Could there be a Split Window Detail ?
#41
I still think there is relevance in the 63 SWC for a heritage revisit though. Afterall they are very valuable and the centerline carbon fiber concept has now been used by Corvette on the ZR1.
#43
It would definitely be nice to see that design carry from the Chiron/Divo (Divo is based in the Chiron) on the ME Corvette. But we would see it poking through the camo.
#45
#46
Not so. A conventional functional rearview mirror is still a requirement. The virtual mirror converts at the flip of a switch. This has been discussed many times already and at one point I posted a section of the relevant code.
The center icon is clearly for the rear hatch. The right is possibly for the roof, and what we see is a convertible.
#47
Actually, if they just centerlined the carbon fiber without the spine, that would still be a great look. It appears that the front hood and roof has a centered recessed area where they could develop a front to rear surface centerline. No spline, but still incredible in detail.
#48
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
When I saw this thread recalled some time ago someone said what it was supposed to be, which I never considered! Took the pic but could not find that post, don't recall the explanation but it apparently has a meaning!
#50
For context, this portion of the thread was kicked off by Skank's bold assertion -
which I pointed out was incorrect. A conventional mirror is a requirement and a rear window to see through.
Believe it or not there are regulations governing rear view mirrors in passenger cars.
The original technical articles on the Cadillac virtual mirror here stated that conversion to a conventional mirror be available because of regulatory requirements. And it is.
Since then I've been challenged several times like this and responded with the US regulation governing mirrors.
So it is true, and this is where I got it.
That was before, when there were no options like this new tech. Clearly a rear window is actually not necessary with this new wide view streaming rear camera. In fact a standard traditional rear view mirror has a narrower view image than this new tech.
49 CFR 571.111 - Standard No. 111; Rear visibility.
S5. Requirements for passenger cars.
S5.1 Inside rearview mirror. Each passenger car shall have an inside rearview mirror of unit magnification.
S5.1.1 Field of view. Except as provided in S5.3, the mirror shall provide a field of view with an included horizontal angle measured from the projected eye point of at least 20 degrees, and a sufficient vertical angle to provide a view of a level road surface extending to the horizon beginning at a point not greater than 61 m to the rear of the vehicle when the vehicle is occupied by the driver and four passengers or the designated occupant capacity, if less, based on an average occupant weight of 68 kg. The line of sight may be partially obscured by seated occupants or by head restraints. The location of the driver's eye reference points shall be those established in Motor Vehicle Safety Standard No. 104 ( § 571.104) or a nominal location appropriate for any 95th percentile male driver.
Unit magnification mirror means a plane or flat mirror with a reflective surface through which the angular height and width of the image of an object is equal to the angular heightand width of the object when viewed directly at the same distance except for flaws that do not exceed normal manufacturing tolerances. For the purposes of this regulation a prismatic day-night adjustment rearview mirror one of whose positions provides unit magnification is considered a unit magnification mirror.
#51
It is a tribute to the "last gasp" of the two roadster versions of the Zora racing Grand Sports. It did have some racing success. That is a quote from the book, "Corvette Grand Sport," by Lowell C. Paddock and Dave Friedman with forward by Rodger Penske dated 1989. The #12 is the car as George Wintersteen raced and as it appeared in the USRRC series in 1966.
You can see in the pic of the emblem, in addition to the two number 12's it's the top view of the roadster, which shows a steering wheel dash area, red box! Zoro made the roadsters to get a lower profile for less drag at high speeds compared to the Grand Sport coupes. Quoting a comment in the book, Winterseen "piloted the car well but was outclassed my the mid-engine McLarens and Lolas."
The C8 will get that fixed!
#52
http://gmauthority.com/blog/2018/11/...camera-mirror/
#53
Bikerjulio, where in those regulations does it say there is a required rear window? We provided a few and can give more examples of cars that barely or essentially have no rear window to view rearward with a conventional mirror. Read the link I gave on the second generation system that GM has developed. A far better solution to the typical exotic car that has a sloped rear window at a extreme angle where resolution is compromised.
Why I ask is it could be possible and attractive to run a venting spine down the middle with glass on either side. Elegant seemed to hint that the back glass design could be radical.
#55
See posts #2 and my #51. One can conjecture that the #2 blurry emblem is a split window BUT it is probably what I define clearly in post #51. The same as the one in my Grand Sport. That one, in addition to the original Grand Sport in it's present configuration as race in 1966 with the #12, is a top view of the roadster, which clearly shows a driver's side dash area as well as it's hood scope.
Rodger Penske bought the 2 original Roadsters believing they had a future in racing. One had a 4 twin carb Webers (like mine, albeit small, pic below!) and the other Wintersteen bought from Penske that had a 427 engine, when it was retired in 1966 and then sold for $6700 (current value estimated at over $7,000,000!) It is the car that has been restored in it's last #12 racing trim! Assume that is why the tribute emblem.
But like those that continue the delusion that the base C8 will cost over $100,000 and GM is intent on Corvette suicide, guess a split window dream will continue as well! We'll soon see.
#56
Wait a second...so who came out with the split dash design first!!?? Corvette C2 or Bugatti? Sacrilege!
#57
Emblem Comparison
Detail of Grand Sport Dash Emblem and #12 Grand Sport
#58
Skank, I have seen GM’s application pics for the vented rear window. Do the illustrations have to be close to production in design?
#59
Received 1,293 Likes
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
#60
GOSH! thousands of viewing of all Corvettes and the C3 still comes on top. IMHO of course.
P.S. sorry for the thread derail. I keep my mouth shut now.
