Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C8 Corvette > C8 General Discussion
Reload this Page >
GM Authority: C8 Delayed 6 Months Over Electrical Issue
C8 General Discussion The place to discuss the next generation of Corvette, be it mid-engine, Zora, or whatever form it may take.
Old 12-13-2018, 08:06 AM
  #61
CRABBYJ
CF Senior Member
CRABBYJ's Avatar
2018 C7 of Year Finalist
Originally Posted by ojm View Post
The head of GM research and development Eddy Current phd is not doing anymore interviews.
More likely it’s this guy.
CRABBYJ is offline
The following 2 users liked this post by CRABBYJ:
Maxie2U (12-14-2018), ojm (12-13-2018)
Old 12-13-2018, 08:13 AM
  #62
638HP
CF Senior Member
Come on ladies and gentlemen, how different can a C8 electrical system be than a C7 system? Not like the C8 will be landing on Mars. Appears to me to be delays to absorb C7 inventories on the ground.
638HP is offline
The following 2 users liked this post by 638HP:
ojm (12-13-2018), Z51VetteFan (12-14-2018)
Old 12-13-2018, 08:17 AM
  #63
PurpleLion
CF Senior Member
Electrical power requirements have been dropping over the years. Modern digital circuits require lower voltages and consume less amps. So, even though modern cars have more electronic components, they have not added much to the electrical load. Minor exceptions might be servo motors to change shock settings (orifice based), change ride height, etc. As mentioned previously, the big gotcha would be the impact of the wiring to support hybrid operation.
Since the hybrid version of the Corvette is years away, I would hope that they would use a separate or an additional wiring harness for it. My guess would be that that the control signals for hybrid operation would be integrated into the current buss structure; whereas, the heavier gauge wiring for the battery / motor connections would be separate.
PurpleLion is online now
dcbingaman (12-14-2018)
Old 12-13-2018, 08:28 AM
  #64
AT T 2D
CF Senior Member
AT T 2D's Avatar
Originally Posted by firstvettesoon View Post
Load is a basic engineering exercise. Not like the engineers as guessing at the requirements.
Hard to believe they could undershoot it so far as to cause any delay......
Just my .02 cents.... I can understand that load should be a basic engineering function. Shouldn't cooling needs be similar? We are in year 5 of the Z06 and from what I understand there continue to be issues tracking a "track car" with the optional automatic when it is hot outside. Or the cost equation of putting wheels on it that won't frequently crack and bend. Much like how hard can it be to find a glue that keeps the leather from peeling off the dash that has been happening since the C6. My faith in GM to do the right thing is much lower now than it was when I bought my first new GM car in '84. I believe GM has some of the best engineers around and can easily fix the above issues if they chose to, but it comes down to a cost equation of how much it will cost them during the warranty period vs cost to keep the problem from happening in the first place.
I hope they begin to look a little closer at customer experience and risk to their brand reputation.
AT T 2D is offline
The following 5 users liked this post by AT T 2D:
ByByBMW (12-13-2018), firstvettesoon (12-13-2018), ShagVette (12-13-2018), Viper (12-13-2018), vndkshn (12-13-2018)
Old 12-13-2018, 09:00 AM
  #65
NoOne
CF Senior Member
NoOne's Avatar
Originally Posted by Vette_Pilot View Post
Maybe with all of the digital goodies instead of analog goodies is too much for the 12 volt system to handle!!!
That is why most cars are moving to a 48V system.
They design to what they think they need, then they test.
Most car programs have a big oops missed in the design. All the work is done in CAD with simulations for everything. Then they build the car. Things show up when the car is moved to different environments that do not show up in simulation or even initial testing.
The last Liberty/Nitro was designed to use a composite horse collar instead of a metal one. All the simulation said it would work. Prototypes built here in Michigan in the winter passed testing with flying colors. Then they took them to the desert and it turned into a limp noodle in thge heat. The whole car was designed, it was done and the fix was ridiculous.
NoOne is offline
Cubby558 (12-13-2018)
Old 12-13-2018, 09:20 AM
  #66
savage99ss
Junior Member
Someone nailed it earlier. It's a hybrid component that is malfunctioning.
savage99ss is offline
Old 12-13-2018, 09:30 AM
  #67
pietro c7
CF Senior Member
pietro c7's Avatar
Originally Posted by Jeff Wisener View Post
^^^ If GM's motivation was to leak a delay to get those on the fence to buy a C7 to reduce existing stock rather than wait for the ME, it worked in your case.
My C7 was my dealers first allocation in 2013,I reserved it in 2012.
Same with the C8...I’m getting his first allocation.
I,personally, don’t like buying a car model that’s about to change generation.
We all see value differently .
pietro c7 is offline
Old 12-13-2018, 09:39 AM
  #68
JerryU
2017 GS, M7, 2.5LT
Support Corvetteforum!
JerryU's Avatar
Received 2,836 Likes on 2,076 Posts
My "guess" is they have implemented Start/Stop which requires and electric water pump and other issues. May even have tried to implement what we have in the wife's BMW SUV a simple form of braking energy recovery that only charges the battery when braking or coasting. The BMW has an additional AMG battery that is used with that system. In her prior X5 SUV there was a recall an they replaced that battery with a higher capacity AMG because of unanticipated use issues! Of interest they use the two 12 volt batteries in series for the electric steering to cut the peak current draw in half. The Vette can use >100 amps in peak transient current.
Just my speculation that something other than normal electrical issues caused the problem. Don't think they could have used an F1 KERS type system just yet!
JerryU is offline
Old 12-13-2018, 09:43 AM
  #69
Shaka
CF Senior Member
Shaka's Avatar
Originally Posted by PurpleLion View Post
Electrical power requirements have been dropping over the years. Modern digital circuits require lower voltages and consume less amps. So, even though modern cars have more electronic components, they have not added much to the electrical load. Minor exceptions might be servo motors to change shock settings (orifice based) , change ride height, etc. As mentioned previously, the big gotcha would be the impact of the wiring to support hybrid operation.
Yeah, but there are other systems such as electric motor power steering, air, stop start systems, turbo anti lag motors, etc. that could use a separate 48v system, GM has close ties with German companies and the major one is Siemans. GM uses their NX Soft ware systems and probably investigating their 2 tier voltage auto systems like they did with ZF. .Battery technology is the biggest obstacle. Lead acid is very stable but heavy.
In 96, the introductory paper "Bordnetzarchitektur im Jahr 2005" (Automotive electrical system architecture for the year 2005) was agreed, and on June 4, 1996, BMW presented the "Tabelle heutiger und zukünftiger Verbraucher im Kfz" (Table of present and future loads in the motor vehicle) and the "42V/14V-Bordnetz" (42V/14V PowerNet).
At the 7th International Technical Meeting for Vehicle Electronics in Baden-Baden in the same year, considerable interest was raised by the paper "Neue Bordnetz- Architektur und Konsequenzen" (New Automotive Electrical System Architecture and Consequences), presented by Dr. Richard D. Tabors (MIT).BMW presented the "Spezifikationsentwurf für das Zwei-Spannungsbordnetz 42V/14V" (Draft Specification of a Dual Voltage Vehicle Electrical Power System 42V/14V) in Hanover.
The work at SICAN GmbH was given decisive impetus by the cooperation between BMW and Daimler-Benz as witnessed in their joint definition of the European "Load List 2005" and the jointly authored "Draft Specification of a Dual Voltage Vehicle Electrical Power System 42V/14V".
In intensive discussions with the major semiconductor manufacturers, a voltage of approximately 40 V was found to be advantageous. Many arguments are summarised in the paper "Intelligente Leistungshalbleiter für zukünftige Kfz-Bordnetze" ("Intelligent Power Semiconductors for Future Automotive Electrical Systems" presented by the former Siemens Semiconductors at the 17th "Elektronik im Kraftfahrzeug" (In-Car Electronics) conference in Munich 97.
Other arguments for a higher voltage included the reduction of weight in the wiring system, improved stability, and reduced voltage drop With three times the voltage, thick conductors can be reduced to a third of the cross-section, and at the same time the relative voltage drop can also be reduced to a third. For the same cross-section, the relative voltage drop is now no more than one ninth. The voltage level resulting from these arguments was so close to three times the present voltage that 42 V became the automatic choice for the second voltage level.
You can spend a lot of time searching this stuff. German car electrics are very unreliable right now, but a break through must be on the horizon and GM must be in the loop
.In 2011, several German car makers agreed on a 48V on-board electric power supply network supplementing the current 12V network and introduced the "Combo plug", a common power plug for DC charging electric vehicles. As of 2018, this 48 volt electrical system has been applied in production vehicles such as Porsche and Bentley SUVs, and Volvo and Audi plan to use the 48-volt standard in 2019 vehicles.
I was horrified when GM used German technology in their Caddy 'Hot V' engine and Toyota using a complete Mercedes chassis in their Supra. Maybe the C8 has rear wheel steering like the MB GT which is coupled electronically to the front steering via wires and electric motors. Maybe they have this German system.
Shaka is offline
The following 6 users liked this post by Shaka:
AORoads (12-14-2018), ArmchairArchitect (12-13-2018), elegant (12-13-2018), Foosh (12-13-2018), JerryU (12-13-2018), Quinten33 (12-13-2018)
Old 12-13-2018, 09:55 AM
  #70
Jeff V.
CF Senior Member
Jeff V.'s Avatar
Go to Google and look at "GM Global B Architecture". This is the follow up to Global A, which was introduced around 2011.
If the C8 is the lead car for a whole new electrical and data architecture, then yeah, there's a whole lot that could go wrong.
Jeff V. is offline
Old 12-13-2018, 10:00 AM
  #71
oregonsharkman
CF Senior Member
oregonsharkman's Avatar
Originally Posted by ShagVette View Post
engineers have uncovered a major electrical issue with the future Corvette during the development process. From what we gather, the vehicle’s electrical system can’t carry the load necessary to support the necessary components.
As an Electrical Engineer for avionics systems, I find that highly unlikely. One of the very first things a design team does, is to capture the electrical load requirements and then design in enough margin to operate in extreme conditions, temperature ranges and corner cases.
oregonsharkman is offline
The following 12 users liked this post by oregonsharkman:
ArmchairArchitect (12-13-2018), Corvette ED (12-13-2018), dcbingaman (12-14-2018), firstvettesoon (12-13-2018), Foosh (12-13-2018), jimmyb (12-13-2018), PurpleLion (12-13-2018), Quinten33 (12-13-2018), Roscoe Primrose (12-13-2018), Shaka (12-13-2018), Tool Hoarder (12-13-2018), vndkshn (12-13-2018)
Old 12-13-2018, 10:06 AM
  #72
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 1,364 Likes on 815 Posts
Could it be something else though? Not just a load requirement, but something to do with interference or systems communication (I only know the very basics of how to wire a race car and do basic house stuff w/o killing myself). If the car has start/stop crap, electric steering, electric AC and water pump and the new super rolling key encryption... is there something in all that that could go amiss under some unique condition and not just simply be a load issue?
Tool Hoarder is offline
Old 12-13-2018, 10:07 AM
  #73
1SG_Ret
CF Senior Member
1SG_Ret's Avatar
Certainly you can question how and why, but one only has to look at other projects like Hubble or Mars Climate Orbiter to see $h!t happens. W/ all the electronics crammed in today's cars, I'm surprised this hasen't happened with other earlier vehicles.
As long as it's corrected before the car hits the market, I'm good. I can't imagine the negative impact the C8 would get if cars would fail to start or worse. One only has to think of the bad press and wide news coverage BMW received when a few vehicles (out or thousands sold) caught fire while parked.
1SG_Ret is offline
Old 12-13-2018, 10:13 AM
  #74
ArmchairArchitect
CF Senior Member
ArmchairArchitect's Avatar
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
On a side note, I hope GM figures out a way to ditch the traditional heavy and large lead-acid battery in the Corvette with some type of cutting-edge Lithium-Ion/capacitor combo battery that is smaller and lighter.
ArmchairArchitect is offline
The following 3 users liked this post by ArmchairArchitect:
elegant (12-13-2018), Foosh (12-13-2018), Suns_PSD (12-17-2018)
Old 12-13-2018, 10:18 AM
  #75
vetteman41960
CF Senior Member
Originally Posted by Supersonic 427 View Post
So, someone at GM tells GMauthority.com that the car that hasn't been announced or acknowledge yet..... is delayed because of electrical problems? That would be a pretty risky leak....if true!
Bingo! No way GM discussed a issue about a car that they do not even acknowledge is in the pipe line.
GM standard answer is we DO NOT DISCUSS POSSIBLE FUTURE PRODUCTS.
Everyone on the forum always states they cannot reveal their source for information .
So does anyone really believe that a GM employee would acknowledge that their are developmental issue with the future unannounced flagship?
I say no way if they risk their job just acknowledging the car is in the pipe line they definitely get fired for discussion of issue with this unacknowledged future car.
vetteman41960 is offline
Old 12-13-2018, 10:28 AM
  #76
vndkshn
CF Senior Member
Originally Posted by fasttoys View Post
We been hearing the faster version of the ME will have electronic motors, simular to other electric cars. In order for GM to keep cost in line they need an electric system to handle all versions.
I dunno, that doesn't make sense to me. Why have the heavy (and expensive) wiring to support electric motors on a version that does not have electric motors?
vndkshn is offline
Old 12-13-2018, 10:31 AM
  #77
Jeff V.
CF Senior Member
Jeff V.'s Avatar
Just like the CAD leaks, the paint shop photos, etc...
Jeff V. is offline
  #78
Redc7z06
CF Senior Member
Redc7z06's Avatar
Here's your problem.
Redc7z06 is offline
The following 3 users liked this post by Redc7z06:
firstvettesoon (12-13-2018), Maxie2U (12-14-2018), ojm (12-13-2018)
Old 12-13-2018, 10:44 AM
  #79
The HACK
CF Senior Member
The HACK's Avatar
Guys guys guys...
at this phase all the testing ting done on the car is for durability purposes. Something BROKE after a period of operation. Whether it’s electrical or mechanical is up for debate, nothing on the car now, during this phase of testing, would have been found to “can’t handle the load.”
Anecdote time. The company I worked for used to supply parts to a Tier One that supplies to GM (*cough* Hurst Shifters on the Camaro *cough*). We designed the part in collaboration with GM, and in durability testing they found that one of the bushings inside the mechanism would fail after about a million shifts. The part fit fine, operated fine, we had actually placed a 7 figure order for parts when they came back and said “um, no. Scrap that purchase order.”
We had to reorder a higher durometer bushing, mad rush the assembly, scrap a container full of parts, and re-do our durability testing and document to show that the bushing will last well past the LIFETIME of the car they’re installed in. It was a pain in our butts, and as the car was already rolling off the assembly line it was high hell to pay on our end.
But sh*t like this actually happens more often than not, especially during the end stages of development and testing. Stuff that worked fine as specified ended up breaking during durability testing.
The HACK is offline
The following 6 users liked this post by The HACK:
dcbingaman (12-14-2018), firstvettesoon (12-13-2018), Foosh (12-13-2018), Quinten33 (12-13-2018), sunsalem (12-13-2018), vndkshn (12-13-2018)
Old 12-13-2018, 11:07 AM
  #80
Tool Hoarder
CF Senior Member
Originally Posted by The HACK View Post
Guys guys guys...
Good points.
Quick Reply: GM Authority: C8 Delayed 6 Months Over Electrical Issue
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
