Take a guess at the base weight????
#121
An LT1 is about 450 lbs, so if the rumors of a base C8 with "LT2" naturally aspirated pushrod V8 based on the Gen V LT1 are true, then it will probably be about 450 lbs as well, depending on changes. If it ends up getting a lot of technology that the LT1 doesn't have, then weight could increase.
Not surprising. The Supra uses a BMW engine. It's not that BMW "underrates" it's engines per se, it's that they certify to ECE power standard, not SAE. It is more stringent than SAE, requiring the engine to run longer periods to heat up and pull timing, and then an average of power made across an operating range is used as the rating. This results in the BMW engines having more power than expected when they are tested using SAE practices.
