Sponsored by: Wheel Design
iPhone 12 Pro Max fit?
Old Sep 14, 2021 | 03:36 PM
Smuuth's Avatar
Smuuth
Default iPhone 12 Pro Max fit?
For those who have a iPhone 12 Pro Max, does it fit in the C8 phone charging location?
Old Sep 14, 2021 | 04:12 PM
Majestic94's Avatar
Majestic94
I have an iPhone 12 Pro (no max) and it barely fits with a very snug case on it.
Old Sep 14, 2021 | 04:17 PM
JoeB3's Avatar
JoeB3
2023 C8 of the Year Winner - Modified
Almost the exact same response for my iPhone 11. from the apple web site the specs of an iPhone 11 are: Overall dimensions are 5.94 x 2.98 x 0.33 inches with a weight of approximately 6.84 oz
my iphone 11 (not a max or pro) barely fits with a thin case. so if your specs are ANY larger (from a width perspective) than those dimensions above then i'd be confident in saying it will NOT fit.
Old Sep 14, 2021 | 04:28 PM
Kracka's Avatar
Kracka
My wife's Samsung Galaxy Note 20 w/case fits fine, and her phone is nearly identical in size to a 12 Max Pro.
Same screen size, same thickness, yours is 0.1" wider and hers is 0.1" taller.
Old Sep 14, 2021 | 05:29 PM
mjannusch's Avatar
mjannusch
My iPhone 12 Pro Max fits fine in the charger slot. No case on mine, doesn't need it.
Old Sep 14, 2021 | 05:39 PM
Smuuth's Avatar
Smuuth
Perfect! Thanks.
Old Sep 14, 2021 | 06:16 PM
THX_ZORA's Avatar
THX_ZORA
I have my 12 pro max in an Encased case, which is pretty thick. It fits fine but snugly, and it does charge through that thick case which surprised me!
Old Sep 14, 2021 | 07:56 PM
jtasch's Avatar
jtasch
I put my 12 pro max with the Apple oem leather case and it fit and charged fine.
Old Sep 15, 2021 | 02:19 AM
karate's Avatar
karate
Confirm like the others that iPhone 12 Pro Max fits with out a case in the center rear charger.
Old Sep 16, 2021 | 12:38 AM
Atlantan's Avatar
Atlantan
11 Pro Max with Pitaka case fits just fine. I suspect a bulky case wouldn’t.
Old Sep 16, 2021 | 07:18 AM
Undy's Avatar
Undy
My Note 9 with an Otterbox defender case fits but its a press-fit.
Old Sep 16, 2021 | 07:51 AM
Washagain's Avatar
Washagain
12 Pro Max fits w/o case.
Old Sep 16, 2021 | 11:18 AM
mjannusch's Avatar
mjannusch
To get ahead of the next logical question, the 13 Pro Max is the same size as the 12 Pro Max, but just a touch thicker. It'll fit too.
Old Sep 16, 2021 | 11:28 AM
Blade2382's Avatar
Blade2382
Modified C8 of the Year 2021 Finalist
The pocket is built for pretty much any size phone out there on the market and to compensate for those phones being in most cases unless you are using some tank of a case because you demo buildings all day or are splitting boulders all day or dodging IEDs wherever the hell the forces are being sent next.
My iPhone 12 Pro fits fine width wise with my case with rooms to spare for wider phones. The pocked itself is flexible inside to account for the thickness of your phone case or no case.
Old Oct 1, 2021 | 10:36 PM
Atlantan's Avatar
Atlantan
Just received my iPhone 13 Pro Max, with the Pitaka case it fits perfectly. It is just a bit tighter fit, relative to my previous iPhone 11 Pro Max with the same Pitaka case.
Old Oct 1, 2021 | 11:55 PM
THX_ZORA's Avatar
THX_ZORA
I have an Encased case on my Pro Max 12. It is a very thick, cushioned case. I can slide it into the charging slot with a little extra pressure as the rubber of the case slides against the plastic charging slots. The great news is that my Pro Max 12 charges through that thick case with no problem.....
Old Oct 3, 2021 | 10:37 AM
Day11's Avatar
Day11
iPhone 12 Pro Max in an Otterbox Commuter also fits for reference.
my 13 pro is coming and I’ll check it w commuter next
To iPhone 12 Pro Max fit?
Old Oct 4, 2021 | 07:22 PM
C8vette2020's Avatar
C8vette2020
Thanks!! That was my next question since my 13 Pro Max should arrive this week
Old May 28, 2022 | 10:30 PM
Samuel Clemens's Avatar
Samuel Clemens
Does anybody have an IPhone 13 Pro Max with the OtterBox Symmetry Clear Series+ Case with MagSafe? I just wanted to make sure it fits and charges in the C8 phone slot before I order a new IPhone. Thanks everybody.
Old May 28, 2022 | 10:35 PM
Kracka's Avatar
Kracka
For those that want to compare dimensions, my wife's Samsung Galaxy Note 20 and Google Pixel 6 Pro, both in cases, fit perfectly.
