another engine/rear LED light install
parts list:
red LEDs set of 8 (you can get other colors) $20
12v remote relay kit (to allow control via garage door opener buttons) $18
2) blue wiring T-taps (commonly available in packs at any parts store etc.)
2) blue shielded wiring crimp-on male terminals (again commonly available at parts stores etc.)
2) blue crimp on butt connectors (I used ones with heat shrink built in)
T15 screwdriver or driver bit
small zipties and 1 large ziptie
I started by bench testing the LED light strips and the remote relay setup before fooling with the car at all. Then I went ahead and programmed the car remote buttons to control the relay/lights before actually installing them. Note that you need to use 2 of the car's 3 garage door opener buttons to run this relay/light setup, one is on and one is off.
Next I jacked up the car and removed the driver rear wheel. Use the torx bit to remove the 3 screws there and pull back the plastic liner. You'll see a wiring plug and two fat black and red wires. These wires are constant power and ground and suitable IMO for tapping into for this very low draw circuit, and allows you to run the lights with the car/ignition/accessories off if you want.
I put a tap on each one. These are heavy gauge wires with thick insulation, so I "helped" the taps penetrate the insulation by using a razor knife to make a slice through the insulation before snapping the taps in place. The male crimp terminals go on the wires feeding the relay power. Common sense, red power wire on the car feeds to red wire on relay, black to black for ground.
Now the lights need installed in the car. There are 2 strings of 4 each, so I used 4 on the hatch and 4 down low around the engine. I ran both sets of wires to terminate on the driver side and run them down inside the cavity inside the fender toward all the wiring we just accessed.
I used a combination of electrical tape and zipties to route and hold the wires out of the way along existing wiring harnesses and frame rails on the car. I'm sure over time the electrical tape will need replaced due to heat, but this is just to get the lights in the car and working for a while to see if I like them or want to change it up.
Both sets of lights' wiring goes down to the relay and the 12v+ light wire goes to the white wire on the relay, ground to ground, both are crimped and insulated.
Ziptie it all up out of the way being sure to keep everything as far from the exhaust stuff as possible. Note that the black plastic assembly is a big fan motor and you want to keep wires, zipties etc. clear of the blades inside as well.
The lights look super bright in these pics but it's just the camera exposure. They are pretty subtle and not overwhelming at all as you can see with the pic that the car's headlights are on.
For the front fascia lighting, do you have any issues with LEOs questioning the use of red lights in the front end of the car (unless they are not on when driving the car)?
parts list:
red LEDs set of 8 (you can get other colors) $20 https://www.amazon.com/dp/B01HHFT3V2
12v remote relay kit (to allow control via garage door opener buttons) $18 https://www.amazon.com/dp/B00LMICSIQ
My kit works on Bluetooth and does every color, brightness, dimmer, flash, strobe and will sync to music
as well all from my phone.
Very nice car that was destroyed in an instant. Anyway, I thought I'd share the video their shop has on YouTube. Personally I'd love to just add some accent lighting within the side intake vents to give a soft glow but I'm not capable of taking body parts apart. LOL
I’ve had my car since June 2020 and always envisioned the possibility but the biggest drawback with the C8 is power source. Everyone talks about it and where to find it. Hypntyz, your location by far is the most advantageous spot I’ve seen. Other locations mentioned have been the Backup Assist Module and even more tedious is the fuse box inside the cabin between the two seats behind the ‘waterfall’ which requires going in above the glass, tear out the headliner and getting behind the seats and the area of the waterfall. Lot of work and time consuming. A guy I know here did his that way or should I say a friend of his did it for him and it looked okay, but I was skeptical of having a non pro installer do it. He’s since sold his car back in July after having it since March 2020 and is looking forward to getting the Z06. Anyway, I applaud your ingenuity on coming up with this power source and lead.
The Henry Ruggs III Corvette done by Dreamworks was a pretty spectacular car with lighting. Shame it turned out the way it did with an act of stupidity but that’s another subject matter.
the wires to tap into are thick! I shaved them down to allow for contact and good connection which I did get. Powered up and my system won’t shut off. 🤷🏽
deleted the app and reinstalled it and same deal, lights constantly on and they’re stuck on purple. Can’t leave like this as it will drain the battery eventually. Plan to snip the ground away from connection and let it ride until later and warmer days come.
Can’t figure it out though as they worked perfectly hooked up to my jump pack a
few weeks back when this thread was hot!
Back to the drawing board but yes, that connection is always hot.
When I connected them to my jump pack they have constant power and do as they should, so this power supply would be the same with a constant source.
Why I feel it’s the kit control module is because there is no functionality with the lights constantly on and no control over what they do by staying stuck on one color and when the install of the app to the phone it didn’t allow me to even select a light kit as before saying “no device detected@.
Your source and info is good on this for something to tap into for sure. I am curious what it’s for though, to be a constant. Just wondering….
