Has anyone went from Z06 to Eray?
#161
in the grand scheme of things, it’s not any more “special” to anyone other than you. And I’m glad it’s special to you!
flap plane, crank, and some extra valves versus an electric motor with torque vectoring who is to say, which is more special? Not me.
And iTs just silly….. we are fortunate to have these platforms available to us to enjoy, experiment with, gets spanked by a more special plaid and continue on the quest for pleasure!!
#162
Received 2,352 Likes
C4 of Year Winner (performance mods) 2019
Delivered the very end of December, so it sat for a couple of months before I could really drive it and get it broken in. I've got 2500 miles on it now, and I absolutely love it. I've had 12 Corvettes, all gens from C4-C8 including most performance variants (and have driven all the performance variants of every gen), and the C8 Z06 is the biggest difference from a "base" (including Z51 in that) to a performance variant (GS/Z06/ZR1) that I've ever experienced. The sound and rev range from the LT6 is absolutely incredible! Yes, the car is stiff, probably at the limit of what most will find acceptable in a street car (and mine's not Z07), but it does exactly what I wanted, which is to feel like an "event" every time I drive the car. I don't know that I'd want to live with it from a daily driver (Stingray/Eray would be the choice there), but for a 3rd car, it's absolutely something special.
#163
No offense taken
Proof is in the pudding mang. There was NO hype that out hyped the awesome hype machine, the z06
I actually can't wait for a plaid version of the corvette. I'm a fan of EV's so i'm ok with that
#164
Concur with Evan's description about why I like the car so much more than my stingray, but I also concur with your 3 hour comment if the car is left in sport mode. I normally manually shift, keep the suspension in sport but the exhaust in tour except when getting on the car (e.g., back roads) when I switch to sport exhaust too. Also, on long trips, I'll switch to automatic shift, tour ride and stealth exhaust if it is a long section of interstate (>40 miles) and cruise control is on. The car is fairly wife friendly at that point. I drive a lot with the top down, so in tour I can hear the exhaust and the rage, without making people 6 blocks away know I coming when I'm in slow city traffic.
I would like to compare ride to an e-ray because on the interstate I think it is the tire noise that wears me down more than the suspension. The e-ray is a tad softer ride, but I wonder if the tire noise is reduced on the A/S. The A/S tires appeal to me for use in cooler weather and if they're quieter, that's a bonus. My C8 Z51 was surprisingly good on the highway. I noticed tire noise, but not as much as my Z06. The Z06's extra couple inches of tire width produces more noise.
#165
The PDR shows you're not high in the rpms, so your car should be broken-in enough to test the e-ray and see if you can exceed the 1.3G. It may be that you don't exceed the max G, but you should be able to come out of the corner faster with AWD. If you have enough old PDR data, you may be to measure point to point time (e.g., 300' before the turn to 800' after) and see the speed delta of the e-ray versus your stingray.
#166
GOLD72 (05-15-2024)
#167
E-Ray, 3LZ, ZER, LIFT
Received 9,682 Likes
Have made that turn many times as it's on my way back from town on back roads. But I am following what Mario Andretti said when someone asked him if he was every scared when going flat out at Indy. He said always! You start out well under max speed and each lap in testing you get your mind to accept higher speeds gradually! I'll creep up on it!
#168
Oh I have almost 1500 miles. Close to using Launch Control to see how much I can best the 2.5 seconds I have done a number of times, one with my ~190 lb cousin in the car! He has a Porsche Carrera 4S and was impressed at the acceleration at launch. Front comes up more than my prior C8 Z51.
On another note, I got the phone call to order an eRay if I still wanted it, but I decided to keep my Z06/Z07 instead. So some other lucky individual can thank me for bowing out.
Still #1 on my dealers list for the ZR1 and the Zora, if they even make one.
tadda (05-16-2024)
#169
2.5 second 0-60? Did you use the draggy, or is that time from the onboard timer? Onboard timer isnt accurate in any C8, and that includes the Z06 and Eray.
In GM's case you just subtract a fixed number for estimated rollout. I matched what Car & Driver published in their test with their V-Box, 2.5 seconds that includes 1-foot rollout. Now all I care about is the relative number with Lauch Control when I pass 1500 miles and will try. Not planning on submitting to the Gunness Book of Records so the actual number is not important. It's the delta time for changes I make is all I care about. As Einstein would say, "It's All Relative!"
