C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Track day number options for ZR1 Coupe
Old 02-17-2019, 12:41 AM
Rinaldo Catria
Rinaldo Catria's Avatar
Default Track day number options for ZR1 Coupe
Looking for ideas/suppliers for track day numbers.
Old 02-17-2019, 06:47 AM
foot 1
foot 1's Avatar
You can order them from club registration.net
Old 02-17-2019, 07:57 AM
william wyatt
william wyatt's Avatar
How do they stick to fiberglass???
Old 02-17-2019, 10:48 AM
davester
davester's Avatar
I use common adhesive backed vinyl shelf liner that I buy at ACE Hardware. I have a template for my numbers in the required sizes depending on the sanctioning organization. Pick your type style and print and enlarge on your printer then transfer to a suitable material to make your templates out of. Easy to apply, stick like glue, and peel right off even after hot track days leaving no residue. Factory produced numbers get a bit pricey if you are peeling them off between events and re-applying.
Old 02-17-2019, 11:09 AM
range96
range96's Avatar
Received 1,978 Likes on 1,216 Posts
Default Herbie
Old 02-17-2019, 09:18 PM
SPDYC6
SPDYC6's Avatar
Give a company called Solo Performance Specialties a call at 877-614-7656. They have reusable numbers that static cling to your car. They're vinyl stickers that come in all different size's and shapes.
Joe
Old 08-11-2020, 03:10 PM
Sensr215
Sensr215's Avatar
I second the recommendation for https://www.trackdecals.com/, they are excellent, and have several options.
Old 08-11-2020, 03:30 PM
rico750sxi
rico750sxi's Avatar
I use static cling vinyl cut with a Cricut. I've never had an issue with them coming off at speed.
Old 08-14-2020, 09:32 AM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
I understand that a good coating of ceramic paint coat will not allow decals to stick very well. If your paint has not been treated you should be okay.
To Track day number options for ZR1 Coupe
Quick Reply: Track day number options for ZR1 Coupe
