Sponsored by: Wheel Design
Rear fuse box
Old Dec 13, 2020 | 03:01 PM
  #41
yelocarbuff's Avatar
yelocarbuff
I did not try to remove the speaker, but felt under it and saw no attachment. All reassembled now, so I really do not want to go in again till someone who has done it answers.
Hopefully someone can chime in that has done it and tell me the story on the speaker.
Video shows speaker does not need to be detached.
Not sure.
Old Dec 13, 2020 | 03:12 PM
  #42
JVi's Avatar
JVi
Chevy Dude's is a 2 or 3 LT - don't know if that matters.
His does not show bungees holding his speaker (a design change ?).
He, as you can see in the video that he posted, just yanks the cover piece out. Do you have plastic trim tools to help?
Old Dec 13, 2020 | 03:27 PM
  #43
yelocarbuff
It is either a design change, or a difference between couple and HTC. Will only know once someone with late 2020MY coupe chimes in to see how theirs looks.
Yes, I have about a dozen plastic trim tools. No help. I am a fairly proficient backyard mechanic.
Old Dec 13, 2020 | 04:26 PM
  #44
JVi's Avatar
JVi
I read where the cover is removed by first pushing INWARD on the "latch".
Old Dec 13, 2020 | 06:01 PM
  #45
yelocarbuff
OK, but I am talking about the speaker cover and waterfall (= vertical part of console against the firewall).
NOT the fuse box cover. That one is very easy to open once you open the hard to remove stuff.
FYI: that fuse box lid appears to be identical to the one under the dash.
On this one, you push a tab towards the center of the box.
In your diagram, that would be towards the roof. Once pushed, you swing that part of the lid outwards in an arc towards the ceiling. Then it falls right out.
But that is no my trouble. Getting to that lid is the problem.
Old Dec 13, 2020 | 06:21 PM
  #46
Broken Halo's Avatar
Broken Halo
That's crazy!! The manual shows you how to open the easiest part (fuse cover) but doesn't show you how to get to it!
Old Dec 13, 2020 | 10:09 PM
  #47
yelocarbuff
Agree. Too crazy! And not in a nice way.
Which begs the question: Why did GM make it so that an average owner can not replace a fuse? First time in GM history?
Never had this issue on any other GM vehicle I owned, including 5 other Vettes.
I can only assume that they really, really do not want anyone accessing those fuse boxes.
Even their own mechanics, unless it is absolutely critical.
Then who cares what parts break (even the video speaks to that, where Chevy Dude thought he broke the speaker cover prying it out).
Really struggling with this one.....
Old Jun 1, 2021 | 02:06 PM
  #48
cC250400's Avatar
cC250400
1st Gear
Default Rear fuse box
Originally Posted by Roller12
Chevy Dude have an explicit video on You Tube : title is bad idea.
I have tried every combination of "Chevy Dude" and "bad idea" on Youtube. I cannot get any videos. Can you help?
Old Jun 1, 2021 | 05:56 PM
  #49
Roller12's Avatar
Roller12
Default This is the video.
Old Jun 1, 2021 | 06:00 PM
  #50
Broken Halo
In his video he's holding his cell phone in one hand and removes the speaker grille and waterfall with zero effort with the other hand. He must have taken it off previously and reworked the clips or something because everything I've read and heard sounds like it's a PITA to remove. One member even gave up and had the dealership do it for him.
Old Jun 2, 2021 | 04:22 PM
  #51
Red Mist Rulz's Avatar
Red Mist Rulz
Chevy Dude is, apparently an idiot who knows nothing about fuses. The fuse is a micro 3 that fuses two circuits at once. If you take it out and replace it with a micro 2 for the mirror circuit, everything works fine.
Old Jun 2, 2021 | 04:56 PM
  #52
Broken Halo
I think you just answered a question I had been wondering about. Is the blade width and spacing on a 2 blade micro the same as a 3 blade micro. True, you'd not have the ability to turn off and on like a Mild To Wild, but if you wanted the open valves 100% of the time a 2 blade micro would be a hell of a lot cheaper!
Old Jun 2, 2021 | 10:21 PM
  #53
Red Mist Rulz
Yes, a micro 2 fuse will fit in one half (center and one of the outside slots) of a micro 3 fuse socket.
