Top speed testing
I know there are more than several owners on the forum who have enjoyed that experience and am looking forward to it.
For those of you with first hand knowledge a couple of questions...
First - what kind of fuel consumption rate did you see at sustained full throttle. I've heard the number 1.5 gallons a minute kicked around.
Next... Since the top end speed is ECM limited does removing the BAW really make a difference in the speed you will see after over 2 miles of full throttle operation?
Did you do other stuff like fold back the side view mirrors to reduce drag? If you did what other items did you find on the car that were "high drag" and what did you do to mitigate the issue.
Did you have the do a high-drama launch or could you launch spirited until about 70 before you put the pedal to the metal.
What was your VP fuel of choice?
Any other special prep other than emptying your bladder first?
I will be wearing my Ron Fellows "Life begins at 200" ZR-1 T-shirt.
Thanks in advance
I did not fold my mirrors in, neither did any of the 20 other cars. I made all of my runs in track mode. These included three standing 1 mile runs and two standing 2.7 mile runs. Total mileage for the day was under 20 miles. I did not do any prior fuel consumption calculations, but I showed up with a full tank of gas and left with 3/4. Had I known 20 other cars would be there I would have came with perhaps a half tank. I took off the stage 2 rear spoiler wings. I ran with a stage 2 ACS front splitter since removing it would have been a pain in the ***. I did 180 mph in both 2.7 mile runs. You will be incredibly faster, obviously. Cars with less HP than than a C7 ZR1 did over 200 mph in the standing 2.7, including a C6 Z06. There was a Bugatti that did 261 mph.
This was by far the most I have ever paid for a track day, considerably more than multiple days at Daytona, but it sure was worth it to have the runway all to yourself when it's your turn to make the runs. By all means do this if you can!
Thanks in advance
I cannot give you an exact number but I was using a little under an 1/8 of a tank on the 2.7 mile top speed runs, so about 1.8-2 gallons.
I am not aware of this restriction on my car, so no comment here.
I tried folding my mirrors on one of the Mile runs and my drivers mirror snapped back into place at about 170mph, so I left them both open the rest of the day.
My launches were all at about 3500 RPM, and on the Top Speed runs I came out normal but then accelerated at full throttle.
I use VP MS109REG, my car is tuned for it.
Check your valve stems before you run and during, I had one loosen on me at the end of the session.
Hope some of this helps.
Now, if you want to see what your car can do in 2 miles, then have at it.
A better figure would be 12-15 miles, if that. Then another 2 miles for shutdown.
Did JB have VP fuel on site or did you bring it in?
Thanks again
Unfortunately because of all the uncertainties with the Flu situation the event scheduled for May 16 has been cancelled.
They are hoping to reschedule it for early June. Once I have the dates I will post them once again.
PM me if you would like the Event Organizer's telephone number.
