Sponsored by: Wheel Design
Check lugnut torque
Old Jun 7, 2021 | 11:22 AM
davelv's Avatar
davelv
Default Check lugnut torque
Got around to checking lugnut torque after 5700 miles. Only the wheel locks which were installed by the NCM staff were correct. Factory installed lugnuts were all less than 140 ft-lbs.
Old Jun 7, 2021 | 11:28 AM
/Bear/'s Avatar
/Bear/
Veteran: Marine Corps
2025 C8 Z06/7/E-Ray of the Year Winner - Unmodified
2021 C8 of the Year Finalist - Unmodified
I'm ready for when I get my car!
Old Jun 7, 2021 | 11:35 AM
Newdude's Avatar
Newdude
Its normal on aluminum wheels for the torque to back off. Aluminum wheels should be checked and retorqued at 100mi, 600mi and then every couple thousand.
Old Jun 7, 2021 | 11:40 AM
newc8vette's Avatar
newc8vette
What size drive do you need to check the lug nuts? 3/8" or 1/2"? I have a torque wrench but I've never used it! Thanks!
Old Jun 7, 2021 | 11:45 AM
Kracka's Avatar
Kracka
Originally Posted by newc8vette
what size drive do you need to check the lug nuts? 3/8" or 1/2"? I have a torque wrench but i've never used it! Thanks!
1/2"
Old Jun 7, 2021 | 11:54 AM
JABCAT's Avatar
JABCAT
I check them on every new car I purchase as well as the tire pressures. Many techs who do PDI don’t really follow the instructions for the specific vehicles. My wife’s new Grand Cherokee had the tire pressures set to 50 all around when the door jam sticker clearly states 33 front and 36 rear. Some of the lug nuts were over-torqued and many were way under-torqued. I checked them as soon as we got the vehicle home. We live < 10 mi from the dealer so these items weren’t due to driving excessive distance.
Old Jun 7, 2021 | 01:36 PM
Newdude's Avatar
Newdude
Wheel torque checking is not part of PDI.
Old Jun 7, 2021 | 01:46 PM
Zymurgy's Avatar
Zymurgy
Moderator
Lug Nut Torque
Lug Nut Torque and first 500 miles
Old Jun 7, 2021 | 02:10 PM
LIE2ME's Avatar
LIE2ME
What is the torque on the lugs supposed to be? Most cars I've owned required 100 ft. lbs.
Old Jun 7, 2021 | 02:12 PM
Kracka's Avatar
Kracka
140 ft/lb
Ask Tadge response: https://www.corvetteforum.com/forums...post1601485001
Old Jun 7, 2021 | 04:25 PM
c_r_h's Avatar
c_r_h
It's generally a good idea to have a torque wrench of reasonable quality (not a Harbor Freight special) and a set of sockets. Technically you are supposed to re-torque the lugnuts after about 50 miles after every tire rotation or change. Few do it, but I have found lug nuts that were way too loose a few times, twice even one I could turn with my fingers. You could go back to the tire service after 50 miles or you can and should do it yourself. Its doable even for people without wrenching experience. Set the torque wrench to 140 lb-ft and just re-torque them in a star pattern (always jump one lugnut until you have hit all 5). It can't hurt, but it could save your life.
Old Jun 7, 2021 | 04:58 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, felt that subjective way when I assembled the 502/502 BB Chevy Crate motor from for my street rod 21 years ago. So although I had a HF Torque wrench bought a much more expensive Craftsman (when Sears Craftsman was considered a good source of tools, mostly what I own) to torque the heads, manifold etc.
But I have read a number of reports that say HF torque wrenches are fine and meet the allowed tolerances. Just watched a very good video comparing a $100 Harbor Freight Torque wrench accuracy with a $390 Snap-on. Snap-on are considered professional quality tools (Just expensive.) In multiple tests of both the Snap-on missed one torque level outside the allowed range and HF none! The HF was within the specified tolerance for all 4 torques tested. In a 10 time repeatability test the ICON was slightly better than Snap-on as well.
I use my 21 year old Craftsman to torque my C8 wheels. Probably still my old subjective feeling! I do keep both unloaded at their lowest setting when stored. That is important to maintain accuracy.
Old Jun 7, 2021 | 06:46 PM
bluan's Avatar
bluan
A while back there were some discussions here that multiple people recommended using beam torque wrench only, and not to use the click type, so I went ahead bought a beam torque wrench based on the online review/ratings. But after using a click type torque wrench borrowed from my son, I felt it was much easier to use than my beam type. Now all I see you guys talking about are the click type, making me wonder if I made the wrong decision in getting a beam type which is harder to use compare to the click type, and maybe I should just get a click type from HF as Jerry's comparison above shows that it's just as good...
Old Jun 7, 2021 | 06:49 PM
Zormecteon's Avatar
Zormecteon
Would be interesting to see those same tests performed 1000 times, .. and again after 5 years....
Old Jun 7, 2021 | 07:45 PM
Avanti's Avatar
Avanti
No surprise, and precisely why most manufacturers recommend checking early on.
Old Jun 7, 2021 | 07:51 PM
Broken Halo's Avatar
Broken Halo
I bought this same Craftsman Torque Wrench on special at Lowe's a few months ago on sale for $49.99. I thought that was quite a deal.
Old Jun 7, 2021 | 08:02 PM
ChiefBoats's Avatar
ChiefBoats
T2T SUPPORTER
Veteran: Coast Guard
From: NNCC No Name Car Crew; Owned 1 C2, 2 C3's, 1 C4, 3 C5's, 1 C6, 2 C7's; Now '86, '03; S. DE
2023 C3 of the Year Wnner - Unmodified
St. Jude Donor '21-'22-'23-'24-'25-'26
2020 Corvette Owner's Manual, technical Data, Page 299
To Check lugnut torque
Old Jun 7, 2021 | 08:04 PM
hdrider1's Avatar
hdrider1
I would be very wary of using HF torque wrenches for critical work. I know a guy that cracked an aluminum oil pan using a HF torque wrench on an oil drain plug. Consider the possible consequences and subsequent expense of overtorqing that nut or bolt to save a few bucks. It's just not worth it.
Old Jun 7, 2021 | 08:06 PM
dohabandit's Avatar
dohabandit
That's the one I am about to use. I have some older beam type, but they seem to be missing. I have seen some fancy digital ones lately, they look pretty nice too.
Old Jun 7, 2021 | 08:17 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
how freaking hard was he cranking on it?? at some point common sense says, "this seems like something is off" were talking 20-25 ft pounds....did he add a 0?
