chazcron's 3D model work in progress
#61
This part will be black trim in carbon fiber weave is my guess or painted black.
#62
Zaro Tundov (11-01-2018)
#63
It's my opinion that the Pacman-shaped side scoop is a ruse. The reason I say that is because of the very thin inlet wall on the lower jaw portion of the Pacman side scoop. The upper jaw portion is substantially thicker. This is true for both the C8 and C8-R.
I superimposed onto the shots below of the C8-R the same scoop I traced from the May 2018 images. I did not alter the outline in any way other than to proportionally scale it, then rotate it to fit with the body lines shown in the photo of the car.
Zaro Tundov (10-26-2018)
#64
#65
chazcron, you are an amazing talent. I love what you are doing. Take all the artistic license you wish, for other than GM, none of us definitively know what the scoop is going to look like. What you have is really good looking.
Thank you very much!
I look forward to your work in progress continuing.
#66
So you you do not think the triangular lip on the door is real?
i understand your reasoning but the thin fake panel over the scoop starts at the top of the door edge and follows the general shape of the door cut out down toward the rocker.
The c8r V shape continues back from the top door edge as seen in some camo images at the same general angle as the V shaped c8R. Where it changes direction and ends is not known but your suggestied shape would mean the triangular piece on the door is fake even tho the image of the guy opening the door from under the lip suggests it it not.
It could be faked of course as could the rear fenders but would they test the car with very fake wrong panels?
As as I said above, the styling cues for the c8 seem to be sharp and angular. I can’t see how a roundish scoop will play into it but time will tell.
#67
#68
This is really rough, probably not worth posting, requires a lot of imagination and you'll probably all hate it, but this is the first stand-alone render, hacked with photoshop. Remember, this is a "WORK IN PROGRESS" thread. (And get used to these placeholder wheels.) Only the roof is new, the rest is just clumsily hinted and not scaled out yet.
The following 7 users liked this post by chazcron:
dcbingaman (01-11-2019),
dsword (03-10-2019),
elegant (10-27-2018),
NAH801 (10-29-2018),
RedDropTop (10-25-2018),
and 2 others liked this post.
#70
I really think you're on to it. Getting the hood right, getting the inside of the headlights right (drl) are going to be the real challenges I think. Great work so far!
#72
I say this mainly because of how the upper and lower portions of the scoop transitions the thickness of the inlet lip.
The upper portion is thick, then tapers sharply to a thin lip on the triangular piece, then widens out to a thick lip once it merges back into the body at the bottom of of the scoop.
I agree. We will only see what the car really looks like once GM decides it's time.
#73
Yes, I agree. Compared to the placement of the street car, the outlines on the racer are slightly aft of where they really should be. I just placed the outline in the general area to see how it fit.
#74
#75
CorvetteBrando: I do appreciate and agree with your analysis and detailed observations. If you look close I think I took all of these into consideration and addressed them in these renders. The only difference is the angles and perspective IMO.
Where the scoop goes after it disappears under the camo panel is a mystery but here are 3 possible versions.
#76
So many posts state that this panel is a fake, that that one is going to be changed later so that the revealed car will look very different from what we are seeing in our renderings.
Think of the cost of flying four ME’s to Nurburgring, probably a crew of 20-30, and spending days testing on the track. Many posts thing that GM was testing with deliverable inaccurate body panels.
Do we not think that inaccurate body panels would invalid much, most or all the test data learned from NRing?
GM has several employees who best job title could be “Masters of Disguise,” so skilled that while we believe we are now seeing just a single layer vinyl skin covering key parts of the car,, we are going to be mightily surprise at the reveal, e.g., how much is underneath the supposed single skin vinyl.
Video of GM disguise program for the current Camaro.
The following 2 users liked this post by elegant:
firstvettesoon (10-26-2018),
WetMountainMan (12-12-2018)
#77
ZishanM (10-27-2018)
#78
LuisZ51 (07-11-2019)
#79
Agree fully.
#80
Zaro Tundov (10-27-2018)
