C8 General Discussion The place to discuss the next generation of Corvette.
Newest “in the wild” spy shots!
Old 05-16-2018, 06:35 PM
f-16pilotTX
f-16pilotTX's Avatar
Default Newest “in the wild” spy shots!
https://www.autoblog.com/2018/05/16/...#slide-7333430
Here is the link, let’s discuss?
-Flat top steering wheel
-Bustress
-Active aero?
-Sexiness?
I also noticed the headlights seem more “production” style then the previous spy shots.
I truely hope they start taking off more Camo because we have been seeing the same thing and basically dissected the best we can with what we have. I don’t know why the article mentions “might be pushed to 2020”, that would suck!
cheers
The following 6 users liked this post by f-16pilotTX:
elegant (05-18-2018), firstvettesoon (05-16-2018), GundamX7X (05-18-2018), pdpratt (05-17-2018), sunsalem (05-17-2018), tbrenny33 (05-16-2018) and 1 others liked this post. (Show less...)
Old 05-16-2018, 07:37 PM
tbrenny33
tbrenny33's Avatar
Like the look of steering wheel, and they sure does appear to be active areo! At least I hope so.
Old 05-16-2018, 07:38 PM
OnPoint
The Consigliere
Support Corvetteforum!
OnPoint's Avatar
Received 5,447 Likes on 2,272 Posts
Looks like it's just an air bubble under the camo tarp to me.
Old 05-16-2018, 07:43 PM
tbrenny33
tbrenny33's Avatar
It could be, I thought that at first but noticed it’s in several different photos at different angles as well. Also it’s odd we’ve never seen this “air bubble” before.
Old 05-16-2018, 07:57 PM
firstvettesoon
firstvettesoon's Avatar
Received 1,906 Likes on 750 Posts
There is also a few side images, right side, that seem to show the side scoop in the door being sucked in and a rear tilted anglee ridge toward the front of the door that may be an air exit from the front wheel wells.
I know many other cars have similar features and I have suggested this in the past but this is the first view of the door being sucked in deeper than the black tarp. Could just be padding but maybe?
Old 05-16-2018, 08:00 PM
Quinten33
Quinten33's Avatar
In the later pictures of that autoblog gallery, there’s the same semi-circle shape on the rear deck where an active spoiler would reside on something like a 650S. In the first few images, the top of the raised rear cover appears to have a similar curve to the aforementioned semi-circle piece. This could easily be a coincidence, and it’s the only instance where something like this has been seen.
Old 05-16-2018, 08:03 PM
Jerradl1987
Jerradl1987's Avatar
Default 2nd bumper option
And as I stated before this bumper was the one that was different than the BG factory spy picture!
https://www.corvetteforum.com/forums...ption-2-a.html
Old 05-16-2018, 08:37 PM
Quinten33
Quinten33's Avatar
It’s obvious that the rear deck is vented in some of these shots, as stated by GM Authority
Old 05-16-2018, 09:09 PM
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
What we now know is that every render showing the car as a "fastback" (Ferrari 458/488 for example) is wrong. Look at pictures 7/8/10/26 among others. The engine cowl is obviously flat and the car has buttresses. I was going to guess that maybe it is a convertible but the B pillar is too pronounced for that.
EDIT: After Bikerjulio posted the top function on the 458 Spyder....maybe it is a convertible
Old 05-16-2018, 09:25 PM
Bikerjulio
Bikerjulio's Avatar
This thread is duplicating another with the same link. You are correct in saying that no spy shots yet have shown a fastback window, only a vertical rear window and buttresses. The B pillar is consistent with the Ferrari spyder. The spy images show a hardtop convertible with similar seams to the Ferrari.
The following 3 users liked this post by Bikerjulio:
GundamX7X (05-18-2018), RapidC84B (05-17-2018), RedDropTop (05-16-2018)
Old 05-16-2018, 09:29 PM
FLS2K
FLS2K's Avatar
The sill design is now clear, and appears to be a match to the CADs. Also, if it wasn’t already confirmed, the leading edge of the side scoops are certainly part of the doors.
Old 05-16-2018, 10:07 PM
firstvettesoon
this could just be padding but "could" be a front wheel-well air channel...
Note the "deep" sucked in area in the door. First time seeing this too!
Crabr1 (05-27-2018)
Old 05-16-2018, 10:46 PM
elegant
elegant's Avatar
Received 2,680 Likes on 1,231 Posts
Yes, it could. It would perfectly echo the spy pic’s camo. Well done. However, while it is possible, it is lacking, IMO, in style points. It chops up the side, and if I might, makes it look a lot less “elegant.”
Here is your earlier rendering without that front wheel air channel. Much more visually attractive to me.
tbrenny33 (05-17-2018)
Old 05-16-2018, 11:05 PM
firstvettesoon
^^ I agree, just trying to show the door difference and depth that the tarp covers. The actual opening would be much more refined if it is there at all.
Interesting...
Old 05-16-2018, 11:12 PM
Medrivfast
Medrivfast's Avatar
Dual brake calipers in the rear
Old 05-16-2018, 11:19 PM
elegant
elegant's Avatar
Today’s picture reinforces what you suggested a few weeks ago FVS, that the fender intake duct could be vertically split, as follows:
I am seeing the top of the “zebra-camo’d triangle” as a dividing line in a vertically-split intake duct (which is present on some other ME’s), with two different chambers providing air for different functions. That picture is at the bottom of this post.
Here are some options for air use with that split intake duct:
*the lower one to a heat exchanger — such as an intercooler air inlet;
*the upper one being for engine air intake;
* the upper one being part of a system Ferrari calls a “base air bleed aero system to reduce drag” (with that air exiting the car in the vents just below the taillights — just as we have seen air ducts below the ME’s taillights.
All picture shown below come from this Ferrari 488 GTB Aero video:
And if one chamber is venting directly to the rear of the car, we have seen “air exiting ducts” on the Corvette ME’s taillights which would be that air’s exhaust point.
firstvettesoon (05-17-2018)
Old 05-16-2018, 11:20 PM
jimmyb
jimmyb's Avatar
Parking brake.
To Newest “in the wild” spy shots!
Old 05-16-2018, 11:35 PM
MikeG37
MikeG37's Avatar
Parking brake.
Been discussed
Old 05-16-2018, 11:58 PM
Apocolipse
Apocolipse's Avatar
Received 1,284 Likes on 929 Posts
GM always copying Ferrari...classic
StancyPants (05-18-2018)
Old 05-17-2018, 05:36 AM
nexxis
nexxis's Avatar
GM is messing with us. Obvious they keep removing coverings little by little. Last spy shots had tons of padding and rear looked clunky. These proportions are SEEEXXXYYY
Also noticed 4 giant distinct ducts. And side scoop looks like a straight horizontal line within where the door would be. All the renderings have been off!
Quick Reply: Newest “in the wild” spy shots!
