★ Attack Blue C8 Dry NANOfiber Performance Air Filter
• Unique Design Creates 11hp & 9lbs or Torque!
• Advanced Dry Nanofiber Technology for Maximum Air Flow With Outstanding Filtration!
• Captures dirt particles the size of bacteria!
• Patent Pending V-Impede Design For Faster, Smoother, Less Turbulent Air!
• Dry No Oil
• Washable & Reusable! Just Soap & Water. No oils or Chemicals Used!
• Direct O.E Replacement Filter. Drop It In & Go!
• Precise Fit & Seal!
• Dyno Tested & Proven
• Throws No engine codes! / No surging!
• Proudly Made 100% in The USA!!
Attack Blue's Patent Pending design paid off. Simply drop it in and free up 11hp & 9lbs of torque. Numbers you can actually feel!
No tuning. No CEL's. No surging. Nothing but responsive, smooth drivability, more power & more torque with just a filter swap.
FILTRATION
What good is more air & power if you're sacrificing filtration? Attack Blue obtains these large numbers without forfeiting filtration by using proprietary advanced dry Nanotechnology. Attack Blues media catches dirt down to an incredible 0.3 submicron level which is the size of some bacteria!
It took 2 years and 2 laboratories to create this dry Nanofiber media which is superior as far as airflow and filtration.
ITS A FACT that nanofibers provide the absolute best air flow while at the same time providing the best filtration over other traditional filtration media. This is undisputable.
Nanofibers are ultra-fine, so much smaller and thinner than traditional spun fibers. This allows you to pack more filtering media in the same amount of space which will still allow air to flow but it creates a treacherous path for dirt & debris so it gets caught up and captured.
This submicron level of particulate retention can increase engine life by reducing wear on internal engine surfaces.
PATENT PENDING DESIGN
In addition to outstanding filtration and air flow, we created this filter with our pat pending V-impede design which allows the air to flow quick, smooth & with less turbulence.
DRY - WASHABLE & REUSABLE
The Attack Blue C8 filter uses an engineered proprietary dry washable and reusable media. To clean, just use soap and water! NO oils, NO chemicals needed to buy or use. . Besides saving you money, you have the ability to run on a clean free flowing filter more often.
PROUDLY MADE 100% IN THE USA
C8 Attack Blue Performance Filter- Lavenza
Part#1001-200T
Retail $135.95
CLICK HERE TO GO TO OUR SITE AND PURCHASE
Any updates on this? Surely the dyno sheet should be easily accessible if you're advertising specific numbers like this... Wonder why that wasn't the first thing posted on this thread or on the website....
https://afepower.com/afe-power-10-10...nce-air-filter
