I have heard, mention of the C8, possibly having different lug nut, spacing? Does anyone know if this is just a rumor, or does it have some validity too it? If it actually is different, seems only logical, any aftermarket source, will need time to tool-up, for such a change, also may be more expensive and or delay any proposed purchase for aftermarket wheels. Thanks for any info.
NONN37
close
- Member SinceMar 2006
- LocationSouthern CALIFORNIA
Liked:239 Times in 199 Posts
The rear wheels need to be more concave or deep dish. They need to make a tighter rear package or make a wider body. the current wheels look weak
The brakes look pretty set in most pics. Looks like a bad hub setup. its like they didnt wanna spend time on machining a new wheel, so they copy/paste the front.
Walt White Coupe
close
- Member SinceJun 2005
- LocationPhila Suburbs 2023 C8 & 2013 650ix
Liked:2,692 Times in 1,384 Posts
Quote:
First, everyone knows they can not be more concave or deep dish. And contrary to what you said or think the design while not pretty or light does look like it will be very strong.Originally Posted by NONN37
Foosh
close
- Member SinceOct 2004
Liked:16,939 Times in 8,419 Posts
OP is not talking about the wheel design. He's asking about the bolt pattern, and I heard it was different as well, but can't find the reference. If true, no previous Corvette wheel would fit even if the offsets and sizes were right.
Red Mist Rulz
close
- Member SinceSep 2016
Liked:10,511 Times in 5,240 Posts
The lugs are 14mm x 1.5 rather than 12 x 1.25. I believe the bolt circle is the same. If you're wondering if C7 wheels would fit, we don't know about offset or center bore yet, which will also be important. It will probably be possible to enlarge the lug holes in some wheels (it's only 1mm of metal taken off the edge of the hole) but offset will be critical.
Offset dimensions have changed for 2020 to 52mm front / 64 mm rear
Bolt pattern in still 5x120mm
2019 wheels will not fit on a 2020
C8Jake
close
- Member SinceSep 2013
- Location►SICAMOUS◄
Liked:5,436 Times in 2,535 Posts
Quote:
Originally Posted by Foosh
heard it was different, can't find the reference
Exploregthal
close
- Member SinceFeb 2013
Liked:1,174 Times in 487 Posts
I've seen something different for offset (although it could be completely wrong)... where did you get this info? Originally Posted by bbbad2dabone
Offset dimensions have changed for 2020 to 52mm front / 64 mm rearBolt pattern in still 5x120mm
They are different, the old was the same 5-4 3/4, the new 2020 is 5 on 120mm. It is about 14 thousanths different but enough that you would not want to use and older bolt pattern on the new one even though you could get it to mount.
Mike Campbell
close
- Member SinceJan 2002
- LocationFt. Myers FL
Liked:1,193 Times in 658 Posts
I also read somewhere that you'll have to reset your torque wrench from 100 lbs to 130 lbs.
Quote:
140 lb-ft. Page 300 of the PDF of the owner's manual.Originally Posted by Mike Campbell
