Sponsored by: Wheel Design
What oil for C8?
Old Feb 6, 2020 | 08:11 AM
BadAV's Avatar
BadAV
Originally Posted by Phil1098
Wonder why the lighter grades of Signature are Dexos2 approved but not the 0W-40?
Did Amsoil really go through the official testing and get approved? From what I have previously seen, they simply "certify" they meet the requirements. I don't know and have not been curious enough to do my own research. I have never used Amsoil but would have no problem doing so, as from UOA results I have seen it appears to be a decent oil. I did recently change my rear diff lube and went with Amsoil with friction modifier added. Wanted to see if it would quiet down some coasting gear whine better than the GM lube. It didn't change anything; I figured it was a pretty cheap expense to give it a try.
Old Feb 6, 2020 | 08:39 AM
Apocolipse's Avatar
Apocolipse
Synthetic
Old Feb 6, 2020 | 08:41 AM
Phil1098's Avatar
Phil1098
Good catch, I just went to the gmdexos site and there isn't one Amsoil listed. They show approvals for dexos1 gen2 and then there is dexos2, completely different list. The oils approved for the Corvette are dexos2.
Old Jan 4, 2021 | 08:17 PM
bestvette2020's Avatar
bestvette2020
Hey Guys! Hope your doing good staying safe this holidays. I thought i would share some news on my c8 as i drive it everyday and now hitting 14k miles today after owning for 4 months! The first oil change the car burned 1/2 to 1 quart of oil. and now on the second oil change at 14,000 miles is now showing it burned another qtr., however i cant find any leaks or smells or bad sounds from engine or even a miss or error code in computer, but i notice i have had to clean the exhaust tips ever week as they are turning black from driving car hard at times 1-4 hours a day or maybe from closed baffles while driving hard makes it blow rich? I'm worried something is wrong with car, not sure how to go about the issue, ill be going for 15k mile PM in a week to service oil change clutch canister and check engine filter. Not sure if its just a small problem or reading the dip stick incorrectly, as I have checked after and during the entire process owning the car every 500 miles, and it shows oil level middle of cross hatch marks up until 25% oil life then the reading is just off and wrong, i tried checking it 165F like it said level at idle. Still reading wrong. or maybe burning oil? If you could point me in the correct direction or forum would be great thanks! Be Safe Take Care!
Old Jan 5, 2021 | 08:56 AM
snampro's Avatar
snampro
uuuuuuuhhhhhggg. It is literally on the oil cap, look through the glass on the back of your car to answer your own question (pop the hatch if you have the htc...)
Old Jan 5, 2021 | 10:57 AM
johnodrake's Avatar
johnodrake
Moderator
Originally Posted by btorlv
I will be using this.
Use what you like, but it isn't spec
Old Jan 5, 2021 | 04:00 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Amsoil is NOT listed on GM's Dexos2 approved oil list. In any viscosity range.
http://www.gmdexos.com/brands/dexos2/index.html
In fact, there are no Amsoil products on the Dexos1 list, either.
That doesn't mean the oil doesn't meet GM's specs, it means Amsoil didn't pay the licensing fees to GM. But there's certainly no proof or even evidence any Amsoil oils satisfy the Dexos requirements.
Old Jan 5, 2021 | 04:04 PM
CP's Avatar
CP
I was working for ARCO when they introduced this stuff. UGH!
Old Jan 5, 2021 | 04:12 PM
Red Mist Rulz
Black residue on the exhaust tips is common with Direct Injection engines from all brands. Not something to worry about.
Burning 1/2 a quart in 7,000 miles isn't really that unusual, either. Some cars are much worse. But it seems odd it would change suddenly, rather than declining gradually.
Regarding the DCT cannister, did you replace it a 7500 miles like GM recommends? If so, it isn't due to be changed again until 22.500 miles.
Old Jan 5, 2021 | 04:15 PM
vicvette's Avatar
vicvette
Nothing comes close to AMSOIL Signature series 0-40 syn zero wear in motors taken apart ,that amsoil was used *****Had 24 corvettes, no engine failure with it!!
Old Jan 5, 2021 | 04:22 PM
Red Mist Rulz
40 year old oil that meets SF standard, when the current is SN?
This oil was discontinued because of reports of clogged oil filters.
Old Jan 5, 2021 | 04:27 PM
919cw313's Avatar
919cw313
2018 C6 of Year Finalist
uuuuuuuuhhhhhhhhhgggggg. It was a reasonable question nearly a year ago when he asked it. How many Corvettes were out there to just check under the hood in Feb. 2020?
Old Aug 21, 2021 | 11:45 AM
  #33
JohnUSA1's Avatar
JohnUSA1
Default The only oil that will be used in my 2022 C8
This is the only oil that will be used in my new upcoming 2022 C8
Old Aug 21, 2021 | 11:56 AM
  #34
Vet Interested's Avatar
Vet Interested
Kind of dramatic aren’t ya?
Old Aug 21, 2021 | 12:39 PM
  #35
JohnUSA1's Avatar
JohnUSA1
I just think it is one of the best oils on the market, and my Chevy dealer uses this oil so it is easy and practical to use.
Old Aug 21, 2021 | 10:39 PM
  #36
Avanti's Avatar
Avanti
Use precisely what GM specifies... and the warranty will never be at risk.
Old Aug 22, 2021 | 08:39 AM
  #37
Andybump's Avatar
Andybump
Originally Posted by Zymurgy
So - there are three Mobil 1 0W40 oils that are dexos 2 approved. What is the difference between the three, and among those three, would one be preferred? I went to the Mobil site, and entered my vehicle info, and it recommends the "ESP Formula" and "ESP x3". The other one just ESP does not come up. I read the descriptions of the oils, and nothing jumps out that would give me reason to prefer one over the other.
To What oil for C8?
Old Aug 22, 2021 | 09:58 AM
  #38
LJT's Avatar
LJT
Here are the part numbers for the Mobile1 ESP Dexos2 oil.Mobil1#123875 (listed on the box), comes in quarts only.
GM#19370233
https://www.speedwaymotors.com/Mobil...-6,371931.html
Old Aug 22, 2021 | 01:52 PM
  #39
MikeinAZ's Avatar
MikeinAZ
I installed a catch can and its doing its job, definately some oil being injested back into the intake without it.
Old Aug 22, 2021 | 06:21 PM
  #40
z06inVB's Avatar
z06inVB
No no no. What you have to do is get a oil filter from JC Whitney that you pack toilet paper in. It won’t clog. And for added economy you can drain the oil thru a cheese cloth and then reuse it. Good as new!
Swear !
