List of components, technologies, and configurations of the Mid Engined Corvette
#121
Listening to Autoline the other night it was mentioned that Cosworth has now set up in Michigan. Apparently they are making the heads to a 4.2 and 5.5 TT V8's. This is going on the List.
https://www.forbes.com/sites/samabue.../#136f129b3d8d
Shaka (09-26-2018)
#122
I think ford ran into big trouble with the flat plane crank abouve 4liters...
i dont know how gm can do a flat plane crank, turbocharge it and have the engine at 5.5 liters...vibrational issue ps with the flat plane crank firing order
the 4.2 is a long stroke engine which i think is not great for high revving...as well.
if this engnpine has a flat plane crank..i think it will be under 4liters..
all the europeans went 4liters and under with their massively powerful turbo v8s..
with dohc engines, turbos...and a flat plane crank..i dont see gm going 5.5liters...
so,ething has be take. Off the list.
probably the flat plane crank...? Or the size of the engine goes down..not up..
jmo
jmo
#123
Possible electronically actuated manual transmission for mid engine Zora. See new article below. This goes on the list.
https://jalopnik.com/gm-s-new-patent...1829177464/amp
#124
Received 4,375 Likes
jmo
jmo
Could someone explain the fascination with high rpm for a street car that does not have rule limited displacement? Higher rpm means higher stresses, and lower fuel economy. When you can get the same power at lower rpm and get better mileage, and the engine lasts longer, why the cry for unnecessarily high RPM? I get it for racing where rules limit displacement. Yes, sometimes they sound cooler. However, having competed in a open exhaust RX-7 where the noise was piercing even with ear plugs and a helmet, sometimes it is not enjoyable.
#125
Potential Hybrid Drivetrain technology as indicated in this article by Road & Track magazine on GM patent. Thread by Darion.
https://www.roadandtrack.com/new-car...o-c8-corvette/
#126
Could someone explain the physics? Seems to me limiting factors are material strengths and maximum piston speed at RPM limit. Piston speed gets limited by RPM and stroke lengths. Rod , crank, bearing materials limit the mass of piston at a given RPM. So make the bores big and the pistons lightweight.
The large size/width of the combustion chamber at ignition can cause increased inhomogeneity in the air/fuel mixture during combustion, resulting in higher emissions. Because these characteristics favor higher engine speeds, oversquare engines are tuned to develop peak torque at a relatively high speed, which again contradict turbo duties.
The reduced stroke length allows for a shorter cylinder and a shorter connecting rod, generally making oversquare engines less tall but wider than undersquare engines. The F488 is a magnificent car but it ain't cheap and you gotta stop for gas often which is bad for track days for that reason. Placing turbos on a engine layout designed for high RPMs is really stupid. High manifold pressure and Low RPMs in a a flat crank V8 causes high piston side loads. Add a turbo charger and you asking for self destruction.
There are some here who call for it in the C8. Chevy LS engines are lighter with low Cg and two valves, one cam and a very short timing chain. You don't need high RPM with two valves and you don't need 4 valves with a super/turbo charger. The LS engine costs $600 less to make than the Caddy DOHC engine. The Caddy engine is much heavier and uses more material. Actually, DOHC means direct overhead cam and not dual. That means the the tappet is in between the cam and the valve.
I want a pushrod, port injected, N/A Chevy V8 in my C8 with a manual 6 speed Xaxle. Either that or I keep my C6Z for another 10 years
#127
A cross plane crank always has one piston going down, one piston coming up, and 2 pistons at mid stroke per bank, and both banks are the same. THis is the most balanced in a mechanical sense of things. In each bank there is always some piston causing the opposite set of forces to any given piston.
A flat plane crank is essentially two 4-cylinder engines sharing a common crank shaft, and has very similar vibration characteristics. There are either 2 pistons coming up and 2 pistons going down or 4 pistons in mid stroke per bank. One can balance the FPC for the coming up and going down part, or one can balance the FPC for the mid-stroke part, but you cannot balance the thing for both (like one can with a cross plane crank).
The vibrational forces in a FPC tend to make the crankshaft into a bit of a helix shape, and when supported by the bearings, the block must be able to absorb these rapid high force events thousands of time per minute. The vibrations basically shake the block to bits, and any casting imperfection will eventually become a failure point. Aluminum castings will have imperfections, and white metals do not have a safe limit for these kinds of repetitive forces being applied.
High RPM engines with flat plane cranks have a sound akin to a V12 purr rather than off kiltered lub dub sound from a cross plane crank.
Now one can fit 180º headers to a CPC and get most of the sound of a FPC at some cost in high RPM power due to the length of the shortest pipes which cross from bank to bank. Hot-V gas flow helps a lot in enabling 180º headers. Routing 180º headers out of the engine bay of a FE car is a nightmare.
One cannot get the intake purr from a cross plane crank that one can get from the FPC, and generally all 8 cylinders draw from the same air box, whereas the FPC engines will have an air box for each bank.
Whether any of this is "of value" to the customer depends on the customer.
bebezote (11-20-2018)
#128
Thanks, Shaka and Mitch. You have confirmed I had a pretty good understanding of the issues. You have both been quite elegant. I am not a fan of high RPM for street use where displacement is constricted by regulation (like racing, or laws). I get the sound factor and have heard Formula 1 cars at 18,000 rpm scream. I am not a fan of superchargers, except in drag racing. There they reign supreme due to no lag. Since they only make about 600 rotations going down the track, even a few rotations of lag can do you in. For the street I think turbos are better due to far less loss of HP to drive the compression. There is some loss due to exhaust restriction but it pales by comparison to a supercharger. Sure there is some lag but on a road course it can usually be compensated for. I raced in amateur classes a suck through carbureted turbo small block The lag was significant and the surge was pronounce, but I got to where I could predict it.
Street cars should be about the most power, with the best economy, and least wear in combination with cost control. In short a very high bang for the buck.
I see the flat plane high RPM more of a bragging rights thing. My preference is a results for the money thing. Corvettes have excelled at that. The different levels of models (Coupe, Z06, ZR1) just do that at different price points. I think they should maintain that. I would like to see less weight rather than more power. Say 20% less weight rather than 20% more power.
Shaka (09-27-2018)
#129
Most of the track miles were spent going within 2 seconds of the class lap record at TWS, MSR-Bonney, MSR-Cresson. Class = (400 HP or less, street tires, 3200 pounds or more). Much of the time the summer temps were in the 103ºF range.
#130
Since GM has trademarked the ZORA name worldwide it"s logical that we will have both left and right hand drive. It's going on the list.
https://www.corvetteblogger.com/2018...cluding-china/
#131
I have 5,000 track miles on my F355 motor and there has been no explosion or massive wear,...(along with 69,000 total miles.) Probably 45+/- track days.
#132
There is a viable potential of all wheel drive on the higher level models of the ME ZORA since GM has trademarked Sport Control AWD. Recently Bob Lutz as well as prior Corvette Chief Engineer Dave McClellan indicated that potential as well. This is going on the list.
Shaka (09-27-2018)
#134
Flat plane crank anyone?
#135
Elegant has given us a interesting article on the new ZF Electronic "Brake By Wire" system. It's going on the List Thread.
http://gmauthority.com/blog/2018/10/...#ixzz5UmiV1IWR
Shaka (10-29-2018)
#136
I think the Vent material and color palette on the ZORA will be Matte black, Carbon Flash, Dark Grey, or body colored like the current vent ordering options of the C7 line up. We will also most likely have a higher quality Carbon Fiber option all the way up to specific right side or left side directional lay up and centerline book matched lay up where components are in the center position of the car. It only makes sense to have the same flexibility in material types and vent colors that we have now. The current ZR1 initiated the centerline book matched lay up option and it will be enhanced on the ZORA. This is going on the List.
#137
fantastic....very well describe... thank you!!
#138
headlines like this
If this is 200-250k ... and can corner.. makes it very difficult to think about a corvette..
New Tesla Roadster First Look: Zero to 60 in 1.9 Seconds, 250-MPH Top Speed, 620-Mile Range
The claimed quarter-mile time of 8.8 secondsIf this is 200-250k ... and can corner.. makes it very difficult to think about a corvette..
#139
Unless you plan on doing track days and your Telsa needs a full battery charge after only 1-2 session.
#140
