Mystery Pass on 3/23/2019
scottss (07-10-2019)
#122
Zr1
When somebody is trying to BS somebody who has actually done the testing and knows the results it's like blood in the water to a shark. The more they talk the more apparent it is that they've never even touched one of these cars or done the testing and they shouldn't be making those statements because it spreads false information. I really dislike false information because before you know it people start to parrot it like it's a fact so you may as well stop it before it starts.
#123
My contention is that since now that we know for a fact that Farmer not only ran 100 octane fuel but a 100 octane fuel that is highly oxygenated compared to pump gas that two things happened on Famer's runs, one, the lower stoich of VP MS100 caused the computer to lean out the mixture to actually increase HP because it takes a while as Nic pointed out for the LTFT's to actually make a significant difference in WOT fueling and then number two and more importantly, highly oxygenated fuel will make a nice HP bump in power, ESPECIALLY on a forced induction motor like the ZR1. My contention then is that likely ~3MPH of the 140 MPH is due to the use of this "special" fuel.
Since we are at a "he said/she said" without facts and date on the run I will buy some of that same fuel and personally test it with no tuning changes in a vehicle on my chassis dyno and report the results back to the Corvette Community later this year and this will irrefutably settle this issue so for now, stay tuned lol!
The following 2 users liked this post by JMB:
h3mpking (07-10-2019),
Thomasmoto (07-10-2019)
#124
Zr1
I'll make it short and sweet, the debate here is whether the use of VP MS100 "Oxygenated" fuel contributed to the record 140 MPH pass by Farmer over and above the fact that this fuel contains 100 octane to prevent detonation. Mr. Abbott contends that the use of this fuel "only" prevents detonation and likely causes the computer LTFT's (long term fuel trims) to actually add more fuel due it it's lower stoich (13.82) vs that of pump gas (14.7) which would make the car run richer AND slower because the ZR1 is too rich as delivered from the Factory already.
I'm looking forward to your results.
Thanks for doing that.
#125
Now that makes sense. Someone has to follow suit in order to prove an accurate point. FARMERS set up even without dyno information should be in the 700 rwhp range . 50 rwhp without a tune is amazing.
#126
Platinum Supporting Vendor
Let's address these. First NicD, nobody is BS'ing anyone. I have not calibrated this car and I have not scanned this one car either during any of the runs like I said very early in the thread. My whole statement about the A/F was based on how the car functions from how JMB was referencing. I also noted that and where you were correct and I was not basing the logic of the 14.10 vs 14.68 on the C7. I was just showing where those calculations were flawed. For you to make is sound like we or I was lying is a total farse and that is the real BS. Like I said you or anyone else is more then welcome to come visit and hang at the track. Now as far as JMB testing, I look forward to it since I have not had the ZR1 on the dyno yet. We talked about a lot of things and there were a lot of accusations made so I welcome any and all testing. I looked up the oxygenated percentage of MS100 which is 3.61%, Now reading about local fuels, there is not much information on it, but I was able to find something on our summer fuel being 2.5-2.75% Not a big difference but a difference, so with the stoich stock of 14.11 and then the MS100 at 13.82, I am still saying that we are not running leaner but richer once the fuel trims are taken into account. So once we are back at the track I will start logging the car and see what the fuel trims are. I also plan on running the car on the dyno and see what happens after Carlisle this year or maybe a little later depending on how busy I am. What nobody seems to mention though is why any of this matters. This fuel was not used in the car on the stock and DR runs, it was used on the last run to see what it would do. So if you have a ZR1 then who cares, if you are the track and are going to be racing the car, but 100 octane in it, remove the seat and remove the spoiler and have fun. For the purposes of testing though, I am all for it.
#127
I don't speak generally when we are on a very specific topic so you'll have to forgive me for thinking we were talking about ZR1s or even LTx applications. However I would still not run that lean of an AFR at WOT on a blower or turbo setup no matter if it's direct injected, port injected, or a combination of both. BTW my question was rhetorical and I asked if you learned about that in a class because you talk about this stuff like you are so certain yet you haven't even touched one. If you had you wouldn't be making half of these statements.
#128
I don't know how much this is worth for this subject, but my ZR1 on the dyno made 606hp on a 90 degree day with only 1 small fan in front of the car. I can't recall the torque right this minute, but will post it here when I find the printout. And this was on 93 pump gas from a local station.
I would think most all stock ZR1's in the same heat would be somewhere in that ball park. So what kind of power does it take to get that car to that speed and ET? I'm thinking the DA is the biggest reason and using as little gas as possible would be the others plus tires and track prep. My best 60' 1.60 to 1.75 and 1/8th mile ET's are 6.9 to 7.1 at 100 to 105 with 100 being see the most often. You guys are saying that these very fast runs are just accomplished with cold air and a little weight out of the car? My local track is 1/8th mile and I've been going there for 40years. For my ZR1 to run that it would need around a 200 shot of spray or some serious bolt on's. to get those times and speeds. I've driven both my 16 Z06 and my ZR1 in some pretty cold air. Yes, they feel very strong due to the temp, but I can't see it being worth 200 hp. I'm not calling anyone any names, I don't do that and I've seen some street cars being a little faster than others of the same model, mostly turbo Buicks back in the day, but this seems exceptional.
Congrats to those that have done it.
JMHO
BTW I plan on trying some 100 unleaded at my next trip to the track. I'll see what, if any, real changes that alone might make. Right now I have access to some Sunoco GT 100 unleaded.
JMHO
#129
JMHO
JMHO
Thomasmoto (07-24-2019)
#130
Received 2,045 Likes
Dynoing the car doesn’t show how much actual hp it was making on a particular day at the track as usually people post corrected numbers, but I would be curious how much the fuel makes a difference at the optimum engine temperature when it’s just poured in and then a pull is made. It does surprise me that as much as this car has been to the track that it’s never rolled across the scales, guess no one was curious like I am.
#131
Not entirely true...in theory you could dyno on a mobile dyno at the track, the "uncorrected" power would be the actual power that you are making at that very moment given all weather conditions and altitude and if you rolled off this mobile dyno and made a pass it would be apples to apples! But the reality/practically of this? Slim and none but if you did happen to dyno on the same day that you went to the track your "uncorrected" number would be pretty darn close to what is happening at the track unless there is a very dramatic weather change.
#132
#133
Correct, but have you ever seen a mobile dyno at the track and how many people dyno the same day they race? Regardless it still doesn’t take into account airflow at speed, not saying a stock car will have much of a ram air effect. Though I know my the kpa in the manifold of my NA C5 with vararam was higher in 4th gear rolling than on the dyno.
#134
Mr. J Abbott. if you're a chess player I call "check" and if your not then I'm calling checkmate lol Put your stock ZR1 on Steroids…VP MS100 vs pump gas: 50+ RWHP!!!
#135
I'm not calling anyone a liar. I also have a approx. 879hp Z06 with a small shot of spray and a cam upgrade and my best mph yet is 136. I've got my engine out for a refresh and cam change and will be over the moon if I can get to 147 mph on motor alone.
I know these " hero " runs are done under the most ideal conditions and usually at track rentals so they don't have to keep the car pulled up in staging and so on. I have posted before lets see some of these cars run in 90 degree heat and at tracks other than the ones that always pull your shoes off if you walk on them. Let's just see how much of a difference it makes.
I just can't figure where you can find enough power from a stock LT5 to go 147mph. I can see taking weight out of the car to help et, but 147 is a serious hp difference. My best mph in my all stock ZR1 has been 130. I don't know if a 200 shot of spray would get it to 147.
I've been doing this a long time and every once in a while you find a car that is a little faster than the others, but I've never encountered this much difference.
would not worry there is such a thing as happy tracks and timers
#136
I have a 2019 stock ZR1. Was at the Texas mile a few weeks ago . Best quarter was 132.3. Last Spring we ran 135.5 with a top speed of 190.5 with spoiler in place( low wing car) , same event. The event a few weeks ago best top speed was 189.4 with the spoiler removed. Conditions make a huge difference on these cars plus whether you get a tailwind, headwind, no wind , etc. It is never apples to apples unless running cars back to back. Several years back during a hurricane ( we were pretty far inland) we ran 175 in to the wind on Friday evening , Rained out Saturday, Ran 187.5 Sunday once the wind got behind us. Conditions can make you a hero or a zero. I do believe farmer has these cars figured out and just like the rest of us they post the "great" #s. Not the stinkers. You never brag about losing money at the casino. But you sure tell your buddies when you hit a big jackpot.
23/C8Z (10-31-2019)
