Installer damaged wheel, need recommendation
I have not talked with the shop yet but was trying to figure out what would be an amicable solution:
1) Replace both the front and rear wheels on the one side so at least the paint would match. Should the shop be on the hook for both wheels? That would run approx $700/wheel or $900/wheel depending on shipping method (boat vs air). Not sure if the shop would go for that. If anything they might offer to pay for one wheel and I pay for the other.
2) Pay another shop to powder coat the wheels which would run approx. $1200 for all four
3) The paint shop also offers ceramic paint for approx. $800 for all four. My concern would be durability, etc.
I'm not sure what the installer will come back with but what would be reasonable? I'm also open to other solutions as well.
As a side note, the wheels look great and Chet has been very helpful.
Thanks!
-Moto
Or do what I just did twice at Discount Tire when I had flats due to nails: 1) took off the C8 rear wheels myself and brought them to the shop and 2) said I want your best tech AND there will be a $20 tip IF there are no marks. Both times Tech looked over my wheels and saw there were no marks and Both times they got the tip! Since I have their tire insurance ($225) in one case where nail was near the sidewall that was a new $400 tire free and the other the nail was repairable.
I think the shop is on the hook for only one wheel.
Overtime chips and road rash will happen.
If you must, my vote, I would replace (or powder coat) only the two on the one side.
All four, IMO that is throwing money away.
The gamble is powder coating/ painting the one wheel and getting a match, which I would not do.
Me? I would do my best to seal the powder coat and touch up the chip with great care, ensuring the repair is smooth in finish.
Good luck.
Good luck.
Discount Tire nicked one of my Z wheels, sent it out for repair/refinishing, and I had it back in less than 24 hours good as new.
Based on the OP’s photo, highly doubt they’re going to replace an entire wheel for that small chip in the finish. Tbh, that wheel finish doesn’t look very durable to begin with looking at how it chipped.
Either way, that brand of wheels would be on my "not to buy" in the future. If the wheels are painted then they were not surfaced prepped properly.
What finish is that? Can they be mounted from the back so that the tire doesn’t roll over the front face?
-Moto
Even the best of the best tire mounting techs make occasional mistakes, and even the best "touchless" mounting equipment will occasionally hiccup.
You'd be surprised how many new and used vehicles have had minor wheel dings touched up, and the new owner has no idea because they look like they were never damaged. Most all dealerships have a mobile wheel repair shop on quick dial.
I need to change out a Tire Pressure Sensor on one High Dollar wheel/tire. Called my closest DT (done significant business with over the years), told them it was a High Dollar wheel and the Service Writer said, "Bring it on in." When I rolled it into DT (~week ago), the Service Writer that I talked to on the phone saw it and said "Whoa, Now I see what you mean by High Dollar. That wheel deserves our Touchless and it is broken".
Long Story - Made much Shorter: He called ~a dozen DT stores. Most did not have a Touchless and those that did were broken. So, discussed with the Senior Tech. He said (this is my memory/interpretation): "Yea, I can do it, and it will almost certainly be fine. But I can't 100% guarantee that nothing slips, and if it does, it might mark up the wheel. That's the advantage of the Touchless. It has multiple points around the tire that go down a little at a time and if operated correctly, it really can't slip into the wheel. Do you need the wheel/tire now? Is it urgent? Or can it wait till we get our Touchless working?"
I don't have my C8 yet, so No Urgency. With No Urgency, I thanked him for being Cautious. I said I would call in a couple of weeks to see if their Touchless was working. I just called (while writing this) and it is still not working, but they think it will be worked on in the next few days. They called around for me (while I was on hold) and found the one in Texas City is working ~15mi away (not too bad).
So, some DT stores have a "Touchless", but even they rarely use it, since they will just default to their std machines 99.99% of the time. This local DT did not use their Touchless when putting new tires on my Fikse FM5's for my C4 recently - And no Issues. Had I known about the Touchless at that time, I would have requested it (though it probably wasn't available).
Might be worth raising the Touchless question in the future at DT for special wheels.
