The Mid-Engine Corvette's Hatch Has a Unique Design to Aid Cooling
Looks like a glass for the engine compartment...
http://pdfaiw.uspto.gov/.aiw?PageNum...Bengine%252522
not necessarily. Still need glass to see thru the vertical rear window inside. I doubt we will be able to see the engine. It may be like the 720
Judging by the pics, I think the glass window will be fixed and you can see through to the engine. You can open the whole rear hatch, to actually get to the engine. And also judging by the rear overhang, when you open the hatch there may be an additional storage area behind the engine at the rear of the car, in addition to the front trunk.
could begin.
If the rear window is as depicted, then what about the retractable hardtop version of the mid engine car? Where does that large piece of glass go when the top is folded into the rear storage compartment just behind the passenger compartment?
How do the built in vents operate when the top is down?
The last photo posted is of a convertible on the Ring. The blacked out “glass” is filler for the buttressed area where the top will fold and stow away. You can see a central vent at the bottom of the blacked out panel where the engine bay will release heat. Look at a McLaren 675LT Spider for reference.
One thing I have wondered about the hatch. Could it be a hatch within a hatch? You have the big hatch for engine maintenance and trunk access. That rear window has lots of seams/lines, could it open separately for basic engine service? Just a thought.
The following 2 users liked this post by Tom73:
firstvettesoon (12-06-2018),
MikeG37 (12-07-2018)
I look at it a bit differently. In the photo below, the Red line on the right would be approx for the passenger compartment bulkhead, same as in yours. The red line on the left is the centerline for the transaxle based on the center if the hub. Yellow is an approximation of the engine/transaxle assembly. That leaves blue as an estimation of trunk area. (As drawn bay a 3 year old with no drawing aptitude ). Lots of room above and behind the transaxle for storage.
(note the exhaust tips on zerv’s leaked CAD’s)
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
All pointed out as a possibility back in Sept. 2018 here.
https://www.corvetteforum.com/forums...post1597956321
As to the A-D markings on the upper right corner Fiero trunk picture it references how the outer sides of the trunk are shallow (C & D) with a center section width (A & B) that is much deeper. The shallow areas to accommodate the exhaust pipe routing out either side of the rear facia.
#37
I can absolutely see the C8 having a visible engine under that glass AND some type of storage at the rear. The spy photo at the Ring shows the entire rear hatch opening, similar to a Ferrari F50. Maybe they’ve included a trunk to access similar to the old and new NSX, and the entire piece lifts to reveal all, while the storage would be sealed off from the engine bay, which vents through the special hatch. This along with behind the seat storage and a frunk would give the owner the best of all worlds.
#38
I hope it's not a sea of plastic under that clear glass.
#39
#40
Is there any reason to think that the black plastic cover over the engine is the shape of the actual glass? Seem like it would be easy to put the plastic cover there to hide the engine and a bunch of tape around it to hide the real shape of the glass. What if the below is the shape of the rear glass. Would be consistent with the B pillar and glass on the C4, C5, and C6.
