Updated 3D renders from bdsvavars
#61
+1. Agreed. The render in Post #1 looks like a hideous 4 x 4 Corvette with all that ground clearance. The rendering skills is not the problem. It's the overall look. I certainly hope GM pulls their head out of their *** for this new C8.
#62
I don’t think the renderings show anymore or less ground clearance in the actual camo car or many other mid engine cars for that matter. No, it’s not slammed on the ground, but it’s not supposed to be. In my opinion, it will be as low as the current c7 s.
The renderings are actually very close to the true sizes and proportions of the car. The original version was missing some of the finer details and correct body lines and contours exact shape of headlights and tail lights etc. but I believe his next renderings will be extremely accurate.... at least for the details that we know, or think we know.
I am looking forward to seeing them soon. !
in my opinion, from the work of BDS and Chazcron in 3-D modeling, we are beginning to see the basic form of the car better, spatially. We are starting to see it from different angles where the character of the car begins to show. The stance and posture .
The beauty of 3-D models his that they will be able to correct for the camera distortion and positioning and will be able to place the model in a 3-D environment with actual reference points so we can get a true idea of its size, height and stance.
The finer details and trim will likely remain a mystery until the car is revealed. trim details can change the entire character of the car by accentuating certain features and tying elements together. All of these models and renderings are giving us an idea of what the basic form of the car will be not the ultimate visual impact We still need to use our imaginations and assume that GM has done their job. I would take these renderings and multiply by 10 and that would be my expectation of the final product.
looking forward to it.
Foosh (11-25-2018)
#63
all the other race cars since the C5.
#64
I think that scoop shape we see under the camo, is the actual ducting system made to be removable for experimental purposes. F1 teams spend millions just on their airboxes. Slight variations have dramatic affects. The engine intake N/A or turbo needs specialized shaping both at the compressor and the plenum. To cool coolant and lubricants take different varying velocities. There is a lot of work going on in this area.
The following 2 users liked this post by Shaka:
elegant (12-08-2018),
firstvettesoon (11-25-2018)
#65
As someone mentioned, the camera distortions don't affect other cars. I don't see any redeeming features on this car other than the race car. I perform major surgery on all your renders to make the design acceptable to my eyes, but it still fails to impress. We will see pretty soon. That scoop is what I look forward to the most. Maybe Pratt and Miller's CFD files will be available like they were on
I also agree that the camouflage car photographs look a little plain Jane in comparison to the Ferraris in McLarens in Lamborghinis but I believe that is mostly due to us not seeing some of the more dramatic styling queues and trim.
as you say and many others say, the side scoop is a defining feature and will need to be treated first for performance and then for styling but the styling had better be killer.!
I do not think we have nailed the side Scoop /rear fender design exactly yet. I feel it is in the ballpark but not accurate. Many of the variations we have tried simply do not look very good or natural. I do not think the rounded Cove scoop suggested looks good either and would be surprised if it was that design although many of the Maclaren side intake designs are not attractive either IMO.
I feel it will need to be sharp and angular to fit with the rest of the features that we can see. Perhaps it will be similar to the McLaren 650 S FAB which seems to have the same general shape and position and also includes a panel in front of the rear wheel which could explain the holes seen in the CAD drawing ?
#66
I agree with you to the point about the camera distortion. The main difference I believe is that other cars we see with camouflage are recognizable/known Car’s such as the Ferrari 488 and Lamborghinis. They are also more dramatic looking vehicles. I believe there is still some slight padding camouflage on the cars to hide specific details which will change the overall look. I don’t think we can expect the Corvette to be super exotic looking car. It will likely look like a cross between a mid engine McLaren or Ferrari and a C7. It needs to retain it’s corvette heritage look and styling queues and B brought forward into the mid engine platform.
#68
#69
Former Vendor
Great skills OP!
I have a feeling the actual car would have similar styling cues but far more attractive than all the renderings because from all we've seen so far if the car looks anything like the renderings and assumptions then the car will be FAR from stunning or attractive IMO. Specially the rear-end (which looks like sh*t) and the side scoops.
None of the renderings so far are attractive enough to be called a Corvette. Hopefully the real car will be more like the C8R than any of the renderings so far.
Now *this* looks MUCH better:
The following 7 users liked this post by bdsvavars:
ACCHRM (11-28-2018),
chazcron (11-29-2018),
elegant (11-29-2018),
firstvettesoon (11-28-2018),
kingpin111 (11-29-2018),
and 2 others liked this post.
#71
The following 2 users liked this post by ACCHRM:
Shaka (11-29-2018)
bdsvavars (11-29-2018)
#73
Excellent work bdsvavars. That is an exciting car you have rendered, and the way you have taken a known C8 IVERS and shown us how your rendering excactly matches up, is very exciting.
Thank you very much!.
#74
Excellent. At last a scoop that works. Can be changed to a wider intake for the higher HP versions. The rear quarter may be the same for all C8s and the wider wheels required for the HP car may receive a larger positive offset. Remember the 11" wheels on the C4 ZR1? Well, the 96 Grand Sport also had 11" wheels at the rear with a stock body. The GS handled a lot better with that geometry with the greater pos. offset keeping the track the same front to rear.
#75
I am a supporting vendor on the Corvette Forum so I need to be real careful not to offend anyone, but I agree completely with you. It is butt-ugly in those renderings. It looks like some kind of stretched Toyota Celica wannabe super car. Ugh!
The following 6 users liked this post by Speednet:
bdsvavars (11-29-2018),
dreamr616 (11-30-2018),
jcsperson (11-29-2018),
JockItch (04-23-2019),
Natrlone93 (11-30-2018),
and 1 others liked this post.
#76
If they keep the price under $100k it will destroy them
#78
Thanks so much bdsvavars. New screen savers!!!
#79
I completely agree, if it looks like the Automobilemag.com rendering my checkbook is open. GM will have a major hit and will finally give the Euro exotics serious competition.
#80
The automobile mag one is just a paint shopped NSX... looks like ****, nothing "Corvette" about it.
