C8 General Discussion The place to discuss the next generation of Corvette.
Final side scoop design
Old 07-09-2019, 10:14 AM
Race Prepared
Race Prepared's Avatar
I would purchase this car and work on getting accustom to the rear facia.
Originally Posted by firstvettesoon
I think they mean it will look like this...
Old 07-09-2019, 10:46 AM
Vettrocious
Support Corvetteforum!
Vettrocious's Avatar
Received 1,118 Likes on 574 Posts
2017 C2 of Year Finalist
I’m probably wrong, but the tape location tells me that the scoop is like this. The plastic “blade” is just there because the options list says there’s one...
firstvettesoon (07-09-2019)
Old 07-09-2019, 10:56 AM
firstvettesoon
firstvettesoon's Avatar
Received 1,906 Likes on 750 Posts
Glad you are back drawing!
It could be anything at this point but I feel it will have some interesting details. Looking forward to being surprised.
Old 07-09-2019, 11:01 AM
Vettrocious
Thanks, couldn’t resist throwing gasoline on the fire. Looks like you got the rear end correct, good job (assuming the that pic isn’t someone’s render)😊
pietro c7
pietro c7's Avatar
Received 1,157 Likes on 650 Posts
Flip flop it(pietro scoop)and use the other base painted mags....
Thanks for contributing Vettrocious
Old 07-09-2019, 11:20 AM
firstvettesoon
where does it say there is a trim blade?
Old 07-09-2019, 11:24 AM
B-Myster
B-Myster's Avatar
I think this is one of the better renders and wouldn't be disappointed if this was close.
k wright (07-09-2019)
Old 07-09-2019, 11:27 AM
John T
John T's Avatar
Exactly. It doesn"t.
Old 07-09-2019, 11:52 AM
Atari_Prime
Atari_Prime's Avatar
Originally Posted by vetteb_96C
I'm still a believer that the scoop does not go into the door creating the little wing piece.
And you are still wrong. There is no evidence to support the position you propose.
The following 2 users liked this post by Atari_Prime:
JockItch (07-09-2019), WalterSobchak (07-09-2019)
firstvettesoon
I know the leaked order form said something about trim pieces in carbon flash but nothing about a "scoop" trim piece specifically.
John T (07-09-2019)
Old 07-09-2019, 11:53 AM
firstvettesoon
He "may" be wrong. We know nothing for sure. It could all be a trick!
vndkshn (07-09-2019)
Sub Driver
Banned Scam/Spammer
Sub Driver's Avatar
Received 3,772 Likes on 1,467 Posts
Originally Posted by Dave Tracy
My hope is that the scoop is not incorporated into the door to any great degree because the projection would be prone to dings by virtue of the sharp edge.
Except every single door on every single car is prone to dings since they can all be opened into other objects.
Old 07-09-2019, 11:59 AM
  #33
firstvettesoon
Save the door dings and get in the C8 the cool way...
FringbirdAloha (07-10-2019)
Old 07-09-2019, 12:08 PM
  #34
JockItch
JockItch's Avatar
Received 5,282 Likes on 1,966 Posts
Im seeing a side scoop with sharp, angular lines to match the style of rear design we already know is legit. The general shape looks to mimic the Aria side scoop many are fond of, I believe the lines of the C8 scoop will have sharper creases instead to match the rear design. I’m liking what I’m seeing.
The following 4 users liked this post by JockItch:
kozmic (07-09-2019), vettesweetnos (07-14-2019), yellowmnm (07-11-2019), z edge (07-15-2019)
Old 07-09-2019, 12:26 PM
  #35
vetteb_96C
vetteb_96C's Avatar
Not sure how I can be wrong when it's still in camo. Do you really think you are seeing everything the final design has to offer?
Old 07-09-2019, 12:30 PM
  #36
ToddC7
ToddC7's Avatar
Which is why he probably said 'I believe'. You don't need evidence for something you believe to be true. You could have 'logical reasoning' to support your beliefs, instead. Such as "GM would never design a vehicle with a dangling triangle hanging off the door", or something similar.
Honestly, it is tough to believe GM would be that risky but you never know. I don't believe the side scoops are going to be nearly as pronounced as the camo indicates. It's just based on historical GM non-risk taking if you will.
But, I'm hoping for a pleasant surprise on the reveal date!
John T (07-09-2019)
Old 07-09-2019, 12:55 PM
  #37
Vettrocious
I’m not claiming there is a Blade just thought that was pretty much accepted, my bad. Here’s it is with no blade:
The rear pic is clearly orchestrated carefully to not show the side of the car. The camera angle was also deliberately from knee level to take the roof out of the pic. Try taking a pic from that angle without bending down and attracting attention. Anyone who believes this was not a GM initiated leak needs to go easy on the caffeine and get out of the carbon monoxide filled garage.
If GM leaked it early, it’s very possibly a bogus pic.
The following 4 users liked this post by Vettrocious:
firstvettesoon (07-09-2019), FringbirdAloha (07-10-2019), John T (07-09-2019), vndkshn (07-09-2019)
To Final side scoop design
Old 07-09-2019, 01:06 PM
  #38
firstvettesoon
^^^ looks good.
I was just wondering if there was some other info I missed.
I think there will be some sort of "insert" in or around the scoop. The one close up door image shows a big lip following the scoop shape. Not sure how this will look in the end.
John T (07-09-2019)
Old 07-09-2019, 01:17 PM
  #39
RapidC84B
RapidC84B's Avatar
Received 13,145 Likes on 5,983 Posts
^^^ looks good.
It will look like the CAD... there will be a trim/lip. The blue leaked car shows this too.
Old 07-09-2019, 01:21 PM
  #40
firstvettesoon
^^^ I meant how "good" it will look. The detail of the big groove and lip.
I am hopeful.
Quick Reply: Final side scoop design
