Corvette Acceleration Testing [Video]
It also lends credence to the theory that this is a Spyder. The vinyl cover collapses over the back window when the driver applies the brakes. The cavity fills with air by the time he shifts for the second time. It becomes a little obvious on the 3rd run.
I was watching the fabric covering the back window. In all three runs it behaved the same way.
As the car comes to rest, the fabric is resting on a flat surface between the two buttresses. (c pillars)
As the car accelerates, the fabric inflates with the slip stream.
So, these cars either have a rear window like the C7 or there's a hard piece of body camo fixed to the body underneath the fabric camo.
sunsalem (06-21-2018)
StancyPants (06-21-2018)
I read that as simply a taught vinyl cover. Not one sitting on top of a window. It may also have some solid membrane to eliminate it completely exposing the cavity below the area.
Miles of Smiles
2016 C5 of the Year Finalist
No, these are not full throttle launches. These are relatively slow, mild launches. Launching hard and running up thru the tach aggressively does not result in 3 shifts before 60 mph, all three of which executed in the lower half of the rpm range.
These launches are pretty mundane.
These mild launches may depict a more "normal" acceleration condition versus (as you stated) an all out 0 to 60 (red line) testing.
Nonetheless, exciting to see/hear more!
I did mention the signs...
May be harder to estimate the correct line as the car crosses the 0.1-0.2 signs due to perspective.
The lines "should be standard 40 foot spacing. 10 foot line- 30 foot space. and the car in right on top of them. Easier to count.
My initial calculations are an abysmal 0-60 - 5.8- 6.2 sec!
I know theses are not full on speed tests...right...
To be competitive, the car would need to be at 60mph by the time it crossed the yellow sign...more or less.
I keep watching the video.
Progress is happening...
I like the “stance” of the car, it’s front down, rear up rake. This was taken after it had come to a stop, was totally settled at rest.
Miles of Smiles
Originally Posted by Dpriceslc
What's the point of changing lanes during acceleration testing?
That or the driver is just overly courteous (signaling to change lanes)!
#33
Ha...Sorry for the confusion...I was referring to the first yellow sign saying "Stops allowed Right and Center lanes" ! Only about 120 feet from start I am guessing.
FVS, how'd you get that calculation? If the 0.1, 0.2, etc. markers are indeed mile markers (which I think they are) then the yellow sign after the 0.1 sign would be the 1/8th mile marker (which it appears it is as it reads 0.125, see below screenshot). From timing it on my phone it appears to be making 1/8th mile passes in the ~6.5-7s range, which is extremely fast. Anyone with better timing equipment/video software can time how this bad boy is accelerating?
#35
#37
First run. 6.3 sec to 1/10 mile marker. So I guess it's close to your 1/8 mile estimate of 6.6sec av.
of course only rough due to perspective etc.
NewYuriCity (06-21-2018)
#38
No worries dude I was curious where you got your 0-60 calculation from, because based on the mile markers he's flying. we can't really tell fully because it cuts out before he hits the 1/4 mile marker but based on 6.5-7s 1/8th mile times that should be less than 11s in the 1/4 mile! For reference, a ZR1 that did a 10.1 1/4 mile pass did the 1/8th in 6.53s
#40
Who else is on go slow at work after watching this?
