EPass Update - Status
This was many moons ago, but I finally had the opportunity to test it yesterday gong to Miami. Being that it is an EPass and not a SunPass, I had to wait overnight for the SunPass transactions (Miami uses a different system) to be uploaded and transferred from SunPass to Epass. Every Toll (5) registered.
This not only proved it should (it was not actually tested on Epass itself) work for Epass, but also on other systems that use transponders that accept Epass.
Yes, I still have/use my Frunk Manual Backup! If it was a daily driver with repeated required opening operations, maybe not, but it is NBD to me. Personal Choice - just sayin'
Interestingly, I was recently in Newport, RI and a bridge there had signs saying that an unmounted EZ Pass is charged more on that particular bridge. That did not turn out to be the case and I was curious how they would know?
@C8J Good to know. I have the EPass sticker - I wonder how that would work in the frunk area. Thanks for the update.
I kept my EZPass in the C7 cubby behind the center screen, but I know that option doesn't exist in C8. It worked most of the time in that location, and I think it would probably work even better mounted to the underside of the frunk lid.
Also, the bigger bar allows for multi state (eastern US currently) use. I do not think that the sticker does.
Based on my experience, the sticker "should" work attached to the hood underside, but until someone reports it works, it is still an unknown.
The reason all of this is possible is due to fiberglass vs metal that would probably act as a shield to rf transmission.
Worse case, it doesn't read and they scan my plates I have on file with the IPASS.
Frankly, I put this out there because some posted that they desired feedback (from an earlier thread on the subject matter) from my mounting in the Frunk. This is why many DO NOT POST. Anytime someone posts, someone else posts how their solution is better. Use it or not - Your choice, but I do not need to be told how to make my choice unless there is a defect I had not thought of. I will gladly welcome the information/suggestion then. There are two ways to go around the block - left turns or right turns. Unless a special condition exists like it is a one way, either is OK. No need to discuss walking, bicycles, helicopters, or ....
[QUOTE=C8J;1604233287]I considered that location, but wanted it out of the weather and WATER environment.
Where mine is, at least, it's never gotten wet, an I've driven through some real monsoons. I've also used them on motorcycles, and being "in the environment" doesn't seem to bother them at all. I think they're completely sealed.
I put my sunpass mini in the same place you did under the frunk lid.
I used velcro like you did to secure it to the roof of the frunk.
I tried it out on the 429 last week and all three times it registered my new transponder. Good to go.
Mike
