Sponsored by: Wheel Design
First C8 oil change
Old May 10, 2023 | 10:25 PM
Andybump's Avatar
Andybump
Originally Posted by Floridasky
Do have to change the o rings on drain plug with every change?
Only "if necessary" per the service manual:
'2. Note:
Clean and inspect the oil pan drain plug gaskets (2 & 3) and replace if necessary."
Old May 10, 2023 | 10:29 PM
Spitfire Mk1's Avatar
Spitfire Mk1
Formula 1
I have the dealer do the services with any of my cars that are under warranty.
To me, it’s more than draining the oil/fluids. Includes look under the car while up on the rack, scan for codes, update software, test electronics, leaks, get entry on carfax for service, and better protect the existing warranty.
Yea, i know if done myself, keep receipts, etc, GM should honor warranty. I just don’t want any daylight if something serious goes wrong, mechanically while under warranty.
To me, creates a relationship with the service dept when may need them in the future.
Old May 12, 2023 | 05:03 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
I do not believe taking a new Corvette to a dealer for an oil change will include any of
Includes look under the car while up on the rack, scan for codes, update software, test electronics, leaks, “
Old May 12, 2023 | 05:31 PM
Mike's LS3's Avatar
Mike's LS3
Correct a dealer needs a visible, audible or DTC to perform additional work.
1. Scan for codes: I use a code reader if a DTC lights up. Then if necessary, I will bring it to a dealer,
2. Updates: I use OTA updates, unless update is a large file, then a dealer has to do it.
3. No need to test electronics with no DTC and as stated, the dealer needs a reason to do so. I do have volt meter, battery tester and Code reader with live data. All simple and inexpensive auto tools.
4. Leaks, dealers do not remove the lower panels to change engine oil, so they will see what you see.
All I'm saying is that if only an oil change is needed and no codes or visible leaks, it's an easy DYI at home.
BTW: Don't forget to apply a little oil on the "O" rings of the oil pan bolt before reinstalling.
Old May 12, 2023 | 05:50 PM
Mike's LS3's Avatar
Mike's LS3
Correct, if no concerns visibly, audibly or DTC codes are present the dealer is going to just change the oil.
1. Scan for codes: I use a code reader if a DTC lights up and then bring to a dealer, if necessary.
3. No need to test electronics with no DTC and the dealer needs a reason to do so. I do have voltmeter, battery tester and Code reader with live data. All simple and inexpensive auto tools.
4. Leaks, dealers do not remove the lower panels to change oil, so they will see what you see.
If only an oil change is needed, it's an easy DYI at home.
