So where's this 1,000 horsepower monster testing?
I agree with you on some of that. I can see younger engineers, "But my modeling says it should be good!". Build it, go try to destroy it.
That said, we have no idea of the timeline of any of this. Maybe the frame issue came up early and has been long fixed and the electric issues are the current delay issues. It's all conjecture at this point.
I wasn't saying don't model... I was just saying I could see a younger engineer overly relying on modeling.
[QUOTE=Tool Hoarder;1599036898]The latest batch of rumors is that the C8 is having frame twist issues with the "1000 horsepower variant". Where is this car? Everything we've seen testing has sounded like an updated LT probably a new LT2 as many assume. I would assume the 1000 horse variant would be a twin turbo Blackwing derived motor with electric assist front drive. Does this car exist already? Also, everything we've seen has had relatively mundane wheels/tires/brakes. I would expect this monster "Zora" model to have a widebody, large tires, and fancy brakes. Hard to do powertrain testing on the 1000 HP model if you don't use the correct sized tires to test chassis loading.
Any production engineers or powertrain engineers have any insight on how they might be testing the hi-po variant at this point? Is this real-world torture testing or theoretical computer modeling stuff?
imo just some of the gm engineers having some fun in their down time
That's fair. A lot of my friends are like that. Although in reaction engineering it isn't as crucial because there is a big old safety margin worked in anyway.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
PS: Yep already decided I'll wait for the Grand Sport version with other than those anemic 305 section width rear tires! You're right the C8s seen in Germany with the "skinny tires" and solid front rotors is fine for the base car at a low price. The other variants will cost more. Hope I don't have to wait too long for the Blackhawk, which their building in Bowling Green- wonder why???
The C8R is just that... the C8R... built by Prat & Miller and being tested for the 2020 IMSA season. Doug Fehan talked about the car at the bash last year much to the annoyance of Harlan Charles. He issued a statement after the bash walking back his comments and talking up racing the C7 again for 2019. Plus, those cars have under 500 horse.
At best, I think this is "Viagra" marketing... "If your erection lasts...". (ehhh, can the lawyers find a way to say "erection" on network TV?).
Marketing VP (gloating)... "Gentle-persons, can we find a way to leak that the engineers have found problems when HP on our new C8-ish car is pushed beyond 1,000HP?.... come on, people, help me here... PLEASE!!"
Back to the OP’s question, such C8 ZR1 testing is taking place on the 140 miles of Milford Proving Grounds. And could well, be as above posted, also be occurring at Yuma test facilities.
Mikec7z (03-13-2019)
Wait a minute! From the same article:
A Corvette prototype with a twin-turbocharged, 8-cylinder engine is generating 900 to 1,000 horsepower and is causing a "structural distortion of the aluminum spaceframe" during tests. "The twist in back was enough to fracture the glass hatch covering the engine," Hagerty reports.
Hagerty estimated that the redesigned model will start in the range of $60,000 to $70,000 and get a 6.2-liter, 8-cylinder engine with at least 500 horsepower, which would be about 50 more than the current base version.
Which is it 900-1,000hp or 500 hp? First electrical delay, now this. What gives GM?
Follow USA TODAY reporter Nathan Bomey on Twitter @NathanBomey.
I had no idea where Yuma proving ground is, then I went on Google Maps and looked it up. Dang! That’s one massive testing facility. She can scream her pipes out and they probably won’t hear it a few miles out. How da hell did Ford do such a good job of hiding the FGT?? Did they not do climate testing, real world element testing?
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes
If you can enforce the mid bulkhead well enough to prevent engine intrusion into the cockpit during front end collision why can't you also prevent frame warpage with same bulkhead structure/structures?? Doesn't take too much imagination to conjure up a few sketches.
Simple: IF they exist, theres only one or two, they're restricted to whatever GMs special operations department is called, and if they go anywhere its on covered trailers. Suppliers tend to not get those type of vehicles none too early, which is who I suspect most of the C8s on the public roads are being driven by.
Ford has a proving grounds down the road. Also remember, the GT was done in complete secrecy, even internally, and sprung on the public in a surprise. It wasn't a revamp of an existing car, it has almost no options that suppliers needed piles of variants to validate, and it sure as heck didn't go on the road until it was revealed.
And no, I suspect by the virtues of what the GT is, I doubt it got the attention to the HVAC that a Fiesta would.
I think the whole story is BS.
The C7 Stingray makes 455HP. The C7 ZR1 makes 755HP. They share the same frame.
SO, now GM can't make a frame to handle 900-1000HP?
Also, I doubt the engine in this hyper C8 will be making that much HP. Probably more like 650 to 700 with 200+ HP electric motors up front. And if that is the case, then the twisting frame/cracking backlights sounds even more suspect.
But it is a good story....
Garret (03-14-2019)
#33
the C7 has been around long enough to have many examples of 1000+ hp builds. although various failures have occurred, none, to my knowledge have been related to the frame structure. probably just due to the immaturity of the C8 design as opposed to any difficult to resolve design problem. i am certain that other issues, many not reported in the press, have been encountered in the years of the ME C8 development.
Mikec7z (03-14-2019)
#34
#35
Didn't Wixom PBC close in 2014?????
#36
I don't think any of the 1,000+HP C7 builds have a glass dome on top of the engine, no? Those questioning why the C8 all of a sudden has an issue with shattering glass now that the engine's been moved to the back...I'm PRETTY SURE if there's a glass in place of where the hood is, some of the 1,000+HP C7 builds will PROBABLY shatter those glass too.
#37
Received 1,816 Likes
#38
#39
Received 8,918 Likes
Bill
kenownr (03-15-2019)
#40
That's they only way they're getting more than 800 HP or so, with a hybrid setup. Wouldn't even need tires as big as the Z06.
