The Battery is in the frunk, I believe behind the panel near the firewall. The Battery saver package is more than a C-Tek 3300. The package includes a convenient female plug in (in the frunk) for the tender. I have it in my C7Z and it is very convenient. Worth the 100 bucks IMO.
I bought the tender from Cultrag performance (Forum Vendor) not from a LPO when I ordered the car. My C8 came with the outlet in the Frunk
The female plug is standard - not part of the battery saver package.
Originally Posted by Roller12
Thank you capevettes. I was thinking that the female plug in the frunk was standard (without the protection package). If it is not standard, i believe you can plug a tender at the passenger side in the cockpit. Is someone know if the new electrical architecture need a different or specific tender? Is the GM one specific? Thank you.
You're right. It is standard.
Originally Posted by Phil1098
What he meant was the CTEK tender itself has the male plug already hardwired. Pretty sure all the cars have that socket in the frunk, it's just most battery tenders come with two sets of connectors, terminal rings or alligator clips, you typically have to buy the male cigarette type connector separately.
Yes, the socket in the frunk is standard.
Originally Posted by capevettes
Phil, I do not believe the C8's come with that female plug outlet unless the battery saver package was ordered. That's the way it was on C7's. I could be wrong, but I'm assuming the C8 is no different.
Wrong, The female outlet in the frunk is standard.
If anyone has the MANUAL for the C8 Battery Protection Package, Option LPO Code (ERI), would you mind Posting it in a PDF format.
Would like to read it over before car arrives next week.
Thank You
[/QUOTE]
It is simply plug and play. Just remember to take the orange plug protector off before plugging it in. It will fit, but won't charge
Thank You
Send me a PM. I cannot post this PDF file here for some reason. I can email it to you.
User Manual [PDF ] This is the owners manual for the CTEK 3300. The C8 version is a stripped down version of the 3300 (has only a single mode - the 14.4V 3.3A mode that is appropriate for the C8.
The actual C7 manual that came with the charger from GM is different than this. I have access to both.
I know you all are talking about the C8 version, but my C7 you do not take the orange cap off and it charges.
I have a C7. If you're talking about the same circular end-cap at the end of the power connector that should remain attached to the end of the connector. It twists off. Leave it on.
