ME dynamics while turning vs FE
This could be during any spirited driving, not necessarily on a track.
me doubting Thomas. I’ll wait to “see” it with my own eyes and feel it with my own ***. Right now I’m inclined to think theres a high likelyhood the FME platform will retain a fair number folks who prefer it. I was thinking about this today as I was rowing throw the gears in my M7 ZR1 ZTK on a twisty northern Wis country road.
Deck seems stacked against them being better though.
The PS4S tires aren’t close to Cups, and the car is much heavier.
One is the natural tendency of a given car to oversteer, understeer or be nearly neutral as the limits are slowly approached.
I can guarantee you that the C8, as most modern cars, will come dialed in from the factory with a slight understeer, as this is safer for most drivers, in most situations.
However, this is of little to no importance is situations, on track or street, as loss of control happens. Almost no loss of control happens in a smooth approach and exceeding of the limits. Loss of control happens on transient conditions (changes in surface traction, undulations, etc) or transient input (throttle out of a turn, brake into a turn, etc). This can upset neutral cars, understeering cars and oversteering cars. Hondas and Minis spin out regularly on track just like 911s, for example.
On this transients, what matters is how progressively or abruptly a car initiates rotation, and how easy or hard it is for the driver to recognize the start of undesirable rotation.
So, lets look at a few things that matter on those factors.
1 - C8 has a longer wheelbase than almost all ME cars - all things being equal that will slowdown rotation.
2 - C8 seems to have a lot of mass at the rear of the car. That super heavy DCT behind the engine is almost as heavy as the engine itself. The C8 likely has a weight distribution closer to the modern 911 than the Cayman. In fact, it is MORE rear biased than the modern AWD 911s. That will tend to be more snappy in rotation. It was obvious that GM was seriously worried about the amount of weight in the back of the C8 - that is why they have a very expensive carbon fiber rear crash bar.
3 - GM's PTM (and the C8 will probably be even better) does a phenomenal job helping prevent power induced spin outs, particularly in Sport 1 and sport 2. So if you keep it on, you can at least remove that as a reason for snap loss of control. If you don't order PTM, 2 clicks on the traction control will bring on competitive driving mode which is almost as good as Sport 1.
4 - It will be much harder for a driver in a C8 to recognize the start of rotation than the C7 driver by feeling the motion (seat of the pants), simply because your body, being closer to the C.G., will not move as much. Rather use the feeling of the "lightening of the steering" to recognize start of rotation. If the wheel gets light, you are already rotating - quick hands NOW.
That is my 2c. The C8 will be more modern 911ish than Caymanish.
Its the only reason i ordered mag ride on my 1lt track build. I want to get ptm.
The stability control on porsches are otherworldly in how you never even feel them working. Theres no blinking light on the dash, no abrupt throttle cut, no weird braking noticed on a single wheel or tugs at the wheel. Its completely transparent. So different than when tracking an amg and a different world than my camaro ss.
Im really really hoping they get it right with the c8 ptm. It can make or break a car for me
My racecars I run with everything completely shut off, but this is a street car. I'd be a lot more upset if I hit a wall with it.
Are you sure you are on PTM on the street? If you don't go to Track, double click, you are not on PTM.
I think the Z mode is the best thing that GM has done. It is currently such a pain to go in to Track-SportX every time before driving that I don't bother. If you are in Track the car reverts to Tour on the next start up.
So I leave mine in Sport (that stays on across re-starts) and simply hit traction control button twice to put it in competitive mode (not as good as PTM SportX, but better than nothing). I can't be bothered with so many button presses on start up.
With the C8, it will be heaven. Start up, hit Z button go. I'll probably leave my Z button as: Track->Sport 1, Sport Steering, Track exhaust, Tour Suspension, Sport brakes. For the street. Unless I can program this into MyMode. In which case, I'll make Z button a track button as: Track->Sport 2, Sport Steering, Track exhaust, Track Suspension, Track brakes.
When you dip your foot on the skinny pedal of a Z06 the PTM has a lot more variability to manage vs PASM. PTM is actually quite good.
If you go drive a Ford Product (e.g. GT350) you would cry and give up if you have to keep the traction control on on track. The only thing you can do with the Ford or Dodge products is turn everything off. Same goes for AMG. BMW's is tolerable at best, but still annoying.
PTM 2, and ESPECIALLY PTM 1 seriously inhibit the ability to get the car to rotate. They cut too much throttle. 2 isn't nearly as bad as PTM, but you're not going to throttle steer in PTM 1 at all.
I dont really want PTM 1 or 2 on the street. I don't throttle steer on the street. I'd rather have more SC on the street.
Tour-Sport-Track, etc are driving modes. You can also change the stability control and traction control in those modes. But that is NOT PTM.
PTM is entered by putting the car in Track mode, then double clicking on the traction control mode. Then you can choose the PTM algorithm (Wed, Dry, Sport 1, Sport 2, Race).
You should try Sport 1. Sport 1 has stability control still on and a much more relaxed traction control. It is good enough to let you spin the tires are launch and even do some light throttle steering out of corners, but will minimize the chances of a loss of control. I think it is quite a good mode for street spirited driving. The only issue is how annoying it is to press all those buttons on start up. The MyMode/Zmode will be welcome additions.
Funny story: I was taking a student for hot laps on a track. We were chatting and I was about to pull into the track and I still did not have PTM set up. So as I was pulling out of pits I quickly put it on track, hit the traction control twice and (this was on Camaro 1LE) hit the button four times down to put it into race. Note that once you are on PTM on 1LE there is no indication of what mode you are in (they all show traction control/stability control off). I started driving, got to first corner felt like the engine had an electrical failure, after several seconds (felt like an eternity) engine worked again, next corner same thing. Took me one more corner to figure it out. I miscounted, so I had one extra click, which put the car from Race to Wet. Boy that PTM did not measure action traction at all. It just completely cut power as if we were on a near zero traction track. I had never used PTM on anything less than Sport 1, so I was completely un-prepared.
So yes. ZMode will solve that problem also. The display is so slow, that I simply count clicks and go. So Zmode will prevent starting on wrong mode. It is crazy that one misclick bring you from the loosest mode (Race) to the most restrictive (Wet) PTM set up. Live and learn.
ZMode for the win.
I've used sport 1 extensively on the track (spring mountain). I developed a lot of bad habits, actually. Sport 1 is pretty restrictive on the track.
The sport version had wider tires, same camber, but god-awful shocks with too much rebound that bound up the car until halfway through a corner and then let go causing a spin. The car did not have a tendency to spin on the road, even aggressive canyon carving. I've accidentally drifted an S2000 out of a parking lot. All of the Elise/Exige issues, with modified steering arms and Dampers.(Both available from www.blackwatchracing.com) fix this issue and the car is incredibly easy and fun to drive.
I mentioned the above, not to inject British awesomeness into a Corvette forum, but to set the stage for the C8. Firstly, I slightly disagree with the previous poster about the C8 being more like 911 than a Cayman. I think it will be more like the Cayman, but not completely. The Cayman is 44/56 F/R vs 40/60 for the Vette. The 911 is like 64% rear, but more importantly a bunch of that weigh hangs cantilevered behind the rear wheels. 911s are fantastic, but you do feel that booty at the limit.
These cars will have Eccentric adjustments for the control arms, so Front camber shouldn't be a problem. GM will also likely have better shock settings out of the gate than Lotus. The big advantage is stability control. The Lotus doesn't have it. Much of the poor driving can be corrected to prevent folks from destroying their cars from lift-throttle oversteer. My hope is that GM relies on stability control vs poor factory dynamics to protect people from themselves. If the shocks are not over-damped and if the chassis is more neutral at the limit, it will help reduce over-driving conditions like push-to-oversteer.
The advantages of ME have been mentioned previously, but the big ones relate to the control of acceleration and rotation. The FE is more benign under corner entry, but as we saw with the pacecar in detroit, High HP FE is tough to manage under corner exit i.e. acceleration. The stability control was being asked to control too much torque on a bumpy track. Mark Reuss was probably embarrassed, but in reality, it was too much power under too slick conditions(i.e.bumps) not enough static grip. The weight over the rear helps tremendously putting power down out of the corner. It reduces the load on the computers and allows more control.
On the rotation front, we will have to see, but the car hopefully has lower polar moment meaning more weight centered in the middle as opposed to out on the ends. This means the car will rotate faster, BUT easier to control. Contrary to what many say, I find it easier to recognize rotation in ME vs FE. We will see.
Bottomline, I think the concerns are not going to be an issue. With various levels of traction control to protect the beginner and adjust-ability in the suspension, I believe we'll be able to setup the car well for track-work but be well-protected from all but the stupidest actions on the street.
You really notice it most (not that it's the most pronounced, but you notice it most) on FWD cars. It's like the front is tucking in on itself or something. I made the mistake of slightly letting up in a huge compression zone of the N-ring in a FWD car. Scared the crap out of myself.
I just can't do FWD. I went in an upgraded to an M4.
