Front License Plate .. to bracket or not?
For those who live in states where a front plate is required....................
Did your car come with the bracket or did you have to order it extra?
For those not using the bracket .. .. Did you remove that center section and bend your plate slightly to use the built in spot?
If you did use that spot were the hole already threaded, or you did you use self tappers or some other method of attachement?
Pictures please .. especially those who used the "bent plate" method. ..
Go ahead and obscure your actual plate number if there are any security concerns with publishing your plate on the 'net... I know I would.
TIA
TIA
Ron_Attleboro_MA (06-22-2023)
Popular Reply
03-22-2021, 11:37 PM
Received 11,606 Likes
7th Gear
TIA
TIA
There's some threads here on the same thing with an actual plate, but I think the picture there can give an idea.
Xplorguy (03-26-2021)
I did the bent plate version as the bracket makes the car look like Hitler. There are four raised thicker square pads for plate screws that I marked with a sharpie and then drilled a pilot hole with a small bit (1/8"?) Then just used standard coarse thread license plate screws.
Not a great picture, sorry.
The following 5 users liked this post by Phil1098:
Dholeski (03-23-2021),
nate.the.great (04-10-2023),
Ron_Attleboro_MA (06-22-2023),
yub (03-23-2021),
Z0Sick6 (03-22-2021)
The following 2 users liked this post by Z0Sick6:
yub (03-23-2021)
I'm in Virginia and they require a front plate but it's no way that I'm installing it. I haven't had one on most of my vehicles. Worse case scenario is a something like a $35 ticket and if you just keep the plate in the car and tell them that you didn't have the screws or something, they probably would never give you a ticket at all. It just takes away from the looks of the car.
The following 2 users liked this post by Rapid Blue C8 Dude:
dale fehrenbach (01-14-2024),
Hellcat_C8_Ryan (03-22-2021)
My car came with the raised bracket but I used the built in spot that isn't officially recommended for the license plate.
The following 2 users liked this post by RKCRLR:
Matt Elkins (04-26-2021),
Mine came with the bracket (at no additional cost thanks to living in a front plate required state).
I've yet to install anything on the front end, but if I ever do I will start with the 'bent' plate solution.
The bent plate install is hardly noticeable at normal viewing angles given that it is low to the ground and tilted backward under the nose. The peace of mind of eliminating a major reason for them to pull me over is a very nice feeling.
The following 5 users liked this post by z8ra:
KonaVette (02-14-2023),
mefly2 (10-30-2023),
VioletVette (12-31-2023),
Xplorguy (03-26-2021),
yub (03-23-2021)
Thanx for the replies so far....
I like the bent plate mount for a number a reasons but was especially curious about whether or not the holes came pre tapped.
With the bent plate, nothing looks added on.except the plate itself AND Police using laser are taught to aim for the plate as the largest flat plane on the car to reflect the signal. With it being both bent and angled down, .. no good reflective surface! ...
For those with the added bracket, .. .. easily removable? I'm now concerned that since I live in a "front plate state" it will come with the bracket and be hard to remove. ..
Italianfox (03-24-2021)
I used the bent plate method with a tinted cover. Holes were already drilled.
yub (03-23-2021)
My holes weren't pre-drilled but it is no big deal to drill some pilot holes and install the screws to hold the plate.
The following 2 users liked this post by george vee:
yub (03-23-2021)
Ed Bard (01-14-2024)
Received 1,168 Likes
St. Jude Donor '21
My bracket was in the trunk. I put the bracket on and it looked horrible. I also thought it had potential to rub on the paint behind it, so I went with the bent plate method. If the bracket is already installed it’s no big deal, 60 seconds to remove it. I too drilled pilot holes in the “pads” which are located under the aero plate cover and align perfectly with the holes in the license plate. I just used regular license plate screws, it’s on there tight. I put the plate in a black silicone license plate frame/holder as well (front and back of car).
The following 4 users liked this post by 16falcon:
Required in my state..... Here's mine..... Never ran a front plate on a better and have never been pulled over.
StormTrooper R (10-29-2023)
The following 9 users liked this post by Phil1098:
22c8z51 (10-29-2023),
CorvetteBank$ (03-23-2021),
Fred Catcott (01-16-2024),
Jwed (01-31-2024),
and 4 others liked this post.
The following 9 users liked this post by Aggie72:
Dirtnap_TX (01-16-2024),
george vee (03-23-2021),
ironheadvette (03-23-2021),
SO.... is there space to put your hand behind the facia so that you can used nut and bolt, or nylon or do you have to use the bolts directly into the ... plastic?..
That's fine for single application, but what about when you have to change plates? will the holes be wallowed out?
