C8 Base model traditional AWD option speculation (Based on New 7/1/2019 Video)
(From the new Germany video)
In the tire pressure widget, downhil spotted the two differentials (https://www.corvetteforum.com/forums...dows-down.html).
The current non-high-end Jag F-type features a traditional mechanical AWD system as an option.
Based on the above screen cap of the tire pressure widget, do you think the base C8 will offer an optional traditional AWD system?
Perhaps while you're driving, this tire pressure widget will indicate/highlight (with color?) in real-time, the power distribution to the front vs rear.
Of course, without knowing more, there are other possible explanations for the above tire pressure widget showing a front axle and front differential:
- Reused widget from a future non-base C8 AWD model
- Reused widget from a different vehicle all-together
- Pre-production widget to be changed before production
- This is not a base model
- Other
Last edited by black_valentine; 07-02-2019 at 01:06 PM. Reason: Edited Jag F-type model range description from low-end to non-high-end per Foosh comment for clarity
FringbirdAloha (07-03-2019)
The V6 AWD Jag F-Type you speak of is hardly "low-end." The 380HP V6 AWD version MSRPs at $88K without any other options. The base RWD starts at $61K.
EDIT: OP edited his original post in the response to the above. Thus, above is now irrelevant.
Last edited by Foosh; 07-02-2019 at 01:07 PM. Reason: Clarification due to OP edit
Edwardz (07-06-2019)
* Excluding the I4 296 hp and V6 340 hp versions that don't offer AWD as an option
Very interesting ...
AWD is not all that expensive and is available on so many performances cars these days, both FE and RE. No reason it real couldn’t be available on the base C8, but there hasn’t been any indication of it until now, and it was not on the leaked order option sheet.
Let me clarify. I was distinguishing between V6* and V8 models where AWD is available as an option, or standard. I was trying to convey that the V6 model is lower in the line-up compared to the V8 models, much like the base Corvette has traditionally been lower in the line-up compared to the higher-performance models (e.g., GS, Z06, ZR1, etc.)
Last edited by Foosh; 07-02-2019 at 01:09 PM. Reason: edited due to OP clarification.
Fair enough. I edited my original description for clarity.
Foosh (07-02-2019)
It would be interesting if they offer it as an option on the base.
Received 1,919 Likes
I'm not feeling it, but I've been wrong (just ask my wife).
We've heard nothing about it to date, and that's a lot of additional change management to add to the package in addition to everything else for the C8 model.
But no, it's not that expensive. My wife's daily driver Toyota RAV4 has it and I think the out the door price was under 24K or something like that. True, it doesn't have gobs of torque to deal with.
Why do people think AWD requires the same size tires F/R? It doesn't. I highly doubt GM is delivering a hybrid electric AWD base Corvette for $60K. That leaves 3 options:
1. This is pre-production software using code from something else (a truck maybe) to create that image.
2. This is code that will be used in the "Zora" and is pre-production and being used in the base car for testing.
3. This is a new powertrain testing in the base body.
That said... electric hybrid front drive won't have a front differential to begin with. I don't for a second thing a traditional mechanical AWD will be stuffed in this car.
Couple of things:
1. It seems all AWD sports cars have the same diameter wheels on front and rear, including Lamborghini, Porsche, and GTR. Yes, the widths can vary but the wheel heights are the same. Corvette traditionally has run 1" smaller rims in the front than rear so equal rims on all 4 tires would be a break from their traditional form factor.
2. All car companies are reducing model lines but increasing trim/feature sets on the remain models to have a wider price range.. Look at Porsche and the Ford Mustang as an example.. With the news of Camaro being discontinued, I'd be surprised if GM doesn't increase configuration and engine options for their only remaining sports car in order to increase sales.
Couple of things:
