Sponsored by: Wheel Design
Front brake ducts?
Old Aug 7, 2020 | 05:33 PM
btorlv's Avatar
btorlv
Default Front brake ducts?
Is there front cooling ducts like the rears you can install for the track? I see a open air ducts in the front next to the radiator and a plastic tray that kind of points to the front wheel. I'm asking because dealer installed the rear brake ducts during the PDI and I also did not get a funnel for the gas tank.
Old Aug 7, 2020 | 05:48 PM
C7joed's Avatar
C7joed
the front is like a tray that they should have installed. On the rear only the duct should be installed not the part that drops down. That part is only for track
Old Aug 7, 2020 | 05:52 PM
MAD Matt's Avatar
MAD Matt
With the Z51 package there are both front and rear brake ducts. The front ones should have been installed during PDI. The rear ones are ONLY installed for track use. If they installed the rear ones, you need to remove them if your street driving your car as they hang down low and will more than likely get torn off on the street. Plus, they have been documented scooping up paper and catching fire. I'd get back to the dealer and have them read the fine print on the PDI checklist.
Old Aug 7, 2020 | 05:53 PM
MAD Matt's Avatar
MAD Matt
Correct....
Old Aug 7, 2020 | 06:18 PM
C7joed's Avatar
C7joed
Originally Posted by MAD Matt
Correct....
Old Aug 7, 2020 | 06:24 PM
ben1272's Avatar
ben1272
So I should have a set of rear ducts in my trunk when I take delivery? (fronts should be installed)
Also, what is the funnel that is referenced?
This place is such a great source of info! I love it.
Old Aug 7, 2020 | 06:25 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
So where is the funnel for the gas tank located? I looked in the manual:
1. Locate the capless funnel adapter.
2. Insert and latch the funnel into the capless fuel system.
3. Remove and clean the funnel adapter and return it to the storage location.
Very helpful. Would it be that hard to tell you in the owner’s manual where exactly it’s located?
It’s the funnel you need to add gas to the tank if you are adding gas out of a gas can, you would need it if you ever ran out of gas while driving.
Old Aug 7, 2020 | 06:29 PM
btorlv's Avatar
btorlv
Thanks the fronts are installed like the pic. I will have the dealer take the rear ducts off. Already picked up a plastic bag in the rear duct, do you leave the part that is on the backing plate?
Old Aug 8, 2020 | 01:35 AM
rmp's Avatar
rmp
tell that to Kerbeck!
Old Aug 8, 2020 | 09:29 AM
MAD Matt's Avatar
MAD Matt
Remove the duct portion that hangs down and leave the rest. GM designed the car so that when you take it to the track, you simply put the lower scoop on then go racing.
Old Feb 22, 2021 | 12:11 AM
Wolfpilot's Avatar
Wolfpilot
8th Gear
Almost to 500. Cant wait.
Still havent found the funnel. Does anyone know where it is hiding?
Old Feb 22, 2021 | 10:24 AM
BIG Dave's Avatar
BIG Dave
Glove compartment? Trunk? Frunk? Console?
Old Feb 22, 2021 | 10:59 AM
johnodrake's Avatar
johnodrake
Moderator
My funnel was in the glove box
Old Feb 22, 2021 | 11:05 AM
shiumai's Avatar
shiumai
Modified C8 of the Year 2021 Winner
My funnel was in the bag with the rear brake ducts, in the trunk, upon delivery.
To Front brake ducts?
