Sponsored by: Wheel Design
2022 MacMulkin list / Orders
Old May 27, 2021 | 10:49 AM
  #81
Philippe1's Avatar
Philippe1
Originally Posted by cor66vette
That's one reason for this thread.
A lot of information is being shared here, also.
*Side Note* You got me by one - My deposit same date, I'm 153
My thoughts exactly.
I figure I can trust the team at MacMulkin to keep me in the loop when there's a loop to be kept in
Same date of deposit, but later in the day I assume, I'm #158
Old May 27, 2021 | 12:15 PM
  #82
Bird67's Avatar
Bird67
OT forum?
Old May 27, 2021 | 12:43 PM
  #83
okaythen's Avatar
okaythen
If people in the 21 list drop out, our spot in the 22 list won't move up right because it's a different list? But if later in July (?) that 21 list gets push back and merge with 22, then we will see our spot move up if they drop out? (July is the last month that GM will make 21 models right?)
Is it around 1 to 3 months for GM to produce the car once your MM order is submitted to GM (Deposit becomes non-refundable)
My local dealer said it will take them 5 months to get the car if I put a deposit down (With 10k mark-up of course), is that true for your local dealers as well? I wonder if 5 months is any accurate or they are BSing.
Old May 27, 2021 | 12:51 PM
  #84
Myfourth1's Avatar
Myfourth1
Run Forest run....your dealer is full of s**t.....go to one of the big 3 dealers and it will take roughly 9 months barring any further shut downs.....
Old May 27, 2021 | 12:55 PM
  #85
Inviktus's Avatar
Inviktus
I am seeing the list has not been updated since 05/10/21, you guys seeing different?
Old May 27, 2021 | 12:59 PM
  #86
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
That is sooooooo not correct.
  #87
Zjoe6's Avatar
Zjoe6
The only sure thing in that deal is you spending the extra $10k. He may not be BSing if he actually believes it. I wouldn't.
Old May 27, 2021 | 01:05 PM
  #88
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
@Myfourth1 I just love how you put things, empathetic & simple, yet direct and unambiguous....
Old May 27, 2021 | 01:06 PM
  #89
okaythen's Avatar
okaythen
Thanks a lot guys! that's what I thought!!
Old May 27, 2021 | 01:09 PM
  #90
yellolab's Avatar
yellolab
Realize BG has not shut down due to chip shortage, but here's some encouraging news that I take as it won't be. Other supply chain issues, sure. But maybe not chips.
https://www.yahoo.com/finance/news/g...130617819.html
Old May 27, 2021 | 01:10 PM
  #91
Inviktus's Avatar
Inviktus
Do you have a link sir? I clicked on what was provided to me Nader
EDIT: I was linked to the 21 tracker not the 22
Old May 27, 2021 | 01:14 PM
  #92
cor66vette's Avatar
cor66vette
This is the list I've been watching.
See if it works for you.
https://docs.google.com/spreadsheets...=0&single=true
Old May 27, 2021 | 01:37 PM
  #93
RobbC's Avatar
RobbC
If you are looking at the 2021MY wait list at the MacMulkin then it was updated through Monday May 24. They just have not changed the table date in the past two weeks is all.
Old May 27, 2021 | 02:07 PM
  #94
c_r_h's Avatar
c_r_h
Can confirm. I moved up by the number of May allocations on 5/17, then another six on 5/24, so the list was definitely updated.
Old May 27, 2021 | 02:12 PM
  #95
Korbek's Avatar
Korbek
I believe the issue is that some 2022 deposits were sent the direct link for 2021 list. I was. I went to their homepage and went to the waitlist tool for 2022 and my email brought up my # as expected. I dont intend on checking it again until Sept at the earliest.
Old May 27, 2021 | 02:14 PM
  #96
yellolab's Avatar
yellolab
OK I call BS. You won't make it till July 4th JK.
Serious willpower here!
Old May 27, 2021 | 02:24 PM
  #97
Inviktus's Avatar
Inviktus
Deposit 05/18 and 142 on the 2022 list. Did I see correctly that there were 100 allocations for June?
To 2022 MacMulkin list / Orders
Old May 27, 2021 | 02:26 PM
  #98
Korbek's Avatar
Korbek
I hadn't actually checked it till the questions in this thread on it being updated. I tried the link I was sent and it didnt find my spot. I went to the 2022 list and there it was, exactly what the email said.
I don't think it's really a willpower thing. Checking the list when you're still 4+ months out from even getting an allocation doesn't do anything but raise your blood pressure.
Once my order goes 3000? Yeah.... I'll probably be checking it every couple weeks.
Old May 27, 2021 | 02:52 PM
  #99
jsg1518's Avatar
jsg1518
How are you seeing the actual MM list. I went to the link that was emailed, do you put in your email then it gives you your info. I assume it takes awhile cause I entered my email and nothing shows?
Old May 27, 2021 | 02:55 PM
  #100
Korbek's Avatar
Korbek
You probably got sent the 2021 link. If you're on the 2022 list, go to their homepage and look for the waitlist tracking link. The 2021 and 2022 lists are both there. Click on 2022, put in your email that you received the confirmation of deposit at, and it should pull up your # on the list (which at this point will likely be the number Dana sent you if you are a 2022 chap with a recent deposit).
Don't look for it until at least 7-10 days after they have received your deposit, per Dana's email, or you'll just worry for no reason.
Edit: This is Macmulkin's 2022 waitlist tool link:
https://www.macmulkincorvette.com/or...2022-stingray/
