C8 General Discussion The place to discuss the next generation of Corvette.
C8 base performance, like C7 Z06 since C7 base was like C6 Z06 performance?
Old 02-08-2019, 01:26 PM
Dethsupp0rt
Dethsupp0rt's Avatar
Originally Posted by Zaro Tundov
Quite likely. The C8 has the advantage of being ME, so a more modest power increase is required to achieve C7 ZO6 acceleration performance.
Rumors suggest a base 500+hp LT1 variant, but based on my own intel there is something more to the powertrain that is being hidden even from GM suppliers who would normally know at this point in development.
Hidden in plain sight. That's the best way to do things, knowing all the speculators will divert attention elsewhere.
Old 02-08-2019, 03:21 PM
Zaro Tundov
Zaro Tundov's Avatar
Received 1,039 Likes on 554 Posts
My guess is that it's a 48V mild hybrid. BorgWarner's P2 Module is already in production, with an off axis version expected to be launched in 2021, just in time for the C8 to enter production. The P2 is perfect match for a DOHC V8 in need of low end torque and a car model in need of higher fuel economy ratings.
Edit: I've been advised that the Blackwing LTA architecture will probably be the ONLY V8 architecture offered on the C8. Perhaps the base really will be an naturally aspirated LTA variant with mild hybrid assist to augment the low end?
Old 02-08-2019, 08:23 PM
FAUEE
FAUEE's Avatar
Received 4,444 Likes on 2,802 Posts
Originally Posted by ffr1352
It seems the next generation base corvettes have about the same performance as the previous generation mid level corvette, so since we have nothing better to do in this section but speculate... I think the base C8 will be 0-60, 60-0, 1/4 mile et/mph and lateral accelerations will be about the same or slightly less than the C7 Z06. While I am at it, the base C8 will be $65k. Your turn. Play nice!
Lol what. You think a base c7 is as fast as a c6z? You need to get out more...
The following 2 users liked this post by FAUEE:
SocalChvy (03-19-2020), vettefordays (03-16-2020)
Old 02-08-2019, 09:27 PM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
I seem to recall 0-60 being within driver error and 1/4 as well. The Z06 traps a hell of a lot faster though iirc.
Depending on the track, I'd wager it could go either way. But if you have longer straights forget about it. The Z06 should walk away from the stingray every time. Short course with twists is probably a drivers race. the torque curves are a lot closer than you'd think actually...
Old 02-08-2019, 09:39 PM
ffr1352
ffr1352's Avatar
You are right!, I need to get more as the stingray was the 58th fastest around Laguna Seca and the C7 z06 was the 88th fastest! Keep trying , flame suit on!
https://fastestlaps.com/tracks/laguna-seca-post-1988
Old 02-08-2019, 10:30 PM
skank
skank's Avatar
Received 1,156 Likes on 516 Posts
To clarify the Fastest Laps list, I was there viewing these three runs with Motor Trend. All driven by Randy Pobst. All three of these tests were quite varied in the weather conditions. Check out the Car & Driver Lightning Lap Test. The C7 GS(2:47.1) walked on the C6 ZO6(2:53.5).
27th C6 ZO6-ZO7 1:34.43
41st C7 Grand Sport 1:35.62
58th C7 Stingray 1:38.28
Old 02-08-2019, 10:40 PM
JABCAT
JABCAT's Avatar
Received 8,804 Likes on 4,236 Posts
Motor Trend has a ‘06 Z06 at 3.5 0-60 & 11.5 1/4 mi at 127mph compared to a ‘17 Grand Sport 3.9 & 12.2 at 116mph.
Old 02-08-2019, 10:55 PM
84 4+3's Avatar
Like I said, within driver error for the average guy. I probably couldn't hit that 11.5 or 12.2.
Old 02-09-2019, 07:57 AM
ZishanM
ZishanM's Avatar
116 vs 127 is all we need to know. These cars are leagues apart. With heads and a cam, the c6z is significantly faster.
Old 02-09-2019, 07:59 AM
Mr. Gizmo
Mr. Gizmo's Avatar
Originally Posted by warhawkmcdaniel
What are the numbers for a C6Z06 vs C7 Stingray? I don't think they are that close.
0-150 mph a c6z06 is a lot faster 4 or 5 seconds quicker then a base c7 and almost 1 second quicker then a c7z06 . Top speed the c6z06 factory estimate is 198 mph. The c7z06 stage 1 aero is 195 mph and takes a day longer to get to top speed then it takes a c6z to get to top speed. Comparing the c7 and c6 z06’s from a rolling race 40 to 150mph then on up to top speed the c6z will be so far ahead you won’t see it’s tailights if your driving the c7z.
0 to 60 c7z is quicker and 0-100 c7z is about a half second quicker then the c6z mainly because of the huge c7z torque with the 1.7 supercharger. But up high the c7z Peters out with the little supercharger. That and the c7z being heavy with barn door aero supposedly good for track downforce make the c7z feel sluggish. Having had both cars I much prefer the normally aspirated motor.
The mid engine c8 if it gets good traction would be better served with an engine that behaves like the normally aspirated ls7 without worrying it’s owners that it will drop valves .
Old 02-09-2019, 08:01 AM
ZishanM
ZishanM's Avatar
Your assessment was true for the C5z and the base c6. Wasn't applicable to the C6z and C7 base. And if the C8 base is N/A there is no way it will be applicable to a 650hp C7Z in the trap speed.
They might be able to run comparable lap times on certain tracks, but thats only one comparison.
Old 02-09-2019, 08:41 AM
JerriVette
JerriVette's Avatar
Received 3,948 Likes on 2,177 Posts
Originally Posted by jschindler
There are two ways to look at that comparison. Yes, you can show much better 0-x times if the car hooks up from a dead stop better. But accelerating through the gears from a roll is what is real world. Only drag racers and bench racers benefit from a dead stop launch. I’m not saying it’s a bad thing, just that it is only one aspect of the performance measure.
chassis rigidity of the c8, the dct , the rear weight bias all favor consistent acceleration performance.
we are on a forum speculating about where the c8 will land in performance to the c7. Of course we are bench racing..lol
zero to sixty with lets say 500 hp and we will see zero to sixty acceleration times to equal 3.3 seconds as a best guess which is halfway between the c7 z06 manual at 3 seconds and the 3.7 seconds on the c7 grand sport automatic torque convertor automatic..give or take a few tenths.
yes the trap speed of the c7 z06 with 650 hp will be quite a bit higher than the base c8...but for most of us....regulalr sports car enthusiasts will enjoy the under 80 mph consistent increase in performance over the already amazing c7 grand sport...
the topic of this thread is where the c8 standard version, maybe the z51 version will land compared to the c7 lineup..
and we are bench racing as we shoot the breeze on where the c8 will land compared to todays corvette lineup.
that was the premise of the thread as we all wait for the official gm release.
traditionally the corvette engineering team wows the automotive world with the release of a new generation.
thats one of the reasons why corvette is an iconic brand...the best corvette is always the newest...at least for the past couple of decades..(none of this diminshes previous generations of corvettes)
jmo
Old 02-09-2019, 10:05 AM
  #33
punky
Banned Scam/Spammer
punky's Avatar
Received 3,862 Likes on 1,912 Posts
My 2016 A8 Z06 in factory condition down to the tire pressure ran 10.92 @ 130MPH and I am no professional driver.
Old 02-09-2019, 10:08 AM
  #34
Yarbie
Yarbie's Avatar
The base will get base performance just like the base C7. $60k isn't getting you 3.3 0-60. You'll pay $100k for that and even more for Z06 2.85 0-60 just like the C7 Z06. It's funny reading folks thinking a $60k car is actually a $300k car.
Old 02-09-2019, 11:40 AM
  #35
23/C8Z
23/C8Z's Avatar
Received 5,761 Likes on 3,177 Posts
You're out of your mind.
Maybe YOUR c7z06. Not mine lol. Or the numerous others who have owned both cars.
Old 02-09-2019, 12:04 PM
  #36
Foosh
Foosh's Avatar
Received 16,668 Likes on 8,311 Posts
Originally Posted by tonypittman
Sad, but true. I can’t understand why simple speculation and discussion gets that kind of reaction on here these days. But, it seems to be the case. Still, I hope the trolls don’t turn this into a totally unfriendly place. It didn’t used to be this way. Over the years it has often been a useful resource. But lately it’s more of a flame war arena, above all else.
Tony,
The C8 section of the forum certainly has generated a lot of controversy and has gotten nasty. That's particularly true when certain individuals proclaim things to be true with no credible evidence to support their assertions. That starts flame wars and pissing contests. There's nothing concrete to actually discuss.
The C7 General and Tech sections are generally very civil, and the same as the C6 General and Tech sections were a decade ago. They are helpful places and great resources. The C8 section is an anomaly, and since there's no car to compare notes on, it can't be a useful resource.
I took an 8-year vacation vacation from this place between '08 and '16. When I returned, the place seemed exactly the same. I wasn't around for the comparable speculation on what the C7 would be like before introduction, but I suspect it was similar to what we're seeing in the C8 section.
Visit somewhere else, and you'll see entirely different behavior.
Old 02-09-2019, 12:37 PM
  #37
Mr. Gizmo
Mr. Gizmo's Avatar
I am hoping the c8 brings some big improvements — lighter weight and a normally aspirated motor that revs high.
the numerous c7z owners don’t want to admit or are to afraid to admit the c6z is a better acceleratiing car up on the big end. Stock for stock then the c7z.
To C8 base performance, like C7 Z06 since C7 base was like C6 Z06 performance?
Old 02-09-2019, 12:49 PM
  #38
449er
449er's Avatar
Received 4,713 Likes on 2,998 Posts
Op, The C7 base is NOT the same performance as a C6 Z06, The C6 is hundreds of pounds lighter, better brakes, more hp/tq...Lol
Old 02-10-2019, 09:22 AM
  #39
punky
Banned Scam/Spammer
punky's Avatar
Wrong. No way you need to spend anywhere near $100,000 for a Z06. The participating dealers on this forum are great and will put you in a Z06 for tens of thousands less than that #. A C7 Z06 is an import humpers nightmare as it will bitch slap their European dream machines at 1/2 to 1/3 the cost. This same crew will go into full meltdown when the C8s take center stage. .
Old 02-10-2019, 10:33 AM
  #40
69L79
69L79's Avatar
Location: Hamilton Square NJ, Ocean City N. J. Key Biscayne Fla.
100 % correct. At best, the C7 base w/Z51 would be the equal of the C6 GS. The C7 could not match the C6 Z until the C7 Z came out.
Quick Reply: C8 base performance, like C7 Z06 since C7 base was like C6 Z06 performance?
