Sponsored by: Wheel Design
Infotainment screen gone blank
Old May 5, 2021 | 10:39 PM
DH2021C8's Avatar
DH2021C8
Default Infotainment screen gone blank
Went to get gas and when I turned the car back on the screen was black. I was still hearing music streaming off my phone. Screen still doesn't turn on and car only has 160 miles. Any ideas?
Old May 6, 2021 | 08:18 AM
BIG Dave's Avatar
BIG Dave
Try rebooting first. Open the frunk, remove the trim panel, remove the Black/Negative/Ground cable from the battery. Wait a few minutes to allow any capacitor’s charge to bleed off. Reconnect the Black wire to the battery, replace the trim panel and close the frunk. If that didn’t work, back to the dealer you go!
Old May 6, 2021 | 12:32 PM
Avanti's Avatar
Avanti
Of all that could have happened, you were probably one of the more fortunate ones. If it won't "reboot" and won't come on by itself (simply another notorious glitch), it's off to the dealer and hope someone there has a clue. Good luck.
Old May 6, 2021 | 06:32 PM
JazzVA's Avatar
JazzVA
Mine went black. It still worked for the camera but otherwise dead.
It was recalled and mine was replaced. No problems since.
Old May 13, 2021 | 08:02 AM
almarlowe's Avatar
almarlowe
Mine went blank yesterday after startup after getting gas. Drove a few miles, went into a store, and it returned after startup ??
Old May 13, 2021 | 09:31 AM
Racer X's Avatar
Racer X
Probably just another Russian hack. I can't wait for the ransomware attacks to start on cars.
Old Apr 7, 2022 | 03:08 PM
oregonsharkman's Avatar
oregonsharkman
I have had this happen to me twice. All displays are blank and none of the control buttons/switches seem to work (climate controls, windows, etc).
I found that by depressing and releasing the start button quickly it all comes back ( works with the engine running too). It appears GM may have used that as a reset option.
Old Apr 7, 2022 | 03:56 PM
srewood's Avatar
srewood
This happened to me once. Turning the car off and starting it again fixed the problem.
Old Apr 7, 2022 | 05:50 PM
avigar's Avatar
avigar
Was this after recent OTA updates?
Old Apr 7, 2022 | 06:04 PM
johnodrake's Avatar
johnodrake
Moderator
I had the reverse. Screen was on but no sounds. Turns out that for some reason the OTA update that I did fried the Boze amplifier. In the process of fixing it the PDR broke. After that, the car has been perfect.
Old Apr 8, 2022 | 12:16 PM
DevilDog82's Avatar
DevilDog82
Veteran: Marine Corps
Same, just happened a few days ago...first problem of any kind on my 7 month old 2021 model year. Hopefully the last!
Old Apr 8, 2022 | 02:00 PM
corvetteflier's Avatar
corvetteflier
Motor Trend just mentioned this in their long-term update on a '21 Vette. Seems like a common problem, but there is a fix.
Old Apr 9, 2022 | 02:48 AM
c_r_h's Avatar
c_r_h
I had a similar problem. When I drove into the garage, the headlights came on and the front cameras wouldn't work (black display). The instrument cluster showed a very simplistic display with only speed and fuel level. I was wondering whether something was broken, but looking into the manual this is what is supposed to happen if the instrument panel lighting **** above the parking brake is turned all the way to the left, for minimum distraction for night driving. Turned it a bit to the right and everything is fine. Sometimes it really helps to read the manual.
Old Apr 9, 2022 | 07:04 AM
Rapid Z's Avatar
Rapid Z
I had this happen on my initial ride home from the dealer. After about 10 minutes it mysteriously came on again and I have never had an issue with it since.
Old Apr 9, 2022 | 07:09 AM
449er's Avatar
449er
CF Community Team
That's why you have a warranty thank goodness
Old Jul 8, 2023 | 09:51 AM
dmsullivanC8's Avatar
dmsullivanC8
1st Gear
Default Information and Heads Up Display Systems gone Black
2021 Corvette Convertible - I have had the DIC and Heads up display systems go blank while I was driving. In the most recent case, I pulled off to the side of the road and photographed the DIC and Head's Up display. The only info on the DIC was the message about "Auto Raising". I then turned the car off. When I restarted it, the screens were still blank but the message on the DIC right was "You are Driver 1 for Memory Purposes" I made an appointment to have it checked out and provided the photographs and circumstances. After checking it, the dealer response was "there were no error codes". Apparently, error codes or lack thereof overrides photographic proof. Any thoughts or suggestions?
Went blank during driving.
Photo after shutdown and restart
Old Jul 8, 2023 | 10:59 AM
Dave O's Avatar
Dave O
I've posted this a few times before but worth another post.
As cars now days are run by computers, they sometimes need to be "rebooted" so to speak just like many other electronic devices. I found out how to to this from this video. First, start the car. Shut the car off. Then open the drivers side door for 90 seconds (and you have to have it open for no less than 90 seconds). Close door, start the car and the computer cache has now been reset, hopefully taking care of any electronic gremlins one might be having. Watch the video using the link below at the 1:44:46 mark.
To Infotainment screen gone blank
Old Jul 8, 2023 | 01:11 PM
Frankb10's Avatar
Frankb10
Similar problem. but it was the whole dash
Hey Folks
Went out yesterday, beautiful day for a convertible, 87 and sunny, drove about an hour and everything was fine. 2023 HTC…3700 miles..
Car was parked for about an hour, started it up and drove about 30 minutes, everything was fine.
Parked again for 45 minutes, got in the car, put the roof down and the whole instrument panel was blank….nothing…drove away (with no speedometer) decided to try the hud and it appeared,,..at least I could see my speed…then all of a sudden the alert code 506 appeared on the dash and it would not reset….anybody have any idea what it means ????
Any input would be appreciated..
UPDATE:
the next day it was fine…..gremlins for sure
Old Jul 8, 2023 | 03:08 PM
Dave O's Avatar
Dave O
Hey Folks
UPDATE:
For any gremlins such as this, use the cache refresh procedure as posted above.
Old Nov 22, 2023 | 06:01 PM
Frankb10's Avatar
Frankb10
Hey Folks
Gremlins again yesterday….for the third time….started car blank screen…..Oh well. HUD was working…
ok after restart…
