C8 Patent For Active Aero Dynamic Side Body Panel System?
Someone should perform a study on how many tens or hundreds of thousands of man hours have been wasted on the internet by people bent on trying to figure out just what auto manufacturers are up to.
I'm sure the results would be mind-boggling.
Thousands and thousands of posts on the C8, and all merely speculation.
I wonder if it exceeds the amount of time spent on online ****?
Shaka (02-15-2019)
Unless things have changed radically without my notice, racing bodies forbid the use of movable aerodynamic devices. That started when McLaren protested the Chaparral “sucker” car in Can-Am a long time ago. IMO, this device would not be acceptable by the FIA or IMSA and probably not others. The rule enforcement goes so far as to check for “flexing” of body work due to aerodynamic or mechanical loads.
Which raises the fascinating question of when and where would this device be used.
Shaka (02-15-2019)
Patents don't mean that these devices will reach production.
Keep this notion in mind in your responses. All we are interested in is the efficiency of the friction circle of each tire over a large speed range in acceleration, braking and turning. Race cars have all types of restriction but street cars don't. Street cars are subjected to a variety of roads and conditions even the supercars. Lap times at the Ring and other circuits seem to be important to sports car buyers. In that regard, street car active aero is a lot different to race car considerations. In the Air Force we referred to 'Shadows" that occur in yaw conditions, IE: Shadows at wing roots and engine nacelles.
Things to consider when designing active aero devices for road and track. We will get to each dwg. on this one post in time unless you have other suggestions.
Pros and cons of yaw.
Effects of pitch, roll and yaw.
Each of the following DWGs. A lot to cover.
Watch the negative yaw on some of the cars on Sunday. Short tracks have positive yaw below.
From yaw to spin
Instantaneous velocity field in yaw
Bump drafting.
Controlling airflow in yaw to minimize shadows.
vettedna (02-16-2019)
firstvettesoon (02-15-2019)
I think the high performance cars have this hood outlet. We have seen various rear spoilers that might be exploring the range of incidence for the active wing,
The front active devices are easy to conceal.
Reading paragraph 0027 of the Patent Publication is very interesting in that it clearly indicates these active vents after the front wheel wells. It the goes on to describe using actuators to push out and deform the body panel by bulging the body surface outward. That indicates the large rear side vents could possibly be used for that in addition to the front vents on the ME. This patent seems to service both FE and ME configurations.
Great information! It's great to see the Corvette Engineering Team utilizing and employing the latest technology and techniques. Similarly, Lamborghini uses Aero Vectoring to help keep those Raging Bulls stuck to the streets.....
*** Courtesy Of Lamborghini ***
Save The Wave,
Corvette_Nut
Save The Wave,
Corvette_Nut
The vectoring flaps is BS. Tire grip is paramount and the higher the load the greater the grip. Why reduce it. Yaw is good on oval tracks but road and track is not. Those airbrake things on the patent DWGs is a nasty way to control yaw or even braking. It will make a racket in the first place and the effect on the cars stability will be enormous. It will be banned on track days. Controlling airflow is very effective and Ferrari does it best. They are building a new supercar. The will be vectoring but to allow it to unload the tire is non sense.
I would prefer the splitter to slide for and aft.
Only to arrest high yaw acceleration actively.
Absolutely. Expect quite a few Z06+ changes in the exterior body. At this time we believe (but not confirmed) that the hood will have two air ducts as rendered many months ago by fvs, the side scoops to protrude around 1/2” more, and additional front, side and rear aero components.
Hot air over the roof reduces lift and drag over the roof but the rear wing diverts it under the wing which further reduces drag.
I moved the outlets further apart
Correct placing of intercoolers. The water to air intercoolers on the streetcar on top of the engine is a disaster waiting to happen. Ferrari has no lag with their IC placing.
#33
Paragraph 0029 describes the use of the system immediately behind the front wheel well to exhaust the heated air from the hot brakes. There are quite a few locations within the entire publication that describes these moveable planar surface vents aft of the front wheel well. These would work very well in FE configuration, where the ME does not have near the available space to accomodate a large blade. Not saying that a ME wouldn't work, just that it's optimum in a FE.
#34
The Consigliere
Received 5,432 Likes
You work for Johnny Bohmer?
#36
Here is the Zenvo TSR-S with a crazy tilting rear wing...
https://www.youtube.com/watch?v=EPsI49eWWpY
#39
The Consigliere
I remember the hood incident on one their first runs with the car after reworking it.
#40
Ah, interesting. I've got over 150 runs in mile events, most of which have come at the Texas Mile. I know this car/seen it run there. Johnny did a nice job on that rig - particularly considering the apparent basket case it was when it was first brought to him.
