C8 General Discussion The place to discuss the next generation of Corvette.
May Car & Driver has ME on the cover...
Old 04-15-2018, 12:29 AM
  #201
IronV
IronV's Avatar
Default The mules camo
Originally Posted by FLS2K
I see what you’re saying, but that’s assuming the line we see on the mule is accurate. One job of these mules is to trick us and the rest of the industry. Time will tell what’s really under there.
The mules' camo, from C5 on, have never been so radical to create entirely different shapes.
Old 04-15-2018, 05:18 AM
  #202
blackcorvette06
blackcorvette06's Avatar
Is there a reason every render is ignoring this image of the rear fender? We haven't seen any side view CAD images, so wouldn't this be the only evidence we have? There's clearly an opening just inches from the rear wheel arch.
Here's an older spy pic for comparison.
Old 04-15-2018, 06:20 AM
  #203
gthal
gthal's Avatar
Received 1,170 Likes on 486 Posts
Originally Posted by Larshelt
Great thoughts, however I believe the como'd cars rearend is probably the actual length of rear of the car. The top como'd portion probably has extra padding underneath , but the bottom rear difusser and exhaust tips are exposed, showing the approximate end of the rear cap of the car. I know nothing is in stone but I think FVS has most of the car fairly close and the C&D rendering just makes the look chunky and bloated.
I suspect you are right but hope you are wrong... the camo'd cars are just SO long in appearance. If you look at the comparison above of the Acura, Lambo and Ferrari, the shorter C&D version is more on scale. If the car is as long as the camo cars, I fear it will look like a stretched limo.
Old 04-15-2018, 09:57 AM
  #204
firstvettesoon
firstvettesoon's Avatar
Received 1,906 Likes on 750 Posts
There actually is a cad image of the rear three-quarter view. See below.
There seems to be a definite wraparound to that area you are referring to but not very much. I show it in the side views but it seems to be slight. The cad image does not indicate that the vent wraps around the side very much
Old 04-15-2018, 10:08 AM
  #205
blackcorvette06
Sorry I didn't make myself clear. I was referring to black rear fender with the blue arrow sitting next to the rear fascia.
Old 04-15-2018, 12:02 PM
  #206
firstvettesoon
I see, thanks. I’ll try to enhance the image and see if we can see anything
Old 04-15-2018, 12:06 PM
  #207
vettedna
vettedna's Avatar
guys, what about this?
Old 04-15-2018, 12:15 PM
  #208
0HUBBELL RACING
Former Vendor
HUBBELL RACING's Avatar
Side rear view looks like a KIA
top of rear fender too thick, looks like baby w dirty diaper. Ferrari rear profile much much better.
lets hope real car looks better
Old 04-15-2018, 12:55 PM
  #209
Shaka
Shaka's Avatar
Received 1,331 Likes on 790 Posts
Front fenders.
Old 04-15-2018, 02:47 PM
  #210
IronV
IronV's Avatar
Default Foam is not stable
Having said that, that would be A LOT of foam stuck on the nose. Would think that would be a problem at speed.
I suspect there is no foam per se, just heavily padded wrap.
Old 04-15-2018, 04:39 PM
  #211
TRT SR
TRT SR's Avatar
Please GM, don't copy Ferrari with the headlights, hope the renderings are wrong. Love the cars but the mid engine needs to stand out from the crowd.
Old 04-15-2018, 04:41 PM
  #212
JerriVette
JerriVette's Avatar
Received 3,947 Likes on 2,177 Posts
AS the corvette moves to rear mid engine the camaro can leave retro behind and copy something similiar to the portifino...now that would be cool
Old 04-15-2018, 06:55 PM
  #213
NY09C6
NY09C6's Avatar
This is also likely the base car. The Z06 and ZR1 variants will likely look more exotic/aggressive.
Old 04-15-2018, 07:19 PM
  #214
0HUBBELL RACING
Former Vendor
Corvette should take from it’s own design history.
Corvette has an excellent design history.
why are there NO gills on the car?
yes the C6DP is a race car but Chevy really needs to improve the rear 1/4 styling. Not as aggressive as the DP but a lot more aggressive than this rendering
The C8 front end is very nice. The rear quarter over the wheel is the mess. It should look a lot more like the C6 DP. I see no reason for that large flat mass over rear wheels. Looks like was designed by LITTLE TYKES & just Mamés rear tire look smaller than front
ArmchairArchitect (04-16-2018)
Old 04-15-2018, 07:23 PM
  #215
IronV
IronV's Avatar
Default I applaud the optimism, but
There's no substantive difference in design form between the higher performance Vettes and the base model. If the base model is a styling success, the uprated versions will be as well. But ground effects, scoops and racing stripes can't fix bad design.
Old 04-15-2018, 07:56 PM
  #216
NY09C6
NY09C6's Avatar
Well, I personally feel my base model c6 is a bland as you get. I think the z06 and zr1 cars are 10x better looking.
Old 04-15-2018, 08:09 PM
  #217
JerriVette
JerriVette's Avatar
Fwiw...i digi my standard black c6 z51 m6...
I suggest c7 z51 black 19/20 inch rims to create a more contemporary look from your c6.
If you still feel your c6 is bland...then selling would serve you well.
To May Car & Driver has ME on the cover...
Old 04-15-2018, 08:58 PM
  #218
NY09C6
NY09C6's Avatar
I have no desire to sell it until the c8 zo6 model hits discount status. Looks alone is not why I buy cars. My point was only that there is a significant appearance difference from the base model to upper end models on recent Corvette models. Everyone is expecting supercar looks from a 70k car. That is not realistic. You will get closer on the 90k z06 versions.
Old 04-15-2018, 09:44 PM
  #219
JerriVette
JerriVette's Avatar
It ll be interesting to see the first release of the standard rear mid engine and then how the vehicle is differiated to signal the higher performance models.
Old 04-15-2018, 10:40 PM
  #220
z06inVB
z06inVB's Avatar
Received 1,106 Likes on 520 Posts
I think the rendering is awesome. I might even consider trading in my base C6 on one and that’s saying something because as we all know the base C6 up to now is the pinnacle of Corvette design 😈
Quick Reply: May Car & Driver has ME on the cover...
