dexos 2 and dexos R
These are the questions I asked:
Question: 1) Are the dexos 2 and dexos R specifications the same? 2) Are the new "Mobil Supercar 0W-40" and the "Mobil 1 ESP Formula 0W-40" identical? 3) The 2023 Corvette Owners Manual recommends only motor oil 0W-40 meeting the dexos R specification. Can the previous recommended oil (for 2020-2022 Corvette with LT2 engine) , 0W-40 meeting the dexo 2 spec be use in place of that?
And, here is the response:
"Thanks for writing to us. DexosR is superseding Dexos2 in high performance gasoline engine applications (like the Corvette), only. Dexos2 is not going away, as it is still the standard for GM's "passenger light diesel" engines found in models like the Colorado/Canyon trucks, a few model years of the Cruze, and in the Equinox.
In earlier model years listing Dexos2 in the manual, Dexos2 licensed 0W-40 oils are still safe to use until the supply runs out. If your 2023 manual ONLY lists DexosR, I wouldn't risk giving anyone a loophole to void your warranty.
If I can help with any other questions, please respond to this email or call me at 1-800-ASK-MOBIL (800-275-6624).
Thank you for choosing Mobil,
Jim
Mobil Help Desk Team"
AND THIS IS FROM THE 2023 MANUAL
0W-40 dexos2 may become scarce if not many diesel engines use that weight.
In earlier model years listing Dexos2 in the manual, Dexos2 licensed 0W-40 oils are still safe to use until the supply runs out. If your 2023 manual ONLY lists DexosR, I wouldn't risk giving anyone a loophole to void your warranty. ) I
Jim
Assuming you quoted “Jim” from Mobil correctly he incorrectly used a capital “D!”
Their trademark attorniies will be all over his butt!
In a long-ago gen, the LS3 came out w. a specific oil type (I think it was GM4718M for Mobil 1). It was a departure from prior recommended motor oil use and was toward the beginning of the "Dexos" name. Other brands of full syn oil eventually got the GM designation besides Mobil 1. It could happen with the C8.
I do hope the esp x3 and other better dexos2 oils also become DexosR approved for the 2023 plus folks
Jim
Seems to say generic mobile 1 meets Dexos R specifications
What do you guys think??
