The side scoop conspiracy lives on
So, I think all the conspiracies are rubbing off on me. Some folks have persisted in saying that the body panels for the side scoop on the C8 are fake and what really lies beneath is a side inlet that follows the curve of a 58' thru 62' Vette. Well, after looking at some of the photos again, I'm not sure they are wrong.
Take a look at the photos below. I haven't altered anything in the photos, only adjusted the light levels and contrast in hopes of revealing some detail. And what I'm seeing is that the side scoop looks to be covering part of a scoop below. The top part with the door handle seems to be real enough, but as soon as you move past the door, it seems that the real shape of the curve may be hidden under a panel. The smoking gun seems to be the shape of the curve that starts to emerge under stress at high speed or under the right light, also shape of the scoop seems to change in some photos. Take a look, enjoy, thoughts are welcome.
P.S. Not sure where the C8R panels fit into all this. Every panel on the C8R is custom. Hard to say if the General is smart enough to create fake panels for that to mess with us.
The following 2 users liked this post by Atari_Prime:
firstvettesoon (01-23-2019),
IronV (01-24-2019)
Popular Reply
01-23-2019, 06:15 PM
This photo clearly shows the faux panel covering the real side scoop outline.
This photo was taken at the same time frame as the McDonald's photos. The faux panel above covers the same approximate area as is revealed in the fabric camo beloe.
This photo clearly shows the same faux panel. This panel is too thin for a production vehicle.
This photo shows the C8 at speed at the ring with the faux panel collapsing inward under aerodynamic pressure.
since we can see the edge, it can't be going back TOO far. IF that is real : )
The following 3 users liked this post by firstvettesoon:
The following 3 users liked this post by DanSavage:
What looks to be an extension of the scoop is actually a removable section to access the ducting (Dark Blu) Once the aero guys have decided what is best ducting shapes, the production quarter panel will cover the ducting.
The placement of the intake at the Coke Bottle curve causes attachment and eliminates the boundary layer. The squiggles represent separation which is expected in this region. Dark blue is the housing for the ducting. Red is higher pressure. Light blue is low pressure. Squiggles are separation.
Red is higher pressure. Turbulence is caused by ridges.
2 ways of avoiding the boundary layer. Elevate the scoop or a bleed off from the compressor.
Cover the mess after all the development work has been done with the production 1/4 panel. No ugly swollen wart bulgy things.
IronV (01-24-2019)
Below is the famous Ring photo with light tweaked a bit. In the past some have argued that the line we see is just a shadow that helps create the curve is just a shadow. But a shadow of what? Not the side mirror, that is in front of this spot. Not the top edge of the panel, its too pointy. The remainder of the panel should be covered in shadow as well. Also, the shadows we see are a completely different color than the line going down the side. If it were the shadow of the panel above we should see a smother transition as it moves backward across the panel.
Also, shadows do not seem to account for the dark area curving beneath the bottom of the door.
YEP.... you can see the thicker scoop wall but note the enhanced contrast image. Can sort of make out the angles. To my eye the edges don't look to go further back TOO far. More than the thin cover but not so far back or we would loose it in the scoop.
I would be very surprised if the scoop were "rounded" at all. Just won't go with the rest of the cars sharp angles and flat features. I could be wrong...
IronV (01-24-2019)
Two scenarios to me:
1. It's 100% a fake panel and the real car won't have it there and the inlet will resemble the CERV concepts and C1 cove shapes.
2. It will be a contrasting color or carbon fiber so that the visual appearance is the same as #1, but maybe it will functionally ingest more air?
Regardless the pics above clearly show a very thin panel covering a thicker edge that goes further back.
firstvettesoon (01-24-2019)
John T (01-24-2019)
In what way?
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
One only needs to look to the C8-R for confirmation that the prominent side scoop is real. They would not test a race car for competition with a fake side scoop.
The following 2 users liked this post by ArmchairArchitect:
CorvettoBrando (01-25-2019),
firstvettesoon (01-25-2019)
That's the part that is confusing. You can clearly see the vent on the regular C8 deform in several shots. Therefore, it has to be either a) a temporary panel to test designs, or b) a fake piece of plastic and tape to cover the real design/shape underneath. The latter seems more accurate based upon the available info. The C8R doesn't have any of these hidden elements, however, every single panel on the C8R is different from the regular C8, especially the rear hatch area which is more flat straight to the bumper kinda like a Europa. This doesn't match the C8 dimensions at all.
While it is true that many of the the panels on the C8R are different, i.e. not the same exact panels, as the streetcar, they are essentially the same profiles. Exaggerated yes, but essentially the same shape. I did and overlay a while back that showed that the race car and the streetcar share a very similar design envelope and styling cues.
I also posted a comparison between the front engine and mid engine cars using Ferrari as example. The C8 seems, at least for the moment, to be on par with the 488 in terms of size and general shape. The Ferrari 488 race version is nearly identical to the street version. I feel that the C8 Will share much of the same overall styling as the race car will be at a bit toned down.
I would think that the purpose is to have a Racecar that looks enough like the streetcar to attract attention to the brand.
The V shaped scoop has been seen and also described by eyewitnesses to be close to the street production version, at least one of them.
of course, we know nothing for sure and I are merely grasping at straws’s in an attempt to figure out this design. Hopefully it won’t be much longer before we start getting some real information and images
