Sponsored by: Wheel Design
My "cheaper and better" engine appearance package
Old Apr 12, 2020 | 08:39 AM
  #61
faninc's Avatar
faninc
Banned Scam/Spammer
Default 3M tape 4611
Hi All, for those looking to use tape, 3M makes a high temperature tape that is higher rated than any other they make. Check out 3M VHB #4611. Rate do to 232 degrees C.
I will be using if my car ever gets built? At 3000 for months.
Old Apr 19, 2020 | 01:08 PM
  #62
big_c's Avatar
big_c
Just wanted to check in on how these are holding up after a few weeks of use? No issues with the VHB/3m tape/ Dual lock installation?
Is the remote working from the driver seat or is it a hassle to change colors and turn off?
Old Apr 19, 2020 | 04:42 PM
  #63
marknagy13's Avatar
marknagy13
Tape is holding up just fine. Remote works perfectly from the driver seat. Very easy to change colors and turn on/off.
Old Apr 19, 2020 | 06:54 PM
  #64
faninc's Avatar
faninc
Banned Scam/Spammer
Default Awesome
Bought light just need the car!😉
Old Apr 19, 2020 | 07:25 PM
  #65
JillyBean's Avatar
JillyBean
Originally Posted by BMadden
Let's see, $20 for the option to change lighting colors to whatever you want or $995 for GM to provide you with 2 white LED lights. Anyone who rags on the OP, but thinks it's perfectly fine to pay for the Engine Appearance Package needs their head examined.
100% agree
Old Apr 19, 2020 | 07:27 PM
  #66
JillyBean's Avatar
JillyBean
Originally Posted by starscream716
I think you're conveniently leaving out the fact that the majority of that $995 GM option is wrapped up in the carbon fiber covers that go on each side of the engine.
ok.......
that's worth about $200
Old Apr 20, 2020 | 12:39 PM
  #67
McKenna's Avatar
McKenna
After reading your post and seeing your pics I purchased the light n Amazon thinking that if I didn’t use it in my car I could use it in other places. Believing that the glass panel in the C8 between the engine bay and interior is thick I decided to test the lights remote. I placed the light on a table inside my house near a front window with double pane glass and an outer glass storm window. I could not get the light to turn on using the remote outside the window, even moving the light into different positions. I then tested the light through a single pane glass door and the remote did turn the light on. I think if I were to mount the light in my engine bay it would only work for appearances at night while the vehicle is parked. The cost of the light is minimal and has several light changing features that could be used in many other places.
Old Apr 20, 2020 | 01:42 PM
  #68
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
The LED Lights I bought (see above post) uses a RF (Radio Frequency) vs IR (Infrared) Remote. That makes a huge difference in the range and penetration to operate the lights. Just got mine so need to install. But here is a test operating lights just laying on the engine cover from inside my C8 sitting in the driver’s seat. And the remote does NOT have to be pointed at the LED light. Also tested in my living room and worked fine at 22 feet. Loftek advertised as over 160 ft in air.
Old Apr 20, 2020 | 01:51 PM
  #69
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
lf these are what you are installing, assume you're using a ring made from something like the correct size PVC pipe to fit the depth?
Old Apr 20, 2020 | 02:04 PM
  #70
CRABBYJ's Avatar
CRABBYJ
No Jerry, I used these round LED lights. I reference the source in an earlier post. These work great but I may not leave them installed except on occasion. The hole plugs allow that. Not sure how heat effects the batteries long term. I bought the four pack because of free Amazon shipping. The other two are going to my son for use in his swimming pool.
Amazon Amazon
Old Apr 23, 2020 | 12:29 AM
  #71
marknagy13's Avatar
marknagy13
I promise you that it turns on from inside the car. If you don't believe me I'll shoot a video to show you.
Old May 7, 2020 | 07:47 AM
  #72
jtwin's Avatar
jtwin
What type of hole plugs did you use, also how did you attach them to the light assemblies.
Old Jun 23, 2020 | 01:19 PM
  #73
iflex2fitness's Avatar
iflex2fitness
do you have a link for the waterproof version?
Old Jul 16, 2020 | 11:40 AM
  #74
Vette_Pilot's Avatar
Vette_Pilot
Looks good to me!!!!!
Old Jul 21, 2020 | 11:26 PM
  #75
JillyBean's Avatar
JillyBean
Mark
are these still holding up well?
my car will be arriving in about 4 weeks and i'm tempted
Old Jul 22, 2020 | 11:13 AM
  #76
JillyBean's Avatar
JillyBean
anyone else do this set up?
thx
Old Jul 22, 2020 | 03:37 PM
  #77
2007Z06's Avatar
2007Z06
How about this 3 pack of rechargeable ones? (Not sure if they are too big):
https://www.amazon.com/Cabinet-Lighting-Wireless-Rechargeable-Display/dp/B07QYW3XS5/ref=sr_1_53?crid=3AK8U455005V3&dchild=1&keywords=under+cabinet+led+lighting&qid=1595446310&sprefix=under+cabinet+led%2Caps%2C160&sr=8-53 https://www.amazon.com/Cabinet-Lighting-Wireless-Rechargeable-Display/dp/B07QYW3XS5/ref=sr_1_53?crid=3AK8U455005V3&dchild=1&keywords=under+cabinet+led+lighting&qid=1595446310&sprefix=under+cabinet+led%2Caps%2C160&sr=8-53
To My "cheaper and better" engine appearance package
Old Jul 22, 2020 | 04:07 PM
  #78
Matthew_C8's Avatar
Matthew_C8
Has anyone found a way to use the official parts from GM? I just want normal looking lights that are wired into the existing harness that appears to be in the engine lid. There are even two cutouts for the OEM lights to snap into.
  • I'm not looking for the carbon bits, just the OEM real lights.
Old Jul 25, 2020 | 04:43 PM
  #79
CanAm Ken's Avatar
CanAm Ken
All,
Have any of you gone with the OP's original design?
If so, can you post here, and tell us how the LEDs/battery/mounting is holding up (under repeated use/heat cycles)?
Old Jul 26, 2020 | 05:02 AM
  #80
C8-Vette's Avatar
C8-Vette
Originally Posted by CanAm Ken
All,
Four months , 4200 miles, no problem, no color change on the unit. I mounted with 3M locking tape. same as whats supplied with Easypass
