
Old 02-11-2019, 01:02 PM
tooold2race
CF Senior Member
It's not a 'Corvette exclusive' issue..... Pretty much happens on everything with really wide low profile tires. Just get used to it....
tooold2race is offline
Old 02-11-2019, 05:54 PM
DTOM
CF Senior Member
Sounds like you may be experiencing the Akerman effect. This is mentioned in the manual.
DTOM is offline
Quick Reply: Tires rubbing when backing up?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
