Sponsored by: Wheel Design
C8 wheels on a Camaro?
Old Apr 29, 2022 | 08:37 AM
skrupski's Avatar
skrupski
Default C8 wheels on a Camaro?
Anyone know if C8 wheels will work on a newer Camaro? Bolt pattern and lug size is correct, concerned about offsets and 11in rear wheels. Might be a market for some of those takeoffs around.
Old Apr 29, 2022 | 08:56 AM
hawk02's Avatar
hawk02
Why would you even consider C8 wheels? First off, they aren’t the best looking wheels on the market. I immediately swapped the stock wheels on my C8 for HREs. Second, the Corvette wheels are two different sizes. No idea how this might affect handling since the Camaro is setup for the same size wheel on all four corners.
I sold my stock ZL1 wheels (20 x 10 fronts and 20 x 11 rears) to a friend with an 2016 Camaro SS. The fronts stick out past the fender a small amount but otherwise they fit fine with no rubbing.
It seems to me it would be cheaper and less hassle to consider an aftermarket wheel specifically made to fit the Camaro.
Old Apr 29, 2022 | 09:36 AM
Kracka's Avatar
Kracka
The C8 switched over to a 5x120.
https://www.corvetteforum.com/forums...post1601485001
Old Apr 29, 2022 | 09:43 AM
skrupski's Avatar
skrupski
Camaro swithed to 5x120 in 2010 i believe
Old Apr 29, 2022 | 09:55 AM
zackb's Avatar
zackb
And the SS 1LE runs 20x10 et23 and 20x11et43's. I have them on mine and they fit pretty well in the wheel well. The Corvette wheels would be similar to taking a stock SS front and the 1LE rear, which I assume would make the car behave a bit weird.
With that said, the C8 rear wheel offset looks to be an et64. The 20x11 already fits very snug in there, I doubt the Corvette wheel fits right with the different offset.
Old Apr 29, 2022 | 10:03 AM
Kracka's Avatar
Kracka
News to me then, thank you for the correction!
Old Apr 29, 2022 | 10:25 AM
skrupski's Avatar
skrupski
Thanks, Sounds like its questionable, not ideal. Of course I have seen lots of wheels on cars that shouldn't be there.
To C8 wheels on a Camaro?
