Sponsored by: Wheel Design
Rearview camera
Old Mar 1, 2022 | 11:57 AM
Hnfish@aol.com's Avatar
Hnfish@aol.com
6th Gear
Default Rearview camera
Any C8 htc owners have issues with rearview camera?
Old Mar 1, 2022 | 04:54 PM
Zormecteon's Avatar
Zormecteon
Mine appeared "fuzzy". Everything was in perfect focus but "fuzzy". It was as if it was trying to auto-dim from daytime headlights while at the same time being artificially bright. Hard to put into words. I tried the defrost button and it seemed to clear up. Oddly, Just as odd was that even though I was actually hitting the climate control defrost for the front window the camera mirror cleared up!? I only found out after multiple trips I looked at the button wall and say the rear defrost button.WTF? Hitting that button also seemed to clear up the image. ??!?
One thing that finally "fixed" it so that I don't have to keep hitting the button(s) as I drive.................. I took a microfiber cloth and wiped the lens. The car is not EVER garaged and sits out in the rain. The "problem" first occurred during a rainy drive and I thought it was just rear traffics headlights ...
I'm not always the brightest guy, but I sometimes work thru a problem.
Old Mar 1, 2022 | 05:07 PM
Zymurgy's Avatar
Zymurgy
Moderator
It might help if you described whatever issue you are having.
Old Mar 1, 2022 | 06:54 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Well, when the top is down (mine is almost always down), the camera is under cover so you only have the standard mirror.
. Getting used to the camera controls took some practice, too.
. Seems my glasses didn't do very well with the camera mirror, also.
Old Mar 1, 2022 | 09:49 PM
Flad's Avatar
Flad
just a thought, I've had lasik done (mono vision). I also couldn't focus (when the roof up in camera mode). try this it worked for me. change the angle of the mirror, what worked for me was pushing the left side as close to the windshield as possible. That fixed it for me. Honestly once you get the camera view dialed in , it's by far one of the better features. super wide clear view of what's behind.
the downside is when the roof is down and no camera view. The mirror needs to be readjusted to capture the view behind
Old Mar 1, 2022 | 10:00 PM
Hnfish@aol.com
6th Gear
When I raise to top the mirror is half reflecting and half camera. In order or correct I toggle to reflect mirror then adjust position slightly then toggle to camera. This usually corrects problem. Brought car in for service and naturally couldn’t duplicate issue. Anybody have any ideas or suggestions.
Thanks.
Old Mar 1, 2022 | 10:29 PM
16falcon's Avatar
16falcon
St. Jude Donor '21
I have found I definitely have to actually flip it to “non camera” mode when the top is down (even though the camera turns off) and back to camera mode with the top up. Otherwise I get very bad reflections and almost a “double vision” kind of view. If I switch it back and forth it works perfectly.
Old Mar 1, 2022 | 10:31 PM
Red Mist Rulz's Avatar
Red Mist Rulz
Do you mean you're seeing a double image, or literally than the camera image only shows up on half the screen?
If it's the first, I would suggest adjusting the mirror to eliminate the double vision, then see if that position works for the regular rear-view mirror, and adjust from there. I find that if I adjust the mirror so it's pointing down slightly from where I would normally put it, I have no problems with either the mirror or the camera.
If it's something actually wrong with the display, take a picture of it the next time it happens so you can show the service writer.
Old Mar 2, 2022 | 10:14 AM
Ringmaster's Avatar
Ringmaster
Just picked up my car on Saturday. At night the headlights on the cars behind me look like they are in a fog. I haven't looked at the camera lens yet to see if it needs cleaning.
Old Mar 2, 2022 | 11:20 AM
Andybump's Avatar
Andybump
You may see a strobe effect on headlights of some cars in the rear view camera. I believe thats an artifact caused by how the camera samples the image and the way the headlights work. And its normal. Others have reported it, and I saw it recently for the first time. You will initially notice a focus issue when moving your gaze from traffic in front, to the mirror. Thats normal and you will find a way to get used to it. Thats because the focal length to the mirror is just a foot or so, while the focal length through the windshield, and a reflective mirror, is a very long distance. You are accustomed to maintaining the long distance focus, and at first it takes a conscious effort to refocus. I think that goes away. It will be affected by bifocal, trifocal, or progressive lenses - in which case you may actually have to tilt your head upward to put the mirror into the reading portion of the lenses (or just get used to the slight lack of focus).
Old Mar 2, 2022 | 11:25 AM
Ringmaster's Avatar
Ringmaster
How many people have looked into the camera mirror to check their hair?
Old Mar 2, 2022 | 11:36 AM
Zormecteon's Avatar
Zormecteon
Originally Posted by Andybump
You may see a strobe effect on headlights of some cars in the rear view camera. I believe thats an artifact caused by how the camera samples the image and the way the headlights work. And its normal. .
It happens with LED headlights. I haven't seen it from "regular" ones. It has to do with the frame rate of the sampling camera as well as the frequency of the LED's
It's akin to watching Western Movies and seeing the Stage Coach wheels appear to turn backwards.
Old Mar 2, 2022 | 11:42 AM
Ken_C8's Avatar
Ken_C8
St. Jude Donor '09, '21
I notice this, too. Headlights aren't crisp and sharp. I have cleaned my lens. I think it's just the way it is?
Old Mar 2, 2022 | 11:49 AM
Racer X's Avatar
Racer X
I think that the cameras have a defrost/defog feature when you use the normal front and rear defrosters. My biggest problem is that my wife never flips the mirror back after she drives the car with the top down (always) and I get in the top is up and stays up, but the mirror makes weird reflections because it is not correctly positioned.
So, my main rearview camera mirror is not really the mirror, it is my wife.
I do have to clean all the camera lenses from time to time.
Old Mar 2, 2022 | 01:05 PM
JScottH3's Avatar
JScottH3
I wear tri-focal glasses. I have to tip my head up to see the wide mirror (the one at the top of the rear window) clearly. I have no problem with the regular mirror. I haven't figured out any way to change the focus, and the fuzzy rear view mirror drives me crazy. I usually use the regular mirror unless I'm in heavy traffic.
Old Mar 2, 2022 | 02:23 PM
Racer X's Avatar
Racer X
I wear progressives. It has to do with focal distance. With a regular mirror that is the total distance to the object (from you eye to mirror to object behind your so 15 feet to infinity. With the rearview video screen, it is the distance to the screen 2 feet. So one is distance viewing, the other is just longer than reading distance. That is why you have to tilt your head back to get it to focus. The image is actually in good focus, but you are trying focus like it is at a distance (regular mirror). It disconcerting to most, until you get used to it, if you do.
Old Mar 2, 2022 | 05:03 PM
jimmyb's Avatar
jimmyb
You're assuming any of us HAS hair...
To Rearview camera
Old Mar 2, 2022 | 05:29 PM
Zormecteon's Avatar
Zormecteon
Not that I'm happy you have an "issue" too, but I'm glad to know that I'm not alone. .. Must be just the way it is, not indication of immanent failure.
Old Mar 3, 2022 | 11:04 AM
jimjimsC7's Avatar
jimjimsC7
Me and I don't have much hair. Love the camera mirror though, very bright and clear but does take some getting use to.
Old Mar 3, 2022 | 11:41 AM
RLCullum's Avatar
RLCullum
Man, I wish there was a focus dial or something for that mirror. With mono vision, the camera/mirror is really bad.
