The ME might have an adaptive instrument cluster
Received 9,515 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Read the full article here:
http://www.corvetteblogger.com/2018/...ument-cluster/
From CorvetteBlogger.com
Earlier this week we learned of several new patents awarded to GM for adaptive aerodynamic technologies that may be headed to future models of the Corvette. From that deep dive in the USPTO, we also learned of a new patent application being sought by the automaker which also may have some applications in future Corvette models as well.
The patent application from GM is titled Adaptive Instrument Cluster and again the drawings for the application show the dash of the C7 Corvette.
According to the patent document, the electronic dash displays that include the speedometer, tachometer, coolant and oil temperatures and other data on an automobile’s instrument cluster are designed to be viewable through an opening in the steering wheel. However, that data can be obscured up to 50% as the driver turns the steering wheel.
An Adaptive Instrument Cluster is designed so that key information from the instruments are repositioned on the electronic display as the driver turns the steering wheel, thereby keeping some the data from the dash viewable within the steering wheel’s opening.
The patent application says that during normal driving, the turning of the steering wheel can briefly obscure the instrument cluster. However, during performance driving activities such as high-performance driving education (HPDE), the viewing of data is more important to the driver. The application also states an adaptive display would have use in autonomous vehicle operations where the information needs to be viewable by the operator under all conditions.
The Adaptive Instrument Cluster is said to have a controller that monitors the angle of the steering wheel and then repositions the instruments on the electronic display so that at least one instrument remains viewable within an opening formed within the steering wheel.
The three illustrations below shows the electronic display through the steering wheel as represented by an oval. As the steering wheel is turned to the left, the instruments also shift to the left and are oriented so that it still displays the key information through the steering wheel opening. Finally, the third drawing shows an extreme steering wheel angle with the dash display is repositioned to show through two different openings in the steering wheel.
elegant (08-16-2018)
Cautrell05 (08-20-2018)
Bad idea... as a racer myself you learn the locations of your key data and it becomes muscle memory to check at certain times/places on track, in the turns are not where I'm looking anyway. If the data is moving around it will be hard to track.
Its one one of my complaints with the variable display on the C7. The redline moves depending on drive mode and it makes muscle memory drag racing harder for me... in a C5 I know exactly where to glance down. Yes I know you can fix it for one display in all drive modes.
firstvettesoon (08-16-2018)
The following 2 users liked this post by NY09C6:
Cautrell05 (08-20-2018),
I’m sure that GM will allow the feature to be disabled under the cluster settings
Personally, I like my display to stay in place. As devil's advocate though, this reminds me of an F1 steering wheel. Except more technological and "pretty" for road use. The dash info is on the steering wheel for an F1 driver. However, I believe F1 places it there because there really isnt much material to put a dash behind the steering wheel. Probably not necessarily advantageous being on the moving steering wheel.
A very strange concept here.
with the thread consensus. It's silly. You shouldn't be looking at the IP mid corner anyway.
Put the instrument cluster IN the steering wheel. Problem solved.
That's what I was thinking too. Not sure I'd like the dynamic display in the IPC - seems that as the data moved around, that movement might catch my eye and cause a momentary distraction. However, the competitive professional driver would most likely become acclimated.
Putting it in the middle of the steering wheel is just the most efficient way to go.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
It could be a leap forward, a real innovation. For me, I had to get used to HUD. Wasn't always looking at the display. It finally happened, slowly. Numbers and icons moving around tho could be disconcerting for some, or distracting.
As to putting it in the steering wheel a la F1, that was necessity-driven. The farther my eyes flicker from the windshield, the worse it is for me. Again, this is just me---F1 drivers have far quicker reflexes than most drivers.
I agree (especially about HUD). I got a 2017 SS a few months ago (wife's car) and she HATES HUD...cuts it off every time she drives.
I'll be the contrarian here. I think it could be helpful. I'm open to new ideas. I'd have to try it out. I am tired of the tachometer being blocked by the steering wheel when it is turned, which can be a good portion of the time.
I love my HUD (just wish it had turn signals in it) and I'm not really interested in this idea at all. I don't want things moving around on my IP. If I were given a choice of this technology or Blind side/Cross Traffic....I would choose Blind Side/Cross Traffic a 100 to 1 over a gauge cluster that moved.
Received 8,928 Likes
Bill
ByByBMW (08-18-2018)
