Sponsored by: Wheel Design
Zo6 motor ?
Old Aug 28, 2020 | 12:34 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Default Zo6 motor ?
Found this online ?
Says zo6 block no cam
https://imgur.com/gallery/XwcEoHN
Old Aug 28, 2020 | 06:32 AM
Sub Driver's Avatar
Sub Driver
Banned Scam/Spammer
Ok......
Old Sep 29, 2020 | 10:58 PM
JUICED1's Avatar
0JUICED1
Former Vendor
Anytime you can add more air to those rotors is a good thing.
Old Sep 30, 2020 | 01:03 AM
bob53's Avatar
bob53
Certainly could be....
the block is a larger v8 and lacks an in block cam casting making it an OHC motor.
the casting stamp indicates it is a GM and if the casting number on the torque plate follows their standard nomenclature it was cast in 2019. The rest of the casting stamps on the block itself do not fit with any existing GM codes.
This is probably a development motor not currently in production but not sure we can definitively call this the z06 motor.
Old Sep 30, 2020 | 07:05 AM
rrsperry's Avatar
rrsperry
Lol.. no cam? At best, you can say there is no cam in the block. It's entirely possible that it is an OHC (probably dual OHC) THink 5.0L DOHC with a flat plane crank, as most of the info has already revealed.
Old Sep 30, 2020 | 10:58 AM
ZishanM's Avatar
ZishanM
How do you put the crank in this motor?
This a very purposeful leak. Just enough information for you to know what it is, and no other shots of the motor.
Old Sep 30, 2020 | 11:09 AM
vndkshn's Avatar
vndkshn
Looks like a casting line goes right through the middle of the center opening, but must fit so tight that you don't see a line in the opening or on the machined outer edges.
Old Sep 30, 2020 | 11:53 AM
RapidC84B's Avatar
RapidC84B
Good question.
Old Sep 30, 2020 | 11:58 AM
ZR-1DUDE's Avatar
ZR-1DUDE
Split case like the C4 LT-5, air cooled airplane engines, etc. That is how they get there crank in there.
D.
Old Sep 30, 2020 | 12:01 PM
RapidC84B's Avatar
RapidC84B
D.
I don't see any seam on that rear machined perimeter though.
Old Sep 30, 2020 | 12:08 PM
Phil1098's Avatar
Phil1098
It's there, just very subtle.
Old Sep 30, 2020 | 12:40 PM
RapidC84B's Avatar
RapidC84B
A buddy who works for Roush Yates confirmed that the seam is there, but with the fresh machining you can't see the line on the machined spots.
Old Sep 30, 2020 | 01:17 PM
ZR-1DUDE's Avatar
ZR-1DUDE
There are 2 slots there to help split the case.
D.
Old Sep 30, 2020 | 01:56 PM
RapidC84B's Avatar
RapidC84B
Ahhh... I see that now.
Old Oct 1, 2020 | 08:20 AM
TRANS DAMM's Avatar
TRANS DAMM
Can we guess how big it is?
Old Oct 1, 2020 | 09:43 AM
Houston Z33's Avatar
Houston Z33
"BG133" - safe to say this is built in Bowling Green?
Old Oct 1, 2020 | 10:41 AM
starscream716's Avatar
starscream716
I don't think so, there's no foundry in Bowling Green. I think that would've been cast in either Defiance or Saginaw.
Edit: Unless you're speculating where the entire engine would be assembled, then it could be Bowling Green, but I don't know what that code is at this point.
To Zo6 motor ?
Old Oct 1, 2020 | 03:20 PM
dio55's Avatar
dio55
That's a RACING engine those billet blocks where heads are supposed to be are for pre setting pistons that you just tap into place rapidly ...Makes me wonder if that's a drag engine
Old Oct 1, 2020 | 09:23 PM
RapidC84B's Avatar
RapidC84B
No... those are torque plates. Block was freshly machined.
Old Oct 1, 2020 | 09:39 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Very easy ................. Just stuff my ex wife's head in the opening.
