EDIT: I white-balanced some of the pics in this post and re-uploaded. Same images, just with tweaked WB.
Un-edited other than WB, cropping, and blacking out some license plates (should be pretty obvious). The various shots are using different exposure settings, but no filters or any other "photoshopping".
Here are a couple under an overcast sky:
One in the sun, butted up against an existing Long Beach Red:
From: North/Central NJ - a.k.a. Gotti in the CFNE section
St. Jude Donor '05
The last 4 shots, were they taken with a Gameboy or an iPhone 2? Jesus... perfect opportunity for sun pics and the pics look like they were taken in the C4 era.
Are those Edge Red brake calipers on the Red Mist Tintcoat car? I assume the Torch Red car has the Bright Red brake calipers.
Exactly my question also, as my order for a Red Mist HTC currently has the Edge Red calipers specified. I assume the wheels are the Trident Spectra Gray (which is what I am planning on changing to from Carbon Flash). Now I just need to decide on the mirrors. Initially going with Carbon Flash to match my original wheel choice, but probably will go back to two-tone.
Not even close, torch red will be 4 times the count of red mist.
I think Phil is right. This color is stunning, and will be what I eventually order my Z06 in. But it won't even appear on Torch Red's virtual RADAR. The only time TR doesn't sell well is when it doesn't exist.
